pupjoint Samba Member
Posted: Fri Aug 03, 2012 12:45 am Post subject: Setrab single and dual fan pack |
is the dual really needed, and despite the smaller size, does it really "outperform" the traditional Mesas?
anyone has any pics of how the dual pack setrab's mounted? |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Fri Aug 03, 2012 11:09 am Post subject: Re: Setrab single and dual fan pack |
pupjoint wrote: |
Yes. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Fri Aug 03, 2012 5:48 pm Post subject: |
Jason,
Do you run the single or dual? What are your temps like? You have eliminated the stock oil cooler with your BB shroud as I recall.
S |
Posted: Fri Aug 03, 2012 6:22 pm Post subject: |
Steve,
I'm running a small, single Setrab (Series 1, 25 row; 7 5/8" x 6 7/16"). Even without the fan hooked up, oil temps stay around 200 F. It replaced a 96-plate- Mesa that ran about 20-25F hotter (also, no fan). The Setrab is simply a way more efficient design, with much greater surface area for convective heat flux from the cooler to the ambient air. _________________
66brm wrote: |
Bodacious wrote: |
Posted: Fri Aug 03, 2012 6:32 pm Post subject: |
Very cool (ha) to hear. I'm thinking of trying a wide aspect ratio but small height/thin Setrab. I have a nice spot to tuck it under my wing where it will have high pressure to duct through.
Motorcycle and utility vehicle (Rhyno) fans from stock oil coolers are cheap on ebay if you need a fan. They go from 5 up to 8".
My squishy 2275 is heating up real quick since I switched to thicker oils. |
Crimson_Axe Samba Member
Joined: September 06, 2004 Posts: 42 Location: Orlando, Fl
Posted: Fri Aug 03, 2012 7:09 pm Post subject: |
Dual setrab works excellent - I ran a 2563 with no internal oil cooler and temps stayed below 200 in orlando, fl during summer |
Posted: Fri Aug 03, 2012 7:47 pm Post subject: |
Crimson, you had a special T4 with Nickies in a hot rod / cruiser type car. With that fancy engine you could have gotten by with no cooler I bet |
Posted: Fri Aug 03, 2012 10:45 pm Post subject: |
yep - but driving from baton rouge to orlando did get the temp up a bit sinceh I was driving at a fast clip The thing I like about the setrab is that they are compact - I would say that if you are only running the setrab without an internal oil cooler then buy a spare fan when you order just in case one burns out (mine have been running for quite a few years with no problems but its good to have a spare fan just in case) |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Mon Aug 06, 2012 7:35 am Post subject: |
Where is the best place to mount an oil cooler, and what's the reason very few, if any, mount an oil cooler at the front, directly in the airflow? Is it the length of the oil lines?
I have a Mesa (with fan) mounted in my replica speedster's driver's side rear wheel well.
Ron |
rrcade Samba Member
Joined: May 29, 2010 Posts: 735 Location: WI 1962 Bug 2276
Posted: Wed Aug 08, 2012 8:10 pm Post subject: |
911pickup wrote: |
Ron |
I've wondered this too, I imagine way too far to pump oil right?? |
