where to find TPS for 1.9L 1985
mrhooie
mrhooie is offline
PostPosted: Sun Jun 03, 2012 8:08 pm    Post subject: where to find TPS for 1.9L 1985 Reply with quote
I purchased a TPS kit from Van Cafe a few years ago and after screwing around with it on and off I finally got it to work and my 1985 1.9L ran really well for about 15 minutes. While rounding the corner to come back home, the idle started to hunt again.
I had a look at the throttle and couldn't hear the switch click at idle or full throttle. I grabbed my multimeter and tried to adjust the TPS to no avail so i removed the throttle body to find the switch was now failed (no clicking)
Now i did have to adjust the spring steel to allow the TPS cam to hit the switch (i bent it out so the cam would hit the spring steel and activate the switch)
I can't find one anywhere except Van Cafe's new version which I will order tomorrow, just wondering if anyone had any thoughts?
85 Westy 1.9l h2o - the Winder mk II
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun Jun 03, 2012 8:33 pm    Post subject: Reply with quote
You mean you bent the arm on the switch because it wasn't hitting the cam--right?
If you had to bend the arm to have it open & close on your Cam--the cam was an earlier 1.9 TPS cam--and is too small for the switch that you ordered.
There is an earlier cam & switch, and a later 1.9 cam & switch.
The earlier one has a real small cam--and I can see what you did to get the switch to ride on it to open & close.
You probably broke the switch bending the arm.
T.K.
mrhooie
mrhooie is offline
PostPosted: Sun Jun 03, 2012 10:28 pm    Post subject: Reply with quote
which is odd Terry as I ordered the cam and switch as a kit from Van Cafe
also, i measured the cam to get an idea if i could order the new part ffrom Van Cafe that they have and my cam is 17mm (ruler, not digital)
Terry Kay
Banned
PostPosted: Sun Jun 03, 2012 10:34 pm    Post subject: Reply with quote
How long ago?
And you did have to bend the switch arm to get it to ride on the cam--right?
Early switch plate--big difference.
VW went from 2 switches, to one switch ( smaller sized cam & different switch,) then the later one--same as the 2.1 TPS with a different switch & cam--all bigger.
T.K.
mrhooie
mrhooie is offline
PostPosted: Sun Jun 03, 2012 10:48 pm    Post subject: Reply with quote
it would be 2 years ago. i had ordered http://www.van-cafe.com/home/van/page_159 and don't believe that i remounted these on the mounting plate that it came as one kit, i reused the allen bolts
it replaced a one switch tps. you're thinking that the original one was smaller and that affected the new kit i replaced it with?
thoughts going forward? if i buy their new kit, will i run into the same issue?
Terry Kay
Banned
PostPosted: Mon Jun 04, 2012 5:04 am    Post subject: Reply with quote
"So as long as you have a 86 to 91 this one should fit"
Did you read that in the newer style switches descripton?
Sounds to me like you might have an earlier, smaller cammed switch which a replacement is still in the works.
If this be the case, & your in a hurry, find yourself a later model Thottle Body & bolt that on.
Case Closed.
Problem solved.
That's what I'm thinking.
T.K.
mrhooie
mrhooie is offline
PostPosted: Mon Jun 04, 2012 6:06 am    Post subject: Reply with quote
ok, thanks Terry.
The throttle body is the biggest player in this? meaning that if i had an earlier throttle body, the later kit wouldn't have worked?
appreciate your time!
Hughie
