Welded and Balanced Fan Question
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Oct 29, 2011 8:09 pm    Post subject: Reply with quote
I had my stock, unwelded fan to 7K+ on accident.......it held up. Would I do it again? Heck no. Laughing I'm building a new IDA motor, going to weld the fan. I should say, that you can gain a bit of 'buffer' if you will, by running a smaller power pulley at the track to keep that fan from spinning so fast. This of course all depends on what RPM you're shifting at if it's isn't too obnoxious.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Oct 29, 2011 8:15 pm    Post subject: Reply with quote
15 years ago I missed a shift and had the stock fan explode. Had to replace the shroud, oil cooler, alternator and fan shroud. Also had 2 fins broken on the right side head.
Glenn
Member #1009
#BlueSquare
mxracer
mxracer is offline
PostPosted: Sat Oct 29, 2011 8:42 pm    Post subject: Reply with quote
I tig'ed my T3 fan without issue. There is enough tab bent over at each fin to weld it without filler rod so throwing it out of balance isn't an issue. I had everything from pulley to flywheel balanced and the fan was still dead on after welding it. It's an easy job with a good tig welder and a little skill. If anyone is interested PM me and I'll weld it up for a fraction of the cost of a Berg one. Then you can get it balanced (or at least checked) when you get the rest of the parts done. I also plan to make a jig for my balance machine so I can take care of that part as well.
69 Jim
69 Jim is offline
PostPosted: Sun Oct 30, 2011 12:06 am    Post subject: Reply with quote
Didn't research it well enough prior to purchasing one from Kustom1. What a wobbling piece of crap. Will be calling Berg on Monday. Live and learn...
[email protected]
john@aircooled.net is offline
PostPosted: Sun Oct 30, 2011 11:24 am    Post subject: Reply with quote
You can prevent some of the fan issues by running a GOOD BELT, "race loose". The fan will hit a speed and won't go faster, even with increasing engine speed. That's one problem with Serpentine Belts, they grip "too well".
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
rkeller
rkeller is offline
PostPosted: Wed Jan 18, 2012 5:34 pm    Post subject: Reply with quote
Is there a market for a better fan?
We are thinking about manufacturing an advanced fan design.
http://www.thesamba.com/vw/forum/viewtopic.php?t=494873&postdays=0&postorder=asc&start=0
58 Plastic Tub
58 Plastic Tub is offline
PostPosted: Wed Jan 18, 2012 10:43 pm    Post subject: Reply with quote
I would be interested. There's one....
Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie."
torsionbar
torsionbar is offline
PostPosted: Fri Jan 20, 2012 1:21 pm    Post subject: Reply with quote
Hotrodvw wrote:
So, welding them is the easy part. How does one balance one themselves? I know how it's done, but have any of you done it yourself at home?
sure, anybody can do it themselves at home. you just need to own a balancing machine. do you have a balancing machine at home?
Max Welton wrote:
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed.
Hotrodvw
Hotrodvw is offline
PostPosted: Fri Jan 20, 2012 1:32 pm    Post subject: Reply with quote
I do not.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
catbox
catbox is offline
PostPosted: Fri Jan 20, 2012 1:46 pm    Post subject: Reply with quote
Lawn mower blade balancer....
Laughing
"...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume.
Hotrodvw
Hotrodvw is offline
PostPosted: Fri Jan 20, 2012 1:49 pm    Post subject: Reply with quote
Think Harbor Freight sells balancers.....
'67 Sunroof
Eric
lots of money!
Hose & Fittings
oldmanmark
oldmanmark is offline
PostPosted: Mon Jan 30, 2012 12:21 am    Post subject: Reply with quote
X2 on racin jason.
adalcanto
adalcanto is offline
PostPosted: Tue Jan 31, 2012 1:38 pm    Post subject: Reply with quote
The bottom line is you never want one to explode as it tears things up beyond belief. I had one explode at Sacramento (BOM) and it took out the fan shroud, alternator and broke a few fins off of one cylinder. The noise.... holy crap! My linkage got tweaked and what not. Let’s just say that night I was in the pits doing a teardown and repair with a mediocre fan I bought from a vendor. On race day I pulled the belt so there was no chance of another grenade going off. I now run a Berg fan with a serpentine belt and have taken it up but still uncomfortable with it so I pull the belt when I race. Even if you use a v-belt and run it loose it is risky in my opinion and most time the belt just rolls off and you lose it at halftrack.
1LOW67
rs58rag
rs58rag is offline
PostPosted: Wed Feb 01, 2012 11:14 pm    Post subject: Reply with quote
Fully tig welded German fan is the way to go and remember to torque fan nut to 40-45 lbs.
Joost
Joost is offline
PostPosted: Mon Feb 27, 2012 6:50 am    Post subject: Reply with quote
http://www.gwd-weiser.de/?luftkhlung=hochleistungs-lufterrad
hpw
hpw is offline
PostPosted: Mon Feb 27, 2012 3:12 pm    Post subject: Reply with quote
345,00 €=$462.00 Shocked Did I convert that right?
http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2
Hotrodvw
Hotrodvw is offline
PostPosted: Mon Feb 27, 2012 3:30 pm    Post subject: Reply with quote
Sounds appropriate due to the weak USD. There are other ways than spending $462.00.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
thebucket
Samba Stockbroker
thebucket is offline
PostPosted: Mon Feb 27, 2012 9:11 pm    Post subject: Reply with quote
Glenn wrote:
Berg.
Trust me... it's not pretty one a fan explodes... i've been there.
Dittp!
ITMC-El Presidente
OG 55 bullet 3 fold....
http://www.thesamba.com/vw/forum/viewtopic.php?t=150858&highlight=thebuckets++++fold
youngstah
youngstah is offline
PostPosted: Sun Jan 11, 2015 6:20 pm    Post subject: fwiw berg doghouse fan 2105 Reply with quote
After reading this older yet informative thread and speaking w a berg late last year i figured a purchase was in order. It seemed at the time there were only a few German OEM fans hanging around still.
I waited until now to place the order. I thought od share woth you what i received and let you comment: Prumsa (sounds brazilian?)
Im NOT completely on the up and up re good vs bad practices with welded fan production but upon inspection i did notice the following so perhaps you could comment:
- good weld penetration
- it seems filler rod was used
- the veins dont appear to be perpendicular to the axis
- the edges are ground for circumference rounding - is this how its balanced?
- clean bare metal, coated w a wd40 like substance (do folks have theirs painted / powder coated and will this affect the balance?
Eaallred
Eaallred is offline
PostPosted: Sun Jan 11, 2015 7:40 pm    Post subject: Reply with quote
It certainly does look like filler rod was used. Using a TIG to simply melt the existing tabs over works extremely well though....
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
Page 4 of 5
