Flavourless Samba Member
Posted: Tue Mar 13, 2012 1:48 pm Post subject: Need help identifying carb setup |
Just recently bought this square back and has a built motor with webber carbs and gene berg manifolds. I need to have the carbs rebuilt but can't find any markings on the carbs as to which model they are. The guy that looked at them thinks they are 40 dcnf's but want to make sure that's the case before ordering a rebuild kit. Also anyone know what size filters these take. The P/O ruined the filters so I need new ones.
Thanks for any and all help |
XxonValdez Samba Member
Joined: February 01, 2008 Posts: 264 Location: San Diego, CA
Posted: Tue Mar 13, 2012 1:51 pm Post subject: |
Look like 40 DCNF's to me, from what I have read I think Berg liked to use those carbs in his old setups. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Tue Mar 13, 2012 1:54 pm Post subject: |
With the nuts on the mixture screws I could assume Berg specials, dcnf modified by berg |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Tue Mar 13, 2012 2:08 pm Post subject: |
mcmscott wrote: |
^^^ I agree ^^^ You could see if Berg's have rebuild kits and the retangular air filters but they are anal about seeing the original receipt of purchase otherwise they might not help you. Pierce Manifolds is another good source of DCNF parts and there's always Art @ Air Cooled Engineering if you don't want to tackle the rebuild yourself. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
PocketRocket Samba Member
Joined: September 22, 2005 Posts: 52 Location: Walla Walla,Washington
Posted: Tue Mar 13, 2012 3:57 pm Post subject: |
My guess is 42 dcnf set from Berg. I don't think he did any 40s. |
Posted: Tue Mar 13, 2012 5:22 pm Post subject: |
Wow thanks a lot guys for the quick responses. I did find Pierce manifolds when I was googling rebuild kits for the dcnf carbs. From what I briefly read they have the most complete rebuild kits but are a little more expensive. It looks like the 40,42 and 44 rebuild kits are all the same according to pierce manifolds website. Anyone know off the top of their head if this is true?
I will give Berg a call or email and see if I can get any help from them or not. It's always worth a shot. I will have someone rebuild and retune the carbs as I still am not comfortable with carbs yet and this is my daily. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Tue Mar 13, 2012 5:26 pm Post subject: |
If the part numbers are ground off it's likely a berg dcnf kit, yeah, he did that! |
Posted: Tue Mar 13, 2012 5:52 pm Post subject: |
Yes the kits are all the same. I have rebuilt lots of the dcnf carbs I like them and they work great. I know you have 42 berg dcnf's if the numbers are ground off the flat side of the float bowls. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Mar 13, 2012 6:35 pm Post subject: |
And NO silicone RTV.....
Posted: Tue Mar 13, 2012 9:39 pm Post subject: |
Dale M. wrote: |
And NO silicone RTV..... |
aka Blue Goo _________________
Mitey62 wrote: |
Posted: Tue Mar 13, 2012 10:34 pm Post subject: |
PocketRocket wrote: |
must have missed this, but does the kit from Pierce include this kit that Gene Berg offers as an addition to the main rebuild kit?
http://www.geneberg.com/product_info.php?cPath=8_2804_2870&products_id=965 |
