Karzapart55 Samba Member
Joined: May 26, 2004 Posts: 640 Location: Old Bridge NJ
Posted: Tue Mar 13, 2012 4:50 pm Post subject: Seat cover Q |
I have a set of TMI covers for my 72 Bus. I have the Wolfburg West coconut pads. Do i need the anything between the pads and the covers? Thanks |
Brionp Samba Member
Posted: Tue Mar 13, 2012 5:59 pm Post subject: |
There was just a post a week or so ago about a white bus in Hawaii that someone bought for his wife and he did a TMI install. He used the WW coco seat covers but he placed a piece of material on top of the springs before he put the coco on. I believe just to catch the coco fibers if they came loose later on down the line. They also put about an inch thick piece of foam padding on the top side of the coco and when the covers were installed they looked tight and tidy. So thats my plan. |
chabanais Samba Member
Posted: Tue Mar 13, 2012 6:22 pm Post subject: |
Putting a plastic bag over the seat prior to installing the covers will make them go on a whole heck of a lot easier. _________________ "I spud therefore I yam." |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
Posted: Tue Mar 13, 2012 8:09 pm Post subject: |
Brionp wrote: |
the thick piece of fabric dose this job also but it also protects the ww horsehair from the springs _________________ 75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Tue Mar 13, 2012 10:07 pm Post subject: |
When I did my 72 SB using TMI seats, I hog-ringed burlap (you can buy it by the roll at Home Depot) over the springs, sprayed 3M Super77 adhesive on the top of it and then fitted the padding over it. This the closest thing you're going to get to hog-ringing the padding into place, it prevents the springs from cutting into the pad, and tacks everything down tight.
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
