kirkvw72 Samba Member
Joined: March 27, 2006 Posts: 272 Location: Hoffman Estates, Illinois
Posted: Fri Jul 06, 2012 3:20 pm Post subject: 102 Degrees in Chicagoland! A/C on full blast. |
Third day of 100+ degree heat here in Chicagoland. Today was the first day that I've ever had the van click over to the full 747 jet engine cooling fan mode where the fan goes to its fastest setting and the AC compressor turns off. AC was on full blast (recharged recently and working very well!), I just came off the highway after about a 10 mile drive, turned on to to road that leads up to my subdivision which has a slight grade, shifted to 4th, continued to accelerate, and then the fan switched over. Everything worked properly, which is a relief. The van came out of that mode after the hill, AC came back on - probably was a minute of total time. Temp gauge never went passed the LED.
I'm guessing this would be a common occurrence for those of you out west during the summer? _________________ 2015 VW GTi Autobahn
2000 Mercedes Benz E430
1992 Miata, automatic converted to a 5-speed
1988 Vanagon Wolfsburg
1987 Porsche 944 (951) Turbo
1987 Vanagon GL, Rocky Jennings Heads, RMW Exhaust, ASL 5-speed, AMG Wheels
1981 Porsche 924 (931) Turbo
1972 Beetle (standard) |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Fri Jul 06, 2012 3:28 pm Post subject: |
We/ve been having 34 to 36 degree and I've had to use my Cold Start Cable to start my diesel each morning and if it's sat all day! Glad I learned that the "Cold" doesn't refer to atmospheric temp!!!! I actually chuckle each time I have to pulll it on! We get some breeze off Lake Ontario most of the time but the sun has been brutal! _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
devesvws Samba Member
Joined: January 05, 2004 Posts: 1540 Location: madison va
Skip Laubach Samba Member
Joined: December 13, 2011 Posts: 237 Location: Elgin, Illinois
Posted: Fri Jul 06, 2012 5:51 pm Post subject: |
Now that it's dropped to 90.4 degrees F, I think I'll take my "ambient air-cooled cabin" '84 WBXR out for a spin.
(just west of Kirkvw74, outside of Elgin, IL) _________________ Skip
1984 Westy 1.9 case WBXR Manual (now with 2200cc GoWesty kit)
Since 26 July 2011 |
kamzcab86 Samba Moderator
Posted: Fri Jul 06, 2012 6:00 pm Post subject: Re: 102 Degrees in Chicagoland! A/C on full blast. |
kirkvw72 wrote: |
I'm guessing this would be a common occurrence for those of you out west during the summer? |
No, actually... at least for mine. Had the A/C recharged last summer (has since lost its charge due to a leak) and it never shut off to run the fan at jet engine speed. I hear the fan turn on all the time (and, to me, it's loud), particularly while idling, but I don't know if that's hi-speed; I need to jump it one of these days so I know what each speed sounds like. _________________ ~Kamz
2016 Golf GTI S
Terry Kay Banned
Posted: Fri Jul 06, 2012 9:52 pm Post subject: |
Hold On To Your Shorts & Crank That AC on again tomorrow--see how it works at 105 degree's--
Unbelieveable--- _________________ T.K. |
debbiej Samba Member
Joined: December 14, 2008 Posts: 1556 Location: las cruces, nm
Posted: Fri Jul 06, 2012 10:09 pm Post subject: |
we often see temps of 105, yes. but seldom with humidity. now that everything is working properly on my van; radiator, thermostat, closed coolant system and radiator fans/ac load, my van runs cooler with ac on.
I don't get the jet engine fan often.
I haven't heard the highest speed since new radiator. but it's there for a reason!! |
Terry Kay Banned
Posted: Fri Jul 06, 2012 10:15 pm Post subject: |
In NM sure---
Not here--Phooey---keep the heat. _________________ T.K. |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Sat Jul 07, 2012 1:35 am Post subject: |
Oh, you'll know it when you hit stage 3 on the fan... it sounds uncannnily like a Cessna 172 on takeoff roll.
I'm pretty sure it will pull the van forward on a level surface...
Back on topic, I found this at Home Depot for about $8...
Position a big fan behind it, and even in humidity, it's pure bliss. _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sat Jul 07, 2012 6:56 am Post subject: |
debbiej wrote: |
...I haven't heard the highest speed since new radiator. but it's there for a reason!! |
Our 84s came with a 2-speed fan with a noticeable but modest high speed. If your fan is still stock you won't get the same experience.
I went with a later 3-speed fan & shroud when I upgraded the A/C and it does come on after a lot of stop & go 100+° traffic. The comparison to a Cessna on a take-off roll is apt. |
Posted: Sat Jul 07, 2012 7:07 am Post subject: |
I noticed the spare tire is quite the block for the air flow off the radiator (replaced the original spare with a new tire). With the spare tire out of the way, the air coming through there is moving!
In terms of the highest speed for the cooling fan, you not only hear the difference, but the AC compressor shuts off as well. _________________ 2015 VW GTi Autobahn
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Sat Jul 07, 2012 8:01 am Post subject: Re: 102 Degrees in Chicagoland! A/C on full blast. |
kirkvw72 wrote: |
The high speed fan can kick on when it is very hot outside..and the coolant gauge is still reading in the normal range. Your cooling system is fine and is working as designed.
The heat from the front A/C condenser (in front of the radiator) will be hot enough to heat-soak the radiator thermo switch and kick in the high speed fan. That front condenser will get very warm when we have high outside ambient temperatures and/or humidity.
Zeitgeist 13 Samba Member
Posted: Sat Jul 07, 2012 10:45 am Post subject: |
Looking at that map, I really appreciate living in ever so temperate Cascadia. I run my AC anytime it's above 65F
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
DAIZEE Samba Member
Posted: Sat Jul 07, 2012 10:58 am Post subject: |
Neat map. California is the coolest. That's a surprise! Thanks for an overall pic. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Jul 08, 2012 11:16 am Post subject: |
You can cool the radiator with a canvas/flax water bag secured over the front of the bus. The evaporation cools the bag and makes for a good supply of emergency drinking water too.
Old Route 66 travel tip. |
Posted: Mon Jul 09, 2012 1:09 pm Post subject: Re: 102 Degrees in Chicagoland! A/C on full blast. |
AtlasShrugged wrote: |
kirkvw72 wrote: |
such as mine _________________ THE FEW THE PROUD THE ORIGINAL VW WATERBOXER -> looking for a original 91 vanagon owners manual with 1991 on the cover http://www.youtube.com/watch?v=pmuiG2tUsP4&feature=share https://picasaweb.google.com/101290228103300323836/BostonBobFlywheelVideo#5543000332201103922 |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Mon Jul 09, 2012 1:24 pm Post subject: |
DAIZEE wrote: |
Neat map. California is the coolest. That's a surprise! |
I take it you've never been to San Francisco in the summer time?
Our home thermostat tripped the heater this morning.
Inland heat + Pacific Ocean = one tremendous heat sink --> and the famous coastal fog of the west coast. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
DAIZEE Samba Member
Posted: Mon Jul 09, 2012 1:41 pm Post subject: |
I don' remember what time of year I was in San Fran but BART was definitely not working. mm maybe winter as I went skiing at Tahoe before going to LA. Liked San Francisco very much regardless. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Mon Jul 09, 2012 3:20 pm Post subject: |
j_dirge wrote: |
Inland heat + Pacific Ocean = one tremendous heat sink --> and the famous coastal fog of the west coast. |
"The coldest winter I ever spent was a summer in San Francisco." _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
