jdledingham Samba Member
Posted: Sat Jun 30, 2012 12:23 pm Post subject: Identify Engine bolt |
This is my fist post. I have 4 books on the engine I am working on and have searched the web. In parts blowout pictures the bolt I am looking at is omitted.
Anyway:
I have a stripped bolt that is stuck it is on a type 2 2L '77 engine. It is resessed between two of the push rod tubes. Size 14mm.
Can someone tell me what this is for, and have any suggestions? |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Sat Jun 30, 2012 1:29 pm Post subject: |
You may have more of a problem than you think. If it is a longish 8mm bolt (13mm head size) that runs across the block directly above the oil pickup screen, you may well have cracked the block by over tightening the nut the holes the pickup screen cover on. This may require having your engine torn down and having the block either welded up or replaced.
There are several threads on this on the Baywindow Forum. |
Posted: Sun Jul 01, 2012 7:35 pm Post subject: |
That sounds like it. it is actually 13mmand directly above the strainer. I found this semi strpped bolt behind some permatex. It wasnt completly stripped until I got ahold of it.
I am not familiar with type 2 engines. I also noticed the previous owners have a bolt that runs down through the strainer and protrudes past the cover plate by about 1cm, definatly does not look like a stock vw setup.
Any insight? should I just start looking for a new case or longblock? |
Posted: Sun Jul 01, 2012 7:46 pm Post subject: |
I have toyed with the idea of drilling right through the other side of the block and then using a longer bolt and a nut. You would have to build up the area with JB Weld to create a flat surface for the nut to tighten against, but that would be easy enough to do. Don't know why VW built the engine this way to start with and why they never corrected their error. This easily correctable flaw persisted for the 15 year run of the T4 engine??? |
