tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Wed Aug 01, 2012 1:34 pm Post subject: |
On a related note, I accidentally ripped my ancient water supply hose to the onboard tank when I was replacing the outside receptacles. It looks like the cabinets would need to be pulled to replace that hose, no?
Anyone have a source for replacing the blue hose? I haven't been able to find it from the usual suppliers. _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16474 Location: Brookeville, MD
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6235 Location: Portland OR
Posted: Wed Aug 01, 2012 1:55 pm Post subject: |
tarandusVDub wrote: |
Anyone have a source for replacing the blue hose? I haven't been able to find it from the usual suppliers. |
GoWesty
http://www.gowesty.com/ec_view_details.php?id=20100&category_id=127&category_parent_id= _________________ 89 Westy 2.1 Auto |
kamzcab86 Samba Moderator
Posted: Wed Aug 01, 2012 2:06 pm Post subject: |
It looks like the cabinets would need to be pulled to replace that hose, no? |
Nope. Just tape it well to the old hose and pull it through. The clamp at the tank is a bit of a PITA, but no need to remove the cabinetry. _________________ ~Kamz
2016 Golf GTI S
Posted: Wed Aug 01, 2012 2:52 pm Post subject: |
OK, and thanks for the link. I searched their site but didn't come up with that result.
So if you pull the tank from inside so you can access the point of attachment at the tank itself, then you can pull the taped hoses through. Sounds easy!
Thanks Kamz! _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
The Skylight Guy Samba Member
Joined: August 06, 2004 Posts: 47 Location: Gibsons, BC
Posted: Mon Aug 06, 2012 9:05 pm Post subject: Delta Six - original camper parts |
We can help you with any questions regarding your camper hook up parts. We've resurrected the original molds and have made several updates to them.
We also still supply the hose connection and P-Trap and drain connections...along with water level sensors etc
Contact us any time! We love hearing from Volks! _________________ Cheri & Trevor
1985 Westfalia 'Rock-on'
www.vanagonwestfaliaparts.com
Gibsons, BC Canada
604-740-1018 |
Posted: Mon Aug 06, 2012 10:42 pm Post subject: |
Thanks Kamz! |
Simply pull the shelf out of the right cabinet/bin (from up top) and there's the fill hose, in the same section as the electrical outlet wiring and such. _________________ ~Kamz
2016 Golf GTI S
Posted: Tue Aug 07, 2012 10:19 am Post subject: |
Thanks Skylightguy and Kamz ~ my weekend project! _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
kingbob1000 Samba Member
Joined: August 14, 2010 Posts: 13 Location: enterprise al
Posted: Fri Oct 12, 2012 11:31 am Post subject: Issue |
Anyone know of a link or forum that goes in depth on installing hook ups on a vanagon. Since I happen to buy one that was not a camper model. I am having to fix the damage from another and want to do it the right way. Much appreciated |
Posted: Sat Oct 13, 2012 3:05 am Post subject: Re: Issue |
kingbob1000 wrote: |
We manufacture the OEM hook ups, please contact us for assistance...
