No engine code numbers on case?!
MadMax78
MadMax78 is offline
PostPosted: Sun Feb 03, 2008 5:24 pm    Post subject: No engine code numbers on case?! Reply with quote
When I was inspecting my engine today I noticed something weird for the first time. My case only has two engine code letters on it, no numbers.
Does anybody know why? Have you ever seen cases without numbers?
1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member
busdaddy
busdaddy is offline
PostPosted: Sun Feb 03, 2008 5:52 pm    Post subject: Reply with quote
It's a VW remanufactured engine, see the little logo with the arrows circling it ahead of the letters? The # was usually on a gold sticker beside that.
Must have been pretty bad if they had to use a new case, most of the ones I've been inside looked like they recycled anything that was even close to limits.
Слава Україні!
donemoto
donemoto is offline
PostPosted: Sun Feb 03, 2008 5:54 pm    Post subject: Reply with quote
Looking at the pic; it looks like there is some weld splatter and perosity from a weld repair near and over the boss. PO sanded it down to restamp and didn't for some reason.
Every picture tells a story don't it?
1975 Campmobile
1962 Bug Convertible
Homebuilt VW Trike
1966 HD Sprint H
1940 HD ULH Flathead
1985 Electra-glide Classic with Tour-Pac
1968 Harley Rapido
1968 Honda CL Scrambler 175cc
1962 Honda Cub 50 Step-thru
1980 Honda Cub 70
germansupplyscott
germansupplyscott is offline
PostPosted: Mon Feb 04, 2008 6:03 am    Post subject: Reply with quote
like busdaddy said, that has nothing to do with a PO, it is VW remanufacturing that removed the SN.
SL
donemoto
donemoto is offline
PostPosted: Mon Feb 04, 2008 7:35 am    Post subject: Reply with quote
Take another look at that stamp boss. It may be a reman..but that boss has definately been filled in by PO or case repairerl. Yes most reman cases had a pop riveted yellow gold tag on them. But, again, those numbers were definately filled in with weld. Seen alot of early Harley cases in my day with same kind of crapmanship weld on stamp bosses to change ID numbers.
1975 Campmobile
Homebuilt VW Trike
1966 HD Sprint H
1968 Harley Rapido
1980 Honda Cub 70
MadMax78
MadMax78 is offline
PostPosted: Mon Feb 04, 2008 8:55 am    Post subject: Reply with quote
Allright, that clears things up, thanks for the replies Cool
Blaubus
Blaubus is offline
PostPosted: Mon Feb 04, 2008 9:14 am    Post subject: Reply with quote
whether or not the factory welds these shrouds, i have to wonder where you think the PO got the factory reman stamping tool! Rolling Eyes
donemoto
donemoto is offline
PostPosted: Mon Feb 04, 2008 9:55 am    Post subject: Reply with quote
My guess is someone took the tag off. Probably the case was stamped GE to identify before number plate was added. Guess this post is beat to death now. Wink
1975 Campmobile
Homebuilt VW Trike
1966 HD Sprint H
1968 Harley Rapido
1980 Honda Cub 70
Blaubus
Blaubus is offline
PostPosted: Mon Feb 04, 2008 10:05 am    Post subject: Reply with quote
yes it is typical of the factory to stamp their reman logo, then put two letters down. on early cases they would mill off the numbers first, but would not plate it.
so, i guess you are saying it was stamped before and welded later? OK...
ajdc78
ajdc78 is offline
PostPosted: Fri Jul 06, 2012 10:21 am    Post subject: Engine Block Has No Marking Reply with quote
I noticed this thread about reman engines and the markings.
I just bought this Buggy with a '69 pan but the engine doesn't have a marking where it should. I don't think that it is the original engine because it had about half 6v and half 12V parts on it. Is there another way to identify the engine?
The block is stamped elsewhere "113.101.102 B 17"
I have a few pics but no idea how to post them here.
