Anyone seen this before?
cmiller95
cmiller95 is offline
PostPosted: Tue May 29, 2012 10:51 am    Post subject: Anyone seen this before? Reply with quote
http://www.ebay.com/itm/1969-1972-VW-IRS-TYPE-1-AI...vi-content
Swing axle: Eating tires since 1938
My Rail Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=427627
My Baja Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466974
the2ndcashboy
the2ndcashboy is offline
PostPosted: Tue May 29, 2012 11:26 am    Post subject: Reply with quote
I tend to think you get what you pay for. That seems a little too easy. An LSD for 350$ would be freaking awesome though Razz
SRP1 wrote:
You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones.
modok wrote:
If anything comes out perfect it just means your measuring tools are substandard.
cmiller95
PostPosted: Tue May 29, 2012 11:31 am    Post subject: Reply with quote
i thought the same thing. on their website it says its not the whole differential its just the plates and springs that go into the factory differential.
Alstrup
Alstrup is offline
PostPosted: Tue May 29, 2012 11:35 am    Post subject: Reply with quote
I´m a complete transmission imbessile.
I cant "see it" How should they be installed ?
T
sullydog93
sullydog93 is offline
PostPosted: Tue May 29, 2012 11:36 am    Post subject: Reply with quote
I see the same price on their website.
Give it a try and report back.
cmiller95
PostPosted: Tue May 29, 2012 11:42 am    Post subject: Reply with quote
im not about to spend 350 on something that might not work haha. i just wondered if anyone has used one.
tncsparky
tncsparky is offline
PostPosted: Tue May 29, 2012 11:59 am    Post subject: Reply with quote
Maybe Bruce will give his two cents on this.
"My Daddy told me, son if your stupid today you will be stupid tomorrow"
scotth17
I think you are just waiting around for a high-five from a unicorn so you can feel better about yourself
Stripped66
Stripped66 is offline
PostPosted: Tue May 29, 2012 12:28 pm    Post subject: Reply with quote
All it appears to do is place pressure on the side-gears, limiting differentiation.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
the2ndcashboy
PostPosted: Tue May 29, 2012 1:10 pm    Post subject: Reply with quote
I did a little research (google is your friend) and apparently they kinda sorta work but they wear out the spider gears and pins very quickly if used on the street. There is some debate about whether they even work at all.
cmiller95
PostPosted: Tue May 29, 2012 1:38 pm    Post subject: Reply with quote
sounds a little too iffy to me.
mark tucker
mark tucker is offline
PostPosted: Tue May 29, 2012 2:41 pm    Post subject: Reply with quote
should not affect the spider gears but may be hard on the dif case at the axle gears from the pressure.if the case was machined for some clutches it would probably be better, but I see nothing rong with nthe kit other than the price for 4 spring& 2 locater plates should be between $60.00 & $88.37 retail. or just grab some out of a gm or mopar product.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue May 29, 2012 3:03 pm    Post subject: Reply with quote
One size fits all... too stupid.
Works on split case, swing axle, IRS and even New Beetle Rolling Eyes
Glenn
Member #1009
#BlueSquare
cmiller95
PostPosted: Wed May 30, 2012 8:33 am    Post subject: Reply with quote
they could have different models and just advertizing they have them for all of those. I think we might make one for our sandrail. like my dad said " machine two steel plates and buy 4 dye springs, we can do that."
mark tucker
PostPosted: Wed May 30, 2012 8:41 am    Post subject: Reply with quote
I would think they just found the size that fits in there,probably not realy made for a vw, but just replacement parts.but what is realy made for these things any way???nothing fits, so .....
Dale M.
Dale M. is offline
PostPosted: Wed May 30, 2012 9:40 am    Post subject: Reply with quote
I thought Limited Slip was spelled QUAIF (or similar spelling)...
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
mark tucker
PostPosted: Wed May 30, 2012 9:44 am    Post subject: Reply with quote
I thought qualif was speled TBSD, or thorson gleason.
a limited slip is a totaly different thing.it's clear in the front & see through in the rear. Shocked
ISPWEST_SAMBA
ISPWEST_SAMBA is offline
PostPosted: Fri Jun 01, 2012 8:34 pm    Post subject: Reply with quote
about a year an a half ago I had a NOS LSD for a 002 transmission it was very similar in design to that eBay listing , but complete so they did / do exist and work, from what I was told not as good as a clutch type or screw type LSD and did wear due to the heavy spring pressures
002 photos below...
http://www.thesamba.com/vw/classifieds/detail.php?id=1087734
View user's profile Send private message Visit poster's website Facebook Instagram Classifieds Feedback
Altema
Altema is offline
PostPosted: Sat Jun 02, 2012 6:02 am    Post subject: Reply with quote
Using your gears as friction surfaces? No thanks. A proper friction-based LSD with use clutch plates. Torsen or Peloquin diffs are good alternatives.
But... didn't VW off a factory limited slip diff at one time?
Paul
bumblebeecaz
bumblebeecaz is offline
PostPosted: Sat Jun 02, 2012 7:01 am    Post subject: Reply with quote
i think it was a ZF diff that was used factory at one time
mark tucker
PostPosted: Sat Jun 02, 2012 8:07 am    Post subject: Reply with quote
ive got a swing superdiff I was goint to add clutches & irs out put shafts to and use it as an irs, and the screw in sides can be used for preload& set the torque breakway.just havent goten to it yet.
