splitpartsunlimited Samba Member
Joined: January 18, 2006 Posts: 1251 Location: Good Ol`Buenos Aires, Argentina
Posted: Mon Jun 04, 2012 3:59 pm Post subject: Split Fuel Tap Rubber Piece |
Hi Guys!
after months of not driving my split , i have decided to completely service it so i have started removing the gas tank for old gas and rust removal .....
once i have removed the fuel tap , i have found that it was completely unuseable , no gas passed through it .
once i have disassembled it , i have found that it has a rubber piece inside , that was completely worn and out of shape .......
anyone knows a source for that rubber piece ??
the fuel tap is an almost NOS split unit with the 8mm pipe ....
any help will be greatly appreciated !
thank you
Ricardo _________________ in my Garage:
1951 crotch cooler split
1971 1302 cabriolet
1981 Mercedes Benz 230 military "Gelandewagen"
2010 Mercedes Benz c200 kompressor touring |
xeno Samba Member
Posted: Mon Jun 04, 2012 4:04 pm Post subject: |
VW used a few different ones. Do you have a photo of yours? _________________ Currenlty Corralled:
1952 Crotch Cooler Deluxe (US specs delivered to Stuttgart, Germany GI.)
1955 Early (Competition Motors - Hollywood, California)
1974 Thing (US specs - Mexicanos)
2008 Rabbit S (Wolfsburg DE)
2012 Golf TDI Tech Package (Wolfsburg DE) |
Posted: Mon Jun 04, 2012 4:14 pm Post subject: |
well , i can get a pic of the complete unit ....the rubber seems to be a round piece with some holes in it _________________ in my Garage:
1971 1302 cabriolet
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Mon Jun 04, 2012 4:42 pm Post subject: |
I have that rubber disc for the early taps. See zarwerks.com. Got any ribbed semaphore arms????
_________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Mon Jun 04, 2012 5:03 pm Post subject: |
What is the washer for ? _________________ in my Garage:
1971 1302 cabriolet
splitjunkie Samba Member
Posted: Mon Jun 04, 2012 5:11 pm Post subject: |
It's for the cup. _________________ Chris
Posted: Mon Jun 04, 2012 5:37 pm Post subject: |
got it !! mine was perfect and not leaking . that`s why i didn`t even notice that it existed ... _________________ in my Garage:
1971 1302 cabriolet
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Tue Jun 05, 2012 7:13 am Post subject: |
johnshenry wrote: |
What rubber nowadays will work for this application? With various amounts of ethanol in the fuel these days, what rubber will withstand being immersed in fuel all the time?
Recommendations? |
Posted: Tue Jun 05, 2012 7:28 am Post subject: |
That's a good question.
I once made one by using the old gasket as a pattern. I cut the holes using appropriately sized brass tubing that I had sharpened the ends. I put it in my drill press (without it running) and punched the holes.
I just used a large rubber washer I bought at the hardware store. Everything worked fine but when I eventually took the tap apart the rubber had swollen. _________________ Chris
Posted: Tue Jun 05, 2012 7:55 am Post subject: |
I tested these rubber discs thoroughly before plunking down way more money that I will probably ever make selling them (the tooling costs were high). I soaked them in gasoline for nearly a week and checked for swelling. It was under 5% IIRC. And it really is not that much of an issue (5%) as the disc is entirely captive in the seal on all sides.
Buna-N rubber was used I think, known for its petroleum product and oil resistance. It is the same rubber that is used in rubber fuel line hose. _________________ John Henry
'57 Deluxe
'56 Single Cab |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Tue Jun 05, 2012 11:17 am Post subject: |
maybe the rubber piece transmuted to a cork type material after 60 years .....
mine was never touched and it was rubber , rotten rubber
1971 1302 cabriolet
Posted: Tue Jun 05, 2012 11:59 am Post subject: |
I think I remember seeing some cork ones at one point long ago. But I really don't see that working well at all.
I have a few NOS ones. Old black rubber, as stiff as plastic now... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Jun 05, 2012 1:07 pm Post subject: |
The one in my '60 was cork. _________________ Chris
xeno Samba Member
Posted: Tue Jun 05, 2012 10:48 pm Post subject: |
If you make your own, VITON gasket material is the way to go. It is impervious to gas/oil/diesel/gas additives and does not swell. _________________ Currenlty Corralled:
Posted: Wed Jun 06, 2012 3:05 am Post subject: |
what is the thickness of that seal ?? i have removed the one i have here , but it came out in pieces _________________ in my Garage:
1971 1302 cabriolet
Posted: Wed Jun 06, 2012 7:33 am Post subject: |
splitpartsunlimited wrote: |
what is the thickness of that seal ?? i have removed the one i have here , but it came out in pieces |
Should be about 3mm |
Posted: Wed Jun 06, 2012 2:20 pm Post subject: |
thank you Nancy !! now i know how much i have to thread the retainer in
1971 1302 cabriolet
