Bman Samba Member
Joined: April 28, 2005 Posts: 895 Location: South Coast, Oregon
Posted: Tue Jun 12, 2012 1:57 pm Post subject: Name This Part (engines, body, misc.) |
Don't know if anyone will find this valuable or not, but as I begin to fiddle and diagnose my own Vanagon troubles I sometimes come accross parts that I have no idea who, what or why they are. The Bentely may show it, but its not labeled; I'll see it listed under a half dozen names in the classifieds, and usually even my local VW mechanic is stumped. Nevertheless the Samba is a rich source of experience and it is threads like these that get me good and "learned."
So, perhaps this thread could be of use for those in similar situtations, perhaps even a "sticky?"
This past weekend I was once again tinkering with my 89 2.1L tintop, cleaning up the FI parts from an earlier tranny oil cooler fail (oil in the coolant) when I pulled the following sensor off of the intake boot. This sensor sits between the oil/case tower hose and the intake boot to the throttle body. It showed the oil/water deposits of my latest problem and a whole bunch of other gunk; it was not until I pulled a clean one off my spare 2.1L that I noticed that the interior of this hose adaptor has a copper shield that receives a current. What is it for, what do you call it and how does it work?
Terry Kay in his ad ( http://www.thesamba.com/vw/classifieds/detail.php?id=302892 ) calls it a vent line heating element. What does it heat the pressured air from the case?
I already replaced this one with a cleaner one, but I would still like to know what this component is. Thanks in advance. _________________ ~Bryan
1990 Burgandy Tintop (Wife's Daily Driver)
1989 Tiico Westfalia "Taj"
2WD Doka build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=503578&highlight=
FaceHook:
https://www.facebook.com/pages/VW-T3-DokaSinka/129026087217120?ref=hl |
gl98115 Samba Member
Joined: April 22, 2011 Posts: 263 Location: Seattle, WA
randywebb Samba Member
Posted: Tue Jun 12, 2012 2:10 pm Post subject: |
that looks like the gizmo in the oil breather line that heats up the oil vapor _________________ 1986 2.1L Westy 2wd Auto Trans. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Tue Jun 12, 2012 2:15 pm Post subject: |
Vent Line Heating Element (Canadian vehicles only)
A heating element is used on the crankcase vent line to prevent icing during cold engine operation. This element can be checked with an ohmmeter. The circuitry to operate the heating element is protected by an in-line 5A fuse, located in the wiring connector box in the engine compartment. _________________ 89 Westy 2.1 Auto |
ok, here is mine -- a new entry
You are lying underneath the 2.1L motor Van on the LH side at the rear ahead of the engine and look up. The big tube in front of your face is an exhaust header.
You see this:
The blue plastic thing to the right in the pic (outboard LH side of the Van) is the Temp II (aka, Temp 2) sensor, which is a common replacement item for keeping the Digifunky Digfant system happy.
Now, name the other sensor with the black rubber boot on it that is towards the front of the pic ... _________________ 1986 2.1L Westy 2wd Auto Trans. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10476 Location: Orbiting San Diego
Posted: Tue Jun 12, 2012 2:31 pm Post subject: |
Temp sender for dash temp gauge. I call it Temp3, since Temp1 and Temp2 are already taken by the Fuel Injection system.
Mark
| randywebb wrote: |
Now, name the other sensor with the black rubber boot on it that is towards the front of the pic ... |
Bman Samba Member
Posted: Wed Jun 13, 2012 3:22 pm Post subject: |
Here is a view of the top of an automatic trans. equipped 1986 Van, take by looking forward from the engine compartment just under the firewall.
Is it labelled correctly?
Also, if that is a gnd. then where does it go?
Posted: Wed Jun 13, 2012 3:45 pm Post subject: |
If that "ground" wire is a curved piece of steel it is a support for a hose that goes across the top of the tranny on some models.
Mark
| randywebb wrote: |
Posted: Wed Jun 13, 2012 4:05 pm Post subject: |
Thx Mark - that must be it. _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Wed Jun 13, 2012 4:08 pm Post subject: |
Here is another pic - brown wire but cannot be a ground, as it is on a sensor
is it an oil pressure sensor? if so, which one?
86 Westy Samba Member
Posted: Thu Jun 14, 2012 12:43 pm Post subject: |
| looks like the 0.8 bar pressure sensor for over 2000 RPMs? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8523 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Jun 14, 2012 6:33 pm Post subject: |
Bentley 17.7: "0.9 bar (13.1 psi) oil pressure switch (from 1986)"
Ummm...how is it you're not finding this stuff in your Bentley...??? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Jun 14, 2012 7:05 pm Post subject: |
| randywebb wrote: |
VW often used brown wires with white stripes for switched grounds. Why they went with plain brown wires in this instance is a mystery. Forward of the connector in the engine compartment the wires have different colors.
I have always considered this small harness to be pretty shoddy. VW should have used special wire that could handle high temps and/or should have shielded the wire well. |
Posted: Thu Jun 14, 2012 9:40 pm Post subject: |
| dhaavers wrote: |
Ummm...how is it you're not finding this stuff in your Bentley...??? |
First, thanks for posting your info.
I thought the idea of this forum was to help people with their Vans, and the idea of this thread was to help people ID parts on their Vans (?), which is not particularly well done by the Bentley manual, even in B&W.
Wildthings - VW is the low buck car manf. in Germany - even the high buck manfs. began a series of cost (and quality) cutting measures in the 1980s, so... _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Thu Jun 14, 2012 10:22 pm Post subject: |
| randywebb wrote: |
| Wildthings - VW is the low buck car manf. in Germany - even the high buck manfs. began a series of cost (and quality) cutting measures in the 1980s, so... |
Yeah, but the most effective cost cutting measure was to reduce warranty cost. This part didn't help there. |
Posted: Thu Jun 14, 2012 10:43 pm Post subject: |
| randywebb wrote: |
| ...the idea of this thread was to help people ID parts on their Vans... |
I get it - you're covering everything the Bentley doesn't.
So far, so good...only 1,042 pages to go...
"The WonderVan"
Jeff's Old Volks Home Samba Member
Joined: December 19, 2011 Posts: 819 Location: Chester Basin, Nova Scotia
Posted: Fri Jun 15, 2012 8:16 am Post subject: |
This seems to be a great game! I'm assuming it's a drill to see who knows their Vanagon and Bentley the best... Is there going to be a prize? or if I stump everyone do I get a prize?
Jeff |
Posted: Fri Jun 15, 2012 1:55 pm Post subject: |
| dhaavers wrote: |
| randywebb wrote: |
The Bentley is simply not organized in terms of "get familiar with the mechanical parts on your vehicle" -- and BTW the Vanagon Bentley is the worst one I've seen.
I don't have to do this -- it seems more valuable than "look at the butt end of everyone's van" _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Fri Jun 15, 2012 4:59 pm Post subject: |
Sorry - no disrespect...I totally agree re: Bentley.
IMO, & knowing how the "search" function works around here, I feel it's probably better to wait for someone
to ask a specific question rather than try to cram every possible answer into a single helpful(?) thread.
But...go for it.
Peace out. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
