H case query
Page: Previous  1, 2
wedgie
wedgie is offline
PostPosted: Fri May 25, 2012 1:20 pm    Post subject: Reply with quote
Thanks for that. What constitutes a 'competition valve job' please? (excuse my ignorance!)
Matthew
Matthew is offline
PostPosted: Sat May 26, 2012 5:33 am    Post subject: Reply with quote
Competition valve job would be multi angles cut on the valve seat and valve face. They range from 3 - 5 angles. Bill Fisher's book explains it pretty well. A google search for 3 angle valve job should yield some photos.
1965 Beetle sedan
Click to view image
wedgie
wedgie is offline
PostPosted: Tue May 29, 2012 12:11 am    Post subject: Reply with quote
Thanks for that, much appreciated!
chizucc
chizucc is offline
PostPosted: Wed Feb 27, 2013 11:33 am    Post subject: Reply with quote
Dangermouse wrote:
The advice I was given was that - The "evil" H cases are the `68/`69 H5 Type I (and their B5 bus-motor brethren, as well as the contemporary Type III cases). H0 (1967 1500 Type I and II) were not cast from the same cottage-cheese alloy, nor were any `70-up cases. The US-market engines had to meet tighter emissions specs which meant higher operating temperatures, and the less-dense alloy was employed in order to improve heat transfer through the case - turned out to be a very bad idea, the softer alloy was much more prone to cracking/warping and pulled head studs. For `70, the oiling system was improved, allowing the use of the stronger AS41 alloy.
In the US market there were no H1 cases. The last `67 case here was something like H0874199, then the H5 came in. But in other countries the H0 series continued until they ran out of numbers in mid`68 and went on from H1000000. My H1259065 is of late`69 vintage (non-US, obviously); the large oil passages and dual-relief setup indicate that it's comparable to the B6 1600SP sold in the US in 1970.
Has anyone seen a H0 case for a Type 3 before?
1964 Notchback
http://www.thesamba.com/vw/forum/viewtopic.php?t=543579
Page: Previous  1, 2
Page 2 of 2
