A slight alteration that makes it easier to get in Syncro
peaceful warrior
peaceful warrior is offline
PostPosted: Tue Sep 11, 2012 1:33 pm    Post subject: A slight alteration that makes it easier to get in Syncro Reply with quote
I have a parts Vanagon, and since I have trouble getting up into it the Syncro, and was worried about grabbing the steering wheel each time I decided to pull the passenger side grab handle and install it in the Syncro. Here is the finished product.
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
GrindGarage
GrindGarage is offline
PostPosted: Tue Sep 11, 2012 1:34 pm    Post subject: Reply with quote
So funny was looking at doing the same may the classifieds flood with spare handels
-cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com
mwsnow
mwsnow is offline
PostPosted: Tue Sep 11, 2012 1:38 pm    Post subject: Reply with quote
Caution - wires inside. Bentley 97.7.
peaceful warrior
PostPosted: Tue Sep 11, 2012 1:42 pm    Post subject: Reply with quote
Good luck in finding them.....the install took all of ten minutes.
Just make sure to get the escutcheon that the handle screws into, screws and caps for the handle, so that they sit away from the pillar, which keep the handle away from the windshield.
Just a note. Be very careful drilling into the A pillar as there is a wiring harness going up it. I knew it was there, so the first hole was drilled very slowly. The I kept a dentist pick on it while drilling the last three holes to keep it away from the bit. Slow and sure is the best way. Wink
TOOB Member #15
Brian
peaceful warrior
Wink Just mentioned that!
TOOB Member #15
Brian
kamzcab86
kamzcab86 is offline
PostPosted: Tue Sep 11, 2012 1:48 pm    Post subject: Reply with quote
Hate to say it, but you're not the first:
http://www.thesamba.com/vw/forum/viewtopic.php?t=394673
http://www.thesamba.com/vw/forum/viewtopic.php?t=378022
Wink
~Kamz Anxious
2016 Golf GTI S
peaceful warrior
PostPosted: Tue Sep 11, 2012 1:52 pm    Post subject: Reply with quote
Wink
That's cool Cool , just thought I would share....thank you for the links. I did not bother to search. Wink Very Happy
TOOB Member #15
Brian
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Sep 11, 2012 2:04 pm    Post subject: Reply with quote
Another option
Casey--
'01 Weekender --> full camper
y u rune klassik?
boof1306
boof1306 is offline
PostPosted: Tue Sep 11, 2012 2:37 pm    Post subject: Reply with quote
Mine has both sides fitted from factory!
peaceful warrior
PostPosted: Tue Sep 11, 2012 2:41 pm    Post subject: Reply with quote
Zeitgeist 13 wrote:
Another option
Not a bad idea either. For me the placement on the A pillar is perfect. I might throw my back out reaching for this one. Laughing Wink
TOOB Member #15
Brian
peaceful warrior
PostPosted: Tue Sep 11, 2012 2:42 pm    Post subject: Reply with quote
Aren't we special... Laughing Wink That is cool, I did not know they were an option or otherwise. I only realized I needed it and had one. Wink
TOOB Member #15
Brian
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Sep 11, 2012 3:18 pm    Post subject: Reply with quote
http://www.gowesty.com/ec_view_details.php?id=2283&category_id=363&category_parent_id=
http://www.van-cafe.com/home/van/page_481_162/grab_handle.html
No wedgies though and no brown.
peaceful warrior
PostPosted: Tue Sep 11, 2012 3:37 pm    Post subject: Reply with quote
Neither of these have the escutcheon or riser, if you will to angle the handle towards the drivers. I don't think it is a good idea to have them flat on the A pillar, but thank you for pointing out the link. Wink
TOOB Member #15
Brian
Franklinstower
Franklinstower is offline
PostPosted: Tue Sep 11, 2012 3:38 pm    Post subject: Reply with quote
I might have some spare brown ones if anyone is interested. Let me know via p-mail.
Paul
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
insyncro
Banned
insyncro is offline
PostPosted: Tue Sep 11, 2012 5:34 pm    Post subject: Reply with quote
Paul
Me too.
MKIII and Sons
MKIII and Sons is offline
PostPosted: Tue Sep 11, 2012 5:50 pm    Post subject: Reply with quote
what ill affects are had by simply grabbing the steering wheel?
broke.status
Farfrumwork
Farfrumwork is offline
PostPosted: Tue Sep 11, 2012 8:22 pm    Post subject: Reply with quote
Zeitgeist 13 wrote:
Another option
Hey Casey,
Any more pics or details about this location?
I bought a spare handle, which came with both styles of risers, in order to do just this! My 5'3" wife wants an oh-sh!t handle above here head (can't reach the A-pillar handle while seated).
I'm not sure where the best place to mount would be(?). I don't want to disturb the trim piece, but it needs to be solid... i.e. wheres the beef up there?
thanks!
sold Sad -> '85 Wolfsburg Syncro / 'Built' DOHC EJ25 (a great machine!)
'07 Legacy spec.B, road tuned stgII
'17 4x4 Sprinter, stone grey, SMB pop-top, on 33"s
"Blood stains, speed kills - Fast cars, cheap thrills - Rich girls, fine wine - I've lost my sense, I've lost control, I've lost my mind"
Zeitgeist 13
PostPosted: Tue Sep 11, 2012 8:38 pm    Post subject: Reply with quote
That handle is from an early '90's Passat. It's not entirely evident, but there's a fair amount of metal that runs up behind the dome light on the drivers side. It's probably best to pop the light out and feel with your fingers to determine how far you can go, but I think it's something like another inch before you run out of metal. I don't use that handle as much for ingress/egress, as for adjusting my position while in the seat.
Casey--
y u rune klassik?
syncrodoka
syncrodoka is offline
PostPosted: Tue Sep 11, 2012 8:53 pm    Post subject: Reply with quote
The driver's side A-pillar handle mod is one of the first things that I do to my vans, both 2wd and syncro.
The handle goes from convenience to requirement when the van is really off camber to the driver's side and you have to get back in by running, jumping then finally climbing your way back into the pilot's seat and the passenger's side is blocked(don't ask how I know Wink).
peaceful warrior
PostPosted: Tue Sep 11, 2012 8:55 pm    Post subject: Reply with quote
Laughing Wink
TOOB Member #15
Brian
