Scooterboyd Samba Member
Joined: January 18, 2009 Posts: 342 Location: Rancho Cordova, California
Posted: Sat May 05, 2012 1:32 pm Post subject: |
Vintage Speed _________________ President of "Society of Unappreciated Overachievers"
62 - 23 Window Bus
60 - Karmann Ghia Convertible
59 - Convertible Raceable Baja Bug
63 - Dune Buggy
65 - Single Cab |
JohnnyRingo Samba Member
Joined: October 22, 2011 Posts: 415 Location: United States
Posted: Sat May 05, 2012 2:39 pm Post subject: |
dreadnotmusic wrote: |
donald.lemay wrote: |
Has anyone successfully use the vintage speed with a thermostat . Modify bracket cut rod whatever it took.
Thanks
Don |
No mods necessary at all. I installed the vintage speed and still use the thermostat. I chose to get the J-Tubes with slip joints rather than flanges so I can go back to heater boxes if I want. I bought industrial tins to close out the sides where the heater boxes were. I love this exhaust! JohnnyRingo Quote...Yea...I didnt choose this heater box style its not a true four into one.The exhaust I used was the vintagespeed non heater version...IT WILL NOT WORK W/GERMAN THERMOSTAT.
1600 single port with dual kadrons from Kaddie Shack. Coming back out today for a scat 36hp shroud.
Posted: Sat May 05, 2012 2:42 pm Post subject: |
JohnnyRingo wrote: |
Thanks
Don |
No mods necessary at all. I installed the vintage speed and still use the thermostat. I chose to get the J-Tubes with slip joints rather than flanges so I can go back to heater boxes if I want. I bought industrial tins to close out the sides where the heater boxes were. I love this exhaust! JohnnyRingo Quote.....Yea...I didnt choose this heater box style its not a true four into one w/equal length header,unlike the A1 sidewinder is!!!The exhaust I used was the vintagespeed non heater version...IT WILL NOT WORK W/GERMAN THERMOSTAT.
Snoop Bob Samba Member
Posted: Sat May 05, 2012 2:44 pm Post subject: |
That's http://www.thesamba.com/vw/forum/search.php?search..._chars=200 up to quote the guy and change the post to make it look like he said it. If you want to reply, post your comments under your own name (Your belief was clear in your above post). Maybe it was a mistake when you quoted and replied, just saying. _________________
BarryL wrote: |
Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
EverettB wrote: |
I would be interested in knowing the sizes of the various shafts. |
Posted: Sat May 05, 2012 2:48 pm Post subject: |
Ok...............dont need the vulgar language some 10 year old maybe trying to learn about VW's.................I was not trying to change the former guys message...dont know what I did..keep youre vulgar langauge to yourself this is a public website. |
dreadnotmusic Samba Member
Joined: March 04, 2003 Posts: 880 Location: Guam, USA
Posted: Sat May 05, 2012 3:47 pm Post subject: |
Given what's readily accessible on the internet these days, I'd consider a random F-Bomb pretty innocuous.
Johnny Ringo, please explain why you think it won't work with a German thermostat. For what it's worth, I find that it does. I have industrial tins that close out the sides where the heater boxes were. The 1/3 exhaust tubing does not route directly under the pushrod tubes. I have the J-Pipes. The thermostat opens and closes just as it always has. What's your take on it?
I'll take some pics once I get it all back together on Monday. _________________ 66 Riviera |
Posted: Sat May 05, 2012 5:43 pm Post subject: |
Easy there Fahrenheit 451.
EDIT---Taken under advisement and altered. I feel it WAS an appropriate vulgarity if intentional (dollar sign or other). Since your mess quote was unintentional, alterations were made with items available on this public site. _________________
BarryL wrote: |
EverettB wrote: |
Posted: Sat May 05, 2012 7:17 pm Post subject: |
I purchased the lowered vintagespeed non heater box version exhaust..........It will not work w/german thermostat........because it is a true length header and the 2/4 exhaust snakes back and forth under the push rod tubes. The heater version will work w/thermostat because its not a true length four into one header. Hope this helps.
Posted: Sat May 05, 2012 7:27 pm Post subject: |
That's precisely the reason I ordered the one with J-Tubes. I wanted to run my heater flaps and thermostat. It works great. _________________ 66 Riviera |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sat May 05, 2012 8:13 pm Post subject: |
I purchased the lowered vintagespeed non heater box version exhaust..........It will not work w/german thermostat........because it is a true length header and the 1/3 exhaust snakes back and forth under the push rod tubes. The heater version will work w/thermostat because its not a true length four into one header. Hope this helps. |
Yes, it does. There was no way to know that information otherwise. Thank you. _________________ nothing |
ldsvwguy Samba Member
Joined: September 16, 2003 Posts: 1020 Location: Saratoga Springs, UT
Posted: Sun May 06, 2012 11:40 am Post subject: |
My truck is not incredibly low, but I really do not want to have my exhaust hanging down too far. I'd really like to have a small hidden exhaust like stock, but be able to support my 1776 engine properly. I'm not a fan of quiet packs; dual or single. _________________ "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car." |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Mon May 07, 2012 5:43 am Post subject: |
Here's my $0.02. With a couple exceptions, I've run just about every exhaust you can think of as my bus has gotten progressively lower over the years.
