Chris659 Samba Member
Joined: June 14, 2011 Posts: 654 Location: Central Florida
Posted: Fri Aug 24, 2012 8:47 pm Post subject: |
Then if that's the case do what I did and put in a velocity ring... _________________ 61 ragtop, 12 turbo beetle |
damicotile Samba Member
Joined: September 16, 2004 Posts: 1069 Location: WOODLAND CA.
Posted: Sat Aug 25, 2012 7:14 am Post subject: |
Chris659 wrote: |
Then if that's the case do what I did and put in a velocity ring... |
I was thinking about that. Where would I get one? _________________ '73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________ |
pow_rider17 Samba Member
Joined: October 13, 2006 Posts: 509 Location: Burque, NM
Posted: Sat Aug 25, 2012 9:02 am Post subject: |
Well I had a thread about a scat welded fan and a CB 36hp shroud fitment issue; for some reason I can't find it along with at least one other thread of mine(Hmmmmmm). Maybe my threads were ultimately deemed unnecessary but that’s hard to believe considering some of the threads around here.....
I had the gaps, had shimming issues and it seemed to be the norm for folks but i didn't like it because when bolting up the OE fan I didn't have these issues.
I ended up getting my OE fan welded locally and using an OE shroud, it all fits great.
Gold star for whoever can find my scat fan and 1955 build threads....may the force be with you. |
Posted: Sat Aug 25, 2012 4:05 pm Post subject: |
damicotile wrote: |
Chris659 wrote: |
I was thinking about that. Where would I get one? |
I got mine from Awesome Powdercoat...I'm sure there's other places too but not familiar with any others _________________ 61 ragtop, 12 turbo beetle |
Posted: Sun Sep 02, 2012 5:40 pm Post subject: |
New problem.
As you know this is a CB fan shroud and cylinder tins.
I have the motor in and running. I also have a center mount bell crank linkage by CSP.
Well the linkage arm is hitting the shroud right at the lower left fan backing plate bolt.
The alt is out of line from the crank pulley by about 3/8" which means it is rearward by that much.
I'm thinking it's the aftermarket cylinder tins pushing it back out of line
Anyone got any ideas on what to do? _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
