vicpolky Samba Member
Joined: August 09, 2006 Posts: 76 Location: Brighton, United Kingdom
dubaddict Samba Member
Posted: Tue Mar 10, 2009 1:26 pm Post subject: |
Looks good Vic n J.
Drives even better than it looks. With luck, Im only waiting on a few parts and we should be able to keep up with you!
E |
Posted: Tue Mar 10, 2009 4:12 pm Post subject: |
Me too...its been a while! Id love to be there on dyno day! |
Mike Att Samba Member
Posted: Wed Mar 11, 2009 3:14 am Post subject: |
Really like this, great eye for detail
Niceone guys |
stede Samba Member
Joined: February 27, 2008 Posts: 316 Location: Buckeye,AZ by way of El Sereno Rifa, Sur Califas 13
Posted: Tue Mar 17, 2009 6:22 am Post subject: |
gerg wrote: |
Very cool work ther and a SUPER clean looking bug.
I just cranked my 1385 for the first time last weekend using a 100 cam and the 373 heads, 1.1:1 rockers as well as a '65 case.
I am pretty happy with the results so far. Only about 40 minutes run time on the stand so far though.
Looks good,nice attention to detail ! |
wardvwracer Samba Member
Joined: July 19, 2002 Posts: 489 Location: De Pere, WI
Posted: Wed Mar 10, 2010 7:07 pm Post subject: |
Great thread! _________________ David Ward
ACME Berrien Buggy Street/Strip racer build
1963 Single Cab
1969 Beetle Convertible
63 11-Window Kombi Bus
Cornpanzers |
zundapp Samba Member
Joined: August 16, 2004 Posts: 514 Location: Never far from Fahrvergnügen
Posted: Fri Mar 12, 2010 4:32 pm Post subject: Re: 40 horse vintage speed project |
EverettB wrote: |
That looks great. Great photo too.
I'm definitely interested in hearing the horsepower rating.
One suggestion... I'd paint the regulator casing black so it looks vintage too. |
Great looking engine.
So what did this end up doing on the dyno?? |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Tue Mar 16, 2010 9:19 pm Post subject: Re: 40 horse vintage speed project |
zundapp wrote: |
EverettB wrote: |
Desktop Pic. Cool _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
stede Samba Member
Posted: Wed Mar 17, 2010 7:12 pm Post subject: |
Where did you find your exhaust ???? |
62ItalianRagtop Samba Member
Posted: Sat Mar 10, 2012 11:27 am Post subject: |
Vicpolky, have you a video of engine running ? _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sun Apr 01, 2012 6:28 pm Post subject: |
Is your left intake manifold offset to the rear slightly to accomodate the left head's more forward location? I checked Riechert's website, and both SP manifolds "appear" to be mirror-image. Quite $$ also! Reason I ask is that I;'m in the process to cut apart some type 3 SP manifolds (Solex 32PDSIT with larger venturies) and welding a short section of pipe spacer to lengthen them for Beetle application. The stock design has the left carb further forward than the right carb. To make the cross-pull carb linkage work, I'd either need to extend the left carb's throttle arm rearward about a good inch, or weld the spacer pipe so that upper part of the manifold positions the carb rearward somewhat.
Mine's all low-budget using leftover parts I already have, for a 1500 engine starting point. |
Posted: Mon Apr 02, 2012 12:29 am Post subject: |
Rome wrote: |
Riechert's set-ups aren't cheap, but they are excellent value - great craftsmanship and ready work straight out if the box. That's a good question about the offset, I'll have a look and get back to you. _________________ 1385cc 40HP Vintage Speed Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=325587&postdays=0&postorder=asc&start=0
http://www.oldspeed-mouse-motor.blogspot.com/
http://www.superninety.blogspot.com/ |
Posted: Thu Sep 13, 2012 7:22 am Post subject: |
Do you use a stock oil pump and fuel pump ? _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
Posted: Sun Jan 20, 2013 5:38 am Post subject: |
On an engine like this one, also a 019 is good ? _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
