drivenachodrive Samba Member
Posted: Wed Aug 01, 2012 8:22 am Post subject: Starter wiring - need help identifying wires |
Someone took my transmission out of my van here in Colombia without my permission. Full details to follow on our next blog post - don't get me started! Anyway, the guy took my starter out and left all of the wires hanging there. I have no idea where they all go now, and need help identifying them. I've replaced the starter and starter solenoid at the same time.
I've included 2 pictures below. One is the starter and solenoid with all connections labeled. The next is the array of wires left hanging in the engine compartment. Can you tell me which wires go to which connectors?
Thanks in advance!
_________________ Driving around the world in a 1984 VW Vanagon
www.drivenachodrive.com
Read our book: www.drivenachodrive.com/book |
ShultzRoadHouse Samba Member
Joined: March 28, 2011 Posts: 318 Location: Caldwell, ID
Posted: Wed Aug 01, 2012 9:11 am Post subject: |
This is from my '82 hope it helps...
_________________ ShultzRoadHouse
'81 AirCooled Westy RIP
'82 Westy w/ '93 Subaru EJ22
'71 Super Beetle w/ '75 AJ 1600
'12 Jetta |
gelPsy Samba Member
Joined: January 10, 2011 Posts: 44 Location: Berlin, Germany
Posted: Wed Aug 01, 2012 9:18 am Post subject: |
What is that extra soleonid for?! Usually the big Ring with the rubber cap on the second pictiure screws directly in to the starter - that's the main + current supply, minus will come via the engine block/ bell housing. The single female in the second picture will clip in one of the male pins on the starter and finito. All the rest is not needed. IF the wiring of your van is stock. If someone has tinkered with it, it might be different. You dont need the extra solenid as the starter it self is equipped with one (the smaller "ton" on the starter). Maybe this was broken and that's why someone added an extra external solenid insteead of replacing/repairing the standard one on the starter? Who knows..... )
Have fun,
.martin, waiting for girlfriend with crown wheel _________________ tiger2asia 2011/12 - http://log.tigerbus.de/reisen/tiger2asia-201112/
14", 1.9 TDi, V2A exhaust/DPF, 2 difflocks, decoupler, 30x9.5R15, ATE57/Lucas38 conversion, Weinsberg poptop, RAL1028 |
vwnewtons75 Samba Member
Joined: October 22, 2009 Posts: 4 Location: Walla Walla, Washington
Posted: Wed Aug 01, 2012 9:22 am Post subject: |
The second picture... wire number 2 and 4 go to the main lead of the starter, the smaller wire is the start signal lead. I agree with Tigerbus about the solenoid not being needed unless something is wrong with the ignition switch or wiring, or the starter itself. Good luck!
Jason Newton, ASE Master and Adv level VW tech. |
gelPsy Samba Member
Posted: Wed Aug 01, 2012 9:30 am Post subject: |
The ground in the second pictire..... Check whethr you really have a ground cable from the body to the gearbox and/or the engine block! Very important. If you don't have, add one or more. The one dangling there might be THE one that should be screwed to the gearbox or the engine block. Then the starter will draw its ground directly via its housing. Got it? All the rest is crap and can be trown out. You might check with a multimter or simply a 12V bulb whther you get power on that small female pin in the 2nd picture while your girlfriend is turning the key as if she wanted to start. If yes, you can connect that directly to the soleoid on the starter, without the big round clamp with the rubber cap. The let her start again, you should hear the soleroid on the starter clicking. If that works, connect the big power and all should be fine.
Ciao,
.martin _________________ tiger2asia 2011/12 - http://log.tigerbus.de/reisen/tiger2asia-201112/
cmorris Samba Member
Joined: May 13, 2012 Posts: 18 Location: Salt Lake City, UT
Posted: Wed Aug 01, 2012 9:48 am Post subject: |
I have seen tons of these solenoids on old air-cooled beetles and what not. It is supposed to overcome the solenoid not engaging reliably due to voltage loss from the old wiring and starter switch.
Likely the PO had starter problems at some point and decided to add the solenoid thinking it would solve his woes. However, I agree with the others who have posted and do not believe adding the solenoid is right approach to solving a starter problem in a Vanagon.
-Chad |
Destructo Samba Member
Joined: July 31, 2006 Posts: 405 Location: Westhampton, MA
Posted: Wed Aug 01, 2012 9:57 am Post subject: |
So it looks like you have a "Hot Start Relay" which makes things all confused. Unless you are having issues with starting while hot, I would toss it in a "to be used later" bin. With that said
Connect 1 female connector to G Male spade on starter
Connect 2 and 4 ring connectors to E post on starter
As for what you have labeled as "3 connector ring ground", Confirm that it is a ground connected to the frame of the van. If so, there should be a bolt on the driver side of your transmission that this connects to. However, if it leads to the alternator or junction box in the engine compartment, then it also has to be connected to E post on starter.
Heres another way of looking at it. 1 wire will lead to your battery and should be connected to the post on the starter. 1 wire will lead to your alternator and should be connected to the post on the starter. 1 wire will lead to your junction box in the engine compartment and should be connected to the post on the starter. The last is is the female connector, there is only 1 male spade this can fit on and I believe this wire leads to your ignition. Hope this clears it up and if you do want to hook up your hot start relay you may have to see if someone else chimes in. I had one and I took it out to make things easier.
Eddie in Phoenix. _________________ 1985 Wolfsburg Edition Westfalia Camper Bostig conversion
Dude, where's your van? |
Posted: Wed Aug 01, 2012 4:46 pm Post subject: |
Thanks all!
I went ahead and removed the auxiliary solenoid (put it away for future projects) and wired it up as suggested. It fired up on the first crank, so thanks for the good advice!
Nacho's going back together nicely - we'll be scaring children and running over pets in no time flat! _________________ Driving around the world in a 1984 VW Vanagon
nunzio82 Samba Member
Joined: April 05, 2019 Posts: 14 Location: Los Angeles
Posted: Fri Apr 03, 2020 1:12 pm Post subject: Re: Starter wiring - need help identifying wires |
Anyone know what the small blue wire with female spade is for? Its the one next to the large red wire with black stripe.
ShultzRoadHouse photo shows it very well. I have one but its been cut. My van runs very well without it but wanted to know what it was used for.
Thank you _________________ 1982 Westfalia camper vanagon air-cooled |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Fri Apr 03, 2020 2:39 pm Post subject: Re: Starter wiring - need help identifying wires |
nunzio82 wrote: |
Thank you |
It might be part of the old diagnostics system that goes to a big plug in the engine compartment
VW would plug into that plug and read out problems to a “ computer” _________________ .ssS! |
