Turk.380 Samba Member
Posted: Fri Dec 30, 2011 12:21 pm Post subject: |
presslab wrote: |
Did you use an impact driver to get the screws out?
ETKA shows the screws as M7x1.25x13, part number N 090 173 3. It is an odd screw, hope that helps you to find it. |
Yeah, I did. But the Phillips slots were already completely rounded out, so I had to carefully cut a new slot and and then used a flat blade in the impact driver.
I do not want to put those back in!!!
thanks for the specs... still searching. All the suppliers I've found so far only go up to an M6.
EDIT: After Googling your exact part description / part # it appears that I'm not alone! Lots of Vortex and water-cooled forum threads of folks trying to find this same screw. apparently it's also used as a speedo cable retainer on Rabbits!
EDIT #2: Dealer orderable... 6$ EACH!! _________________ Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista |
Summers420us Samba Member
Joined: June 14, 2010 Posts: 759 Location: Amissville, Virginia
Posted: Fri Dec 30, 2011 1:04 pm Post subject: |
They are VERY proud of their hardware! |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Fri Dec 30, 2011 1:07 pm Post subject: |
Quote: |
EDIT: After Googling your exact part description / part # it appears that I'm not alone! Lots of Vortex and water-cooled forum threads of folks trying to find this same screw. apparently it's also used as a speedo cable retainer on Rabbits |
'84-'99 jetta use it as a speedo cable retainer bolt
'68-'79 busses and all vanagons use it in the same position
Just some more wrecking yard options for you.
You can get them from vwdiscountparts.com for less than a buck and a half each new. |
Posted: Fri Dec 30, 2011 2:21 pm Post subject: |
syncrodoka wrote: |
Thanks for the source, but after shipping I may as well just pay the dealer price for a few.
Bookmarked for future oddball part needs though, thanks! _________________ Brian W
St. Louis, MO
chimivee Samba Member
Joined: September 23, 2009 Posts: 741 Location: Orange, CA
Posted: Mon Mar 05, 2012 12:11 am Post subject: |
I'm in the middle of this job, and I can't get the old flange seals out. I tried inserting a screw as mentioned by the OP, but the screw simply tore out as I pried. Found a "seal puller" at Sears, like this:
I gave it a go, but I'm not sure it's meant for this odd shaped seal (or maybe I'm using it wrong ).
Any other ideas on getting these seals things out?. Today was a frustrating Vanagaon day. _________________ -James
86 Syncro Westy, etc |
Posted: Mon Mar 05, 2012 12:38 am Post subject: |
Where he shows the screw going in is just a rubber lip with a spring. Try on the part of the seal with the recessed blocks in it, that part of the seal has a metal backing.
The seal puller you bought usually works well but maybe not in this situation. Are you laying it flat against the shaft and wedging it under the seal? |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Mon Mar 05, 2012 7:02 am Post subject: |
chimivee wrote: |
Any other ideas on getting these seals things out?. Today was a frustrating Vanagaon day. |
I used the same puller, in a parking lot in Reno. It worked ok, I pried against the adjuster ring. It takes a lot of force, as it bends the seal because it does not pull straight out. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
deprivation Samba Member
Joined: September 14, 2006 Posts: 1220 Location: Austin, Texas
Posted: Mon Mar 05, 2012 8:33 am Post subject: |
syncrodoka wrote: |
Try on the part of the seal with the recessed blocks in it, that part of the seal has a metal backing. |
Exactly right. You'll have to put the screw in fairly close to the outside of the seal because it is strongest there. Be care not to gouge the flange itself.
BTW, I used drywall zip screws to remove my seal and they worked very well.
Good luck. You'll get it. _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
www.kittenfart.com |
?Waldo? Samba Member
Posted: Mon Mar 05, 2012 9:49 am Post subject: |
Be sure to check that the atmospheric bleed in the top front of the trans is not blocked before starting on this job. If it is plugged (quite common) then it will make brand new seals leak. And if it is plugged and your seals are leaking, unplugging it will often cure the leaking without needing to change the seals. |
Posted: Mon Mar 05, 2012 11:02 am Post subject: |
Syncros rarely have that problem because the vent line is plumbed over the gas tank not open right over the nosecone like 2wd vans |
Leebo Samba Member
Joined: February 01, 2012 Posts: 87 Location: Mountains of N.C.
Posted: Mon Mar 05, 2012 11:32 am Post subject: |
OK, so I had some tranny fluid leaking out of my boot (driver/tranny joint). I read some previous posts and thought that maybe it was just my drive flange cap that had failed and that by replacing that piece it would be all good.
So, I removed the axle bolts and the drive flange cap fell to the floor. It looks to be fine after a cleaning. So, do I simply place this back on and bolt the axle back to the tranny and all is good? After reading this post I'm wondering if it may be my drive flange seals? Does the cap "click" or "snap' in? For mine, it just seems to kind of lay there.