For a stock motor, get a stock exhaust. Period. The couple extra hp you gain from getting an aftermarket exhaust isn't worth the headache of dragging the exhaust, the price of the exhaust, or the extra noise.
For a bigger motor, vintage speed gives the best ground clearance. I drug a hole through the muffler on my sidewinder (as well as bottomed it out on quite a number of speed bumps). The vintage speed exhaust is a much nicer setup, not to mention how much quieter it is! I had forgotten what it was like to have a conversation with somebody inside my bus when I was driving.
Don't even consider quiet packs (single or dual). You might as well cut holes in them with your sawz all before you put them on, because you're going to end up dragging holes in them as soon as you start driving around. _________________ -Andrew |
dirtylawnchair Samba Member
Joined: January 26, 2004 Posts: 1234 Location: Bradenton FL
Posted: Mon May 07, 2012 12:09 pm Post subject: |
We have 2 LOW busses that run the lowered vintage speed exhausts on 1600 DP with DRD heads dual Dells 36s and a few mods. Sound is amazing and quiet, not stock quiet but quieter than most aftermarket exhausts. The VS sits up very high. As I stated, the two buses are slammed and no scrapping.
No rear pics but here are the two.
Also, Pat (Type2man) of Wide5 in Miami runs his single cab with a 1776 with dual Dell 36s and a stock exhaust. No heat issues and he drives it everywhere like he stole it. Quiet as all hell. and no scrapping issues. _________________ Paulie
63 Standard OG paint |
Posted: Mon May 07, 2012 1:47 pm Post subject: |
dirtylawnchair wrote: |
Also, Pat (Type2man) of Wide5 in Miami runs his single cab with a 1776 with dual Dell 36s and a stock exhaust. No heat issues and he drives it everywhere like he stole it. Quiet as all hell. and no scrapping issues. |
How does he have that hooked up? is he running j tubes? _________________ "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car." |
Posted: Mon May 07, 2012 2:05 pm Post subject: |
Vintage speed stainless j tubes and industrial tins. Thermostat and flaps fully functional.
Posted: Tue May 08, 2012 6:34 am Post subject: |
ldsvwguy wrote: |
How does he have that hooked up? is he running j tubes? |
I would imagine Jtubes as there is no need for heat in south Florida...but I am not 100% sure. _________________ Paulie
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Tue May 08, 2012 6:57 am Post subject: |
ldsvwguy wrote: |
I think he meant no heat tranfer issues, or over heating issues....not heater.
gordo. |
rjonas Samba Member
Joined: July 24, 2004 Posts: 644 Location: Chandler, AZ
Posted: Tue May 08, 2012 10:14 am Post subject: |
That SS vintage exhaust looks sweet and has nice clearance but $$$$
I just bought this single tip GT muffler $65 to install with heat exchangers on a mild performance dual carb 1700cc.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D3487
Have not installed it on my 65 dlx yet or even seen one on a bus but I know I've seen the quad outlet GT style on a bus before...appears it will fit with a slight apron adjustment...???
Has anyone tried this single GT style on a bus? _________________ 1979 Type-2 Westfalia “Sandy”
1973 Type-181 Thing "Velma"
1956 Type-1 Beetle Patina Project “Rosie”
www.azbusclub.org |
donald.lemay Samba Member
Joined: March 01, 2009 Posts: 484 Location: Rhode Island
Posted: Tue May 08, 2012 12:53 pm Post subject: |
E-mailed vintage speed today with some questions. I can't believe how fast I received my answers. 12min
Here are answers for you:
Hi I have a couple of questions reguarding lowered style early bus exhaust with balanced tubes.
Can you run stock german thermostat and flaps. If not can it be modified quite easily.
A: This one 155-207-05200 or 155-207-052SF will fit with stock german thermostat and flaps.
Can you use one of the M18 ports for exhaust scavenging for my evacuation system.
A: Do you need positive pressure or negative pressure for evacuation system?
Now I need to build s special pipe for you. We build negative pressure pipe in 12mm or 16mm. |
smokeykombi Samba Member
Joined: October 02, 2006 Posts: 38 Location: Carson City Nevada
Posted: Sat Sep 22, 2012 4:26 pm Post subject: |
Is anyone running the vintage speed lowered bus exhaust on a press bumper bus with pics. I have a very low 58 press bumper bus and would like to se how it looks......thanks |
