Vinnems Samba Member
Joined: December 23, 2008 Posts: 1183 Location: Simi Valley, CA
Posted: Mon Sep 03, 2012 11:13 pm Post subject: Door seal question |
Was looking at the door latch from the inside and notice the door seal does not cover that area. At all. I can see right outside the car. New seal from Wolfsburg. Is this just normal for the seal or am I missing something on the latch to make it seal completely? It's a pretty big gap, lets in lots of noise. Rest of the door is sealed tight (can barely close the door!) but there's that big gap I don't like. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Tue Sep 04, 2012 5:23 am Post subject: |
The door seal is larger at the door latch. It's got a 'flap' that almost sticks out of the gap with the door closed. Sounds like you didn't put the new seal on right. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Tue Sep 04, 2012 1:28 pm Post subject: |
Thanks Run, I'll look at it when I get home. |
Posted: Tue Sep 04, 2012 11:02 pm Post subject: |
OK, checked my seal, I see what you mean. The 'flap' part is larger in that area. I know the seal is on right because that part is where the latch is. It seems the flap is push in, though, so it doesn't slide against the pillar, if that make sense. |
Posted: Wed Sep 05, 2012 10:46 am Post subject: |
onslowb Samba Member
Joined: November 20, 2006 Posts: 315 Location: Woodland Hills
Posted: Wed Sep 05, 2012 1:53 pm Post subject: |
I just got door rubber from WW and one of them was about a foot too long along the curve part from the top rear corner to the front bottom corner. I cut a section out and reglued. Worked OK but the seal itself is thinner in that area than on the other door. Seems like it got deformed or stretched coming out of the mold but I have never seen how these things are made so just a guess. |
Posted: Wed Sep 05, 2012 6:06 pm Post subject: |
Holy moly, Ron! That section on mine is a little longer than the rest, but not THAT long Where'd you get your seals? |
dubstar Samba Member
Joined: January 17, 2009 Posts: 1437 Location: New York
Posted: Wed Sep 05, 2012 9:27 pm Post subject: |
I didn't have to glue my seals from WW at all. They fit perfectly and held. But that edge is nowhere as big as Run posted. I even checked my other door seal, which I haven't put in yet, and it's not even close as that big anywhere around the seal. |
doc1976 Samba Member
Posted: Wed Sep 05, 2012 9:33 pm Post subject: |
remind me not to buy door rubber from WW! back to West Coast Metric |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Sep 06, 2012 6:01 am Post subject: |
If I got a door seal that was too long I would send it back for replacement. But I've never had an issue with Wolfsburg West. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Thu Sep 06, 2012 8:12 am Post subject: |
"remind me not to buy door rubber from WW! back to West Coast Metric"
note that I wrote MIB...I suspect the other seals that are too large are made in Brazil, as well
WCM most likely will have the same seals
MIG probably won't be a problem _________________ 1963 Type II Kombi
1977 Type I Fuel Injection
http://instagram.com/john_aka_dubstar/
http://web.stagram.com/n/john_aka_dubstar/
"you could transport really tall things too, like a giraffe" |
Posted: Fri Sep 07, 2012 2:47 pm Post subject: |
My WW seal, pressed flat, for comparison. |
Posted: Sat Sep 08, 2012 2:35 am Post subject: |
My WW door seals look like yours near the latch. Apart from the length problem on one door my seals fit well with no glue. Airtight too. I can feel and hear the air pressure when I close the door. Post a pic of the gap. |
Posted: Sat Sep 08, 2012 10:18 pm Post subject: |
Will, do, onslow. And I know what you mean. Other than the door gap, these seals are great. I really have to slam the door to make sure it's closed all the way because they are so thick. |