We are working on an installation guide for folks, just not ready yet. _________________ Cheri & Trevor
Gibsons, BC Canada
604-740-1018 |
a00318070 Samba Member
Posted: Mon Jul 29, 2013 12:41 pm Post subject: Faucet blows fuse when I use freshwater tank but city works |
Hello, This information is all very helpful, but I've been searching around and cannot figure out what needs to be fixed on my sink. It worked 2 weeks ago when I bought the van but now it blows the fuse every time I turn the knob on the faucet. I'm not sure what is broke? Anyone have any ideas? Thanks a lot. By the way its a 1991 Vanagon GL Camper. |
Timwhy Samba Member
Posted: Mon Jul 29, 2013 1:45 pm Post subject: Re: Faucet blows fuse when I use freshwater tank but city wo |
a00318070 wrote: |
Sounds like your faucet is worn out. Replace it with an original model or upgrade to a shurflo! _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Posted: Mon Jul 29, 2013 1:47 pm Post subject: Re: Faucet blows fuse when I use freshwater tank but city wo |
Timwhy wrote: |
a00318070 wrote: |
Sounds like your faucet is worn out. Replace it with an original model or upgrade to a shurflo! |
My guess is the pump went bad. _________________ 89 Westy 2.1 Auto |
Posted: Mon Jul 29, 2013 1:49 pm Post subject: Re: Faucet blows fuse when I use freshwater tank but city wo |
a00318070 wrote: |
Consult your original topic: http://www.thesamba.com/vw/forum/viewtopic.php?t=564482 . _________________ ~Kamz
2016 Golf GTI S
Bruce Picton Samba Member
Posted: Mon Apr 21, 2014 8:40 am Post subject: water tank |
Can the water tank be plugged where the water supply line goes out to the Delta Six?..What is used to plug it? Cheri and Trevor..do you have new tanks(or used) ones for sale?...Has anyone moved there tank? |
TNjohn Samba Member
Joined: October 28, 2014 Posts: 10 Location: Asheville, NC
Posted: Sun Apr 05, 2015 11:08 am Post subject: |
I am trying to replace my sink water pump. The old pump wires (blue and brown) met the other wires in a plastic box (photos on previous page). I can not get into this box. Do I simply splice the new wires to the old ones that enter the box, or is there a better solution? _________________ '87 westy 2.2 L Gowesty Engine
'72 Beetle Convertible |
Timwhy Samba Member
rotaecho Samba Member
Joined: October 14, 2012 Posts: 513 Location: Nomadic Vanlifer
Posted: Sun Apr 05, 2015 4:42 pm Post subject: |
I got it working Thanks for the reply! _________________ -Will
1982 Westfalia mTDI (50deg) aka Betsy Bertha
http://www.tdivanagons.com |
jerryherb Samba Member
Posted: Wed Jan 13, 2016 1:41 pm Post subject: Re: Me and my RV, Vanagon, Westy Plumbing With pictures!!! |
i recently became an owner of mostly renovated 83 aircooled westy and am trying to finish the job. there are a few minor details that needed attention and im in the process of re-engineering the dashboard as well as making the fridge/water/battery panel fully functional. it turns out the all that was needed to repair the panel LEDs was cleaning the op-amps as through the years dust/dirt caused cross-shorts between the op-amp "feet" causing the low water as well as amber-red battery LEDs to glow regardless of battery/water level. if you have experienced strange behavior with the FWB panel i would recommend mechanical cleaning of the LM324Ns first.
anyway, i extensively referenced to the bentley and found a comment there that low level of water should cut the power to the pump to prevent it from running dry, however that is not happen in my camper. i replaced the broken delta with a shurflo and it does cause the pump to turn on regardless of the water level. its a submersible pump and has 4 connectors on the outside of the tank (1 black ground, white,yellow,green). all test fine and light up the equivalent LEDs on the panel, but no pump shut off takes place.
my panel has the green fridge-on LED and it appears that the battery level and the fridge light run off the op-amp on the right and the water level runs of the op-amp on the left. i dont see how the pump shut off once the water is low is supposed to work by looking at the bentley diagram.
any help would be greatly appreciated. all cabinet wiring appears original and not altered in any way. pictures attached.
please correct me if im wrong, but looking at the picture above it appears that the black wire is ground. the white wire feeds from the pilot light indicator. green is the voltage from the water tank level sensors. orange wire is +12v and the yellow jumper wire feeds +12v directly to the pump yellow cable through the faucet switch completely bypassing the FWB panel circuitry. i dont see how the current/factory wiring can shut the pump when water low level is detected as the other cable at the pump (picture 1) is just black/ground.
GreenMachineVW Samba Member
Posted: Wed Jan 13, 2016 4:11 pm Post subject: Re: Me and my RV, Vanagon, Westy Plumbing With pictures!!! |
I am pretty sure that only the very early panels cut off the pump, and maybe even only the ones with the pump under the sink and not in the tank: the ones without a fridge light on the bottom left. Like you, I don't see how that could work on the new ones. |