Also, since I have been losing the tranny fluid, I'll need to top it off. I have searched and it appears the drain plug is located on the bottom towards the engine. Where the heck is the fill plug? I thought I read it was on the driver's side about half way up?
Thanks!! _________________ '84 Westy
1.9L w/'89 tranny |
Posted: Mon Mar 05, 2012 12:14 pm Post subject: |
deprivation wrote: |
syncrodoka wrote: |
Good luck. You'll get it. |
Thanks SD and Dep. for the tips. I had the screw more toward the inside of the seal, per the OP's photos. I recall some metal fleck when I drilled, so I think I caught the metal in the seal. But I will try again further out. Thanks! _________________ -James
Posted: Mon Mar 05, 2012 12:20 pm Post subject: |
syncrodoka wrote: |
Yes, I should have mentioned that this is for my Syncro. And I did start by making a 20-second attempt at checking for blockage on the vent line... But after following the tube back to where it disappeared into the abyss, I moved on. _________________ -James
Posted: Mon Mar 05, 2012 12:39 pm Post subject: |
Leebo wrote: |
So, I removed the axle bolts and the drive flange cap fell to the floor. It looks to be fine after a cleaning. So, do I simply place this back on and bolt the axle back to the tranny and all is good? After reading this post I'm wondering if it may be my drive flange seals? Does the cap "click" or "snap' in? For mine, it just seems to kind of lay there. |
FWIW, my driver side cap fell right out too when I pulled the axle; the CV was flooded with gear oil. But I was also getting oil weeping from the passenger side, even thought that cap was in tact.
On a related note, how do the flange seal (axle seal) and flange cap differ in terms of how/what they are sealing? It sounds like tranny oil isn't necessarily contained by the flange seal, since a bad/loose cap can leak oil too. Should the new cap be installed with RTV? _________________ -James
Posted: Mon Mar 05, 2012 1:53 pm Post subject: |
chimivee wrote: |
On a related note, how do the flange seal (axle seal) and flange cap differ in terms of how/what they are sealing? It sounds like tranny oil isn't necessarily contained by the flange seal, since a bad/loose cap can leak oil too. Should the new cap be installed with RTV? |
The cap seals against oil leaking past the splines between the axle and the flange into the CV joint. The axle seal prevents oil from leaking out around the flange.
Yes clean the metal parts and rubber cap with acetone and apply silicone sealant (RTV) where the cap touches the flange before assembly. Afterward, it's not a bad idea to liberally apply silicone sealant over the top of the cap, especially if you run aftermarket drive axles. _________________ 1986 Vanagon Westfalia EJ25
Leebo Samba Member
Posted: Mon Mar 05, 2012 4:52 pm Post subject: |
OK, so I figured out that I had the flange cap on backwards (duh!). After I flipped it around I used the back of a screwdriver to "pop" it back in. Now I'm wondering if that will solve my tranny oil leaking in the boot or do I need to replace the seal, too? I guess I'll drive around the block and see if it still leaks or not. _________________ '84 Westy
1.9L w/'89 tranny |
Posted: Mon Mar 05, 2012 11:15 pm Post subject: |
So, turns out, being dumb isn't so bad... when you're internet friends are SMART. Thanks all for the help. Got it done.
I figured I'd start with Presslab's suggestion and tried the seal puller again. I had to pryl REALLY REALLY hard, pulling from a couple points along the seal perimeter before it came out.
Getting it all back together took a little effort too. The passenger side flange took probably 200 blows with a block/mallot to seat it fully. Following tips here, I used a honkin' socket (1.25") to hammer against and press the spring washer to seat the clip. BTW, removing the flange was by no means easy either - didn't come close to sliding off. I rigged a FLAPS loaner puller tool to work and really cranked on the thing to get it off.
Anyway, thanks again all! I hope others have a little easier time with this one than me. _________________ -James
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Fri Apr 06, 2012 7:53 pm Post subject: |
Wow, you got lucky with those. I also had to use a puller to get both flanges off. The seals were unbelievable as well - a fight to the end. I have a seal puller I've used for 20 years and perhaps a hundred seals. Broke it and had not budged the first seal. Went to NAPA and got a top shelf one and still had to use a cheater bar.
A tip on putting them back in. The seal has ribbed edges that contact the seating area. For some reason, these don't yield to hammer blows well - almost as if they flex in, then rebound back out with little actual progress. So after I had them started and progress stopped with quite a bit to go, I used a long piece of wood for leverage and pried them in the rest of the way using a large socket to push against. It was surprisingly little effort to push it home though minutes before it had not budged with a heavy plastic and brass hammer. I think it's those ribs.
The flanges needed to be pounded on with the brass hammer. Just work around the flange edge after it's started on the splines.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Sat Apr 07, 2012 10:20 am Post subject: drive flange |
Thanks guys, as always you come to the rescue , mine started to leak last week, had know idea how to do this. Getting ready to order parts monday . Now I know what I'm getting myself into! _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
Posted: Sat Apr 07, 2012 10:46 am Post subject: |
Tap a 12 pt socket over the heads and they come right out without drama. |
