Is the motor destroyed? |
Yes! |
44% |
[ 4 ] |
No, it can be re-built. |
33% |
[ 3 ] |
Start saving money.... |
22% |
[ 2 ] |
Total Votes : 9 |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Mon Mar 19, 2012 3:38 am Post subject: H6 Conversion- My New Problem..... |
My exhaust broke the other day. As I drove (slowly!) to work, the engine started to knock. I had the exhaust welded at work, but the knock stuck around. Here is the video I made on Sunday.
....And I have already posted this on the Subagon forum. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Mon Mar 19, 2012 5:55 am Post subject: |
The poll should have had a "all of the above" option.
You might want to stop running the engine until you tear into it a bit to see where the trouble is. I was cringing during the whole video and when you revved it up, it was like dragging your nails down a chalkboard.
I wonder if the shorten oil pan had anything to do with it or maybe your donor engine came out of a rollover. I don't know, do new cars have a safety feature that shuts the engine off as soon as the car goes belly up?
This has convinced me to leave my oil pan alone, though. Good luck. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin |
insyncro Banned
Posted: Mon Mar 19, 2012 6:52 am Post subject: |
Why are you still running the engine?
Since you are, I'd say its f'd.
Drain and screen the oil.
Pull the pan and check it and the sump for particles/ pieces of anything.
Where did the exhaust crack?
It sounds to me like a hole in a piston, but I'm thousands of miles away watching a video.
Its chugging right?
Sounds like a train to me.
Very difficult to diagnose under these circumstances.
If it was me, I would have the engine on a stand and opened up at the first sound like this.
Continuing to run this motor will cost you more and more to fix it, the longer it runs.
EZ30d long blocks are going for roughly $850 in my neck of the woods. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Mon Mar 19, 2012 7:06 am Post subject: |
Killing one cylinder at a time and repeating your test, will take the load off of the cylinder to help narrow in on the noise. Rod bearings fail due to lack of lubrication or from detonation or a combination of both. If killing a cylinder at a time does not make a difference in the sound, it may be upper end. I would also remove all the belts to be sure it is not an external problem. _________________ ☮️ |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Mon Mar 19, 2012 7:51 am Post subject: |
When you revved it up, I held my hand over my eyes waiting for a rod to punch through the case.
Stop running it and maybe it can be fixed. How did the exhaust break? Wasn't it all new? |
Posted: Mon Mar 19, 2012 8:56 am Post subject: |
After the exhaust was fixed, I drove it home, and it has stayed put since. As far as taking the belt off, I hadn't thought of that, but then again, it does not sound like the power steering pump. I comes from under the pump. It sounds like #1 cylinder.
Insyncro- could you check on those motors for me? For $100, my shop's part supplier will ship a motor to my shop. My computer is a 01-02.
The donor motor DID come from a wreck. I had to replace the crank position sensor when I finished the build. This is the emergency shut off for the motor.
Yes, the exhaust was new. It broke on a welded seam, right under the trans.
This crack went just about all the way around. We had to pull the exhaust apart and weld it on the bench. Our Master Welder added a sheath over the weld just to beef it up. The pipes are thin, coated mild steel. I mentioned this to the guy I got my conversion kit from, and he said that he has since changed the quality of pipes he offers. He then offered me new pipes for cost of shipping. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
insyncro Banned
Posted: Mon Mar 19, 2012 12:01 pm Post subject: |
As I understand it the stainless pipes had issues.
The replacement mild steel, coated inside and out are much more stout.
At the cost of shipping for them, that is a deal and no brainer
As for motors, they are plentiful.
The low mileage ones are drying up fast.
Do a search, they will turn up.
Posted: Mon Mar 19, 2012 1:58 pm Post subject: |
Yeah. Lets move this to PM. I found a way, but I gotta clear it through work, so I will let you know tomorrow.
Please look into the motors and let me know what is actually available and prices.
Cheers! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Mon Mar 19, 2012 2:38 pm Post subject: |
As with other suggestions, pull power to each plug one at a time. If it's a rod, it should quieten down a little.
I'd also pull the sump and check for bearing material. How's the oil pressure?
Bummer... I know how it feels. Bad luck mate.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
Posted: Mon Mar 19, 2012 3:39 pm Post subject: |
I don't know about oil pressure (I don't have a pressure gauge), but I did spot a class 1 oil leak coming from under the crank-shaft pulley.
Oil IS full, BTW. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Mon Mar 19, 2012 3:44 pm Post subject: |
Is your oil light working right ? |
thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Mon Mar 19, 2012 9:59 pm Post subject: |
that rod would have let go by now-- you may have spun a cam shim or a lifter on the right side. pulling one plug at a time will hint to which cylinder.
my condolences--I too installed a hard-run engine with oil in my coolant now. a new engine is a good preventative with conversions. It lasted a while though. |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Zeitgeist 13 Samba Member
Posted: Tue Mar 20, 2012 8:06 am Post subject: |
I guess I'm missing something from what I've read here (is this a carry-over from another conversation?), but how does a small exhaust leak lead to a rod knock? It seems the only logical connection between the two would be a burnt exhaust valve from the introduction of super cool air into the exhaust stream. How about a simple diagnostic test like a compression test? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
insyncro Banned
Posted: Tue Mar 20, 2012 8:13 am Post subject: |
Zeitgeist 13 wrote: |
I guess I'm missing something from what I've read here (is this a carry-over from another conversation?), but how does a small exhaust leak lead to a rod knock? It seems the only logical connection between the two would be a burnt exhaust valve from the introduction of super cool air into the exhaust stream. How about a simple diagnostic test like a compression test? |
We shall see.
Im curious to know what happened, but not that curious. |
wolfsburg4x4 Samba Member
Posted: Tue Mar 20, 2012 8:15 am Post subject: |
A replacement ceramic coated mild steel header is on the way, look for it in your mail box soon.
Did you try to put a magnet to your existing header ? Unless the builder of that exhaust lied, it is indeed stainless steel, and they were not cheap.
www.stainlessheaders.com
If you need to replace the motor, I would recommend doing a leak down test on the "new" one before buying it, and unless the motor has less than 50k miles, it would be a good idea to replace the plastic chain guides and tensioner...
Their are plenty of those motors available here in the states, although a 2001-02 will probably have higher miles.
Eric |
Posted: Tue Mar 20, 2012 9:14 am Post subject: |
I was just hoping I hadn't missed out on the Group Buy for the Samba "Jump to Conclusions Mat"
y u rune klassik? |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Tue Mar 20, 2012 10:38 am Post subject: |
Dude, that sounds bad...time to put an EJ2.5 in |
Posted: Sat Apr 21, 2012 12:30 pm Post subject: |
So thank you all for your help with finding a new engine. A special big thanks to whats-his-name for telling me I'm not worth his time, and doesn't deal with 'people like me' (?) via PM.
I found a new motor, had it shipped to Germany, and had it installed in two days.
And yes, it was a bearing. When I pulled the oil pan off the old motor, there were chips and pieces stuck to the magnets. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Sat Apr 21, 2012 4:35 pm Post subject: |
Any idea how this happened? I'm assuming it might be due to the situation (wreck) that led to it being available in the first place--> roll-over _________________ Casey--
y u rune klassik? |
