T2 How much does Engine Transmission weigh weighs weight
Rocknrod
Rocknrod is offline
PostPosted: Wed Dec 15, 2004 7:28 am    Post subject: T2 How much does Engine Transmission weigh weighs weight Reply with quote
Hey guys...
Anyone tried to ship an engine? Type 1? Type 4? How much did they weigh?
Anyone tried to ship a transmission? How much do they weigh?
Thanks guys Cool
VWBusrepairman
VWBusrepairman is offline
PostPosted: Wed Dec 15, 2004 8:41 am    Post subject: Reply with quote
I believe a fully dressed type IV engine is in the neighborhood of around 273 lbs. and a type I engine is around 30-40lbs. less. The transmissions are comparable topping the charts near 55-65 lbs.
I believe FedEx only ships ground items to 150 bs.
(I do accept engines/ transmissions as Christmas gifts, so ship them to me)...
Rocknrod
Rocknrod is offline
PostPosted: Wed Dec 15, 2004 9:34 am    Post subject: Reply with quote
Dont have any engines to ship ya...
I'm thinking about building a rear engine sportscar, just trying to find an engine/transmission combo thats cheap, and light.
Still havent found anything about the power this stuff will take though... Wink
pawesty
Samba Medic
pawesty is offline
PostPosted: Wed Dec 15, 2004 10:13 am    Post subject: Reply with quote
transmission in the neighborhood of 75 lbs. complete type 4 around 300lbs, 1600 around 25 lighter. these are loose numbers, give or take a few lbs.
dave
"Go smell the wind, go far. Hear the marvelous strange chime of midnight" Kerouac
79 westy
78 westy
purveyor of refurbed westies and parts!!! inquire within!
mightyart
mightyart is offline
PostPosted: Wed Dec 15, 2004 10:32 am    Post subject: Reply with quote
The best way to ship something like that is on a pallet and via truck freight. Although the cost may be about the same as a tow dolly from
U-haul.
My Art:
http://www.gordonflynn.com
VDubTech
VDubTech is offline
PostPosted: Wed Dec 15, 2004 10:52 am    Post subject: Reply with quote
I shipped a complete 6-rib Bus tranny from Syracuse, NY to Ohio for about $40 vis UPS. I used your standard cardboard box and lined the bottom with a scrap piece of plywood. I used a heavy duty box, and it got there fine.
ratwell
ratwell is offline
PostPosted: Wed Dec 15, 2004 12:04 pm    Post subject: T2 How much does Engine Transmission weigh weighs weight Reply with quote
I just weighed all this stuff as part of an engine breakdown and shipment prep:
http://www.ratwell.com/technical/Weights.html
Long block:
A Type 4 long block weighs approx. 142 lbs.
Case - 55 lbs.
Crank - TBD
Camshaft - 3 lb. 12 oz.
Cylinder head - 17.5 lbs.
Piston + pin - 1 lb. 9 oz.
Cylinder - 6 lbs. 5 oz.
Rods - TBD
8 Lifters - 2 lb. 3 oz.
8 Push rod tubes - 1 lb. 6 oz.
Engine:
Fully dressed Type 4 weighs 309 lbs.
How does a long block compare to a Type 4 fully dressed? The long block weights about 167 lbs less. This makes quite a difference when you are moving the engine around from one place to another, trying to lift it onto an engine stand or calculate shipping costs.
Flywheel - 14.5 lbs.
Fan shroud + alternator - 24 lbs.
Muffler - 23 lbs.
Heat exchangers - 17-19 lbs.
Clutch - 2 lb. 3 oz.
Pressure Plate - 9 lbs.
Dual Solexes + manifolds - 15.5 lbs.
Engine tin - 20 lbs.
Distributor - 1 lb. 10 oz.
Engine support bar - 22 lbs.
Oil cooler - 2 lb. 2 oz.
Transmission:
002 transmission - 89 lbs.
Starter - 9.5 lbs.
'78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ
Put your trust in the law offices of Bentley, Muir, Haynes, and Wilson.
Rocknrod
Rocknrod is offline
PostPosted: Wed Dec 15, 2004 2:17 pm    Post subject: Reply with quote
Thanks guys!
Especially you Ratwell... You weighed all the accessories as well! Cool
obieoberstar
obieoberstar is offline
PostPosted: Wed Dec 15, 2004 8:22 pm    Post subject: Reply with quote
almost a year ago i bought a complete bus engine on ebay. it had everything from the air box to the tailpipe. all fuel injection components intact. i paid about $300 for the motor and another $200 to ship it. the motor was coming from boston, ma to tucson, az. the bill of lading said the weight was 390 lbs. this included the pallet.
hope this helps you out.
i used yellow freight (the complany with the orange logo????) and had to pick it up at the terminal here with a friend's pick-up. took about a week.
Rocknrod
Rocknrod is offline
PostPosted: Thu Dec 16, 2004 7:03 am    Post subject: Reply with quote
Cool thanks!
I'm thinking a pallet is normally 40lbs... but I'm not positive on that Cool
