stew82 Samba Member
Joined: May 02, 2003 Posts: 31 Location: Salt Lake City, UT
Posted: Wed Jun 18, 2003 8:32 pm Post subject: Pop-top to Rag-top conversion |
I have a 69 camper top bus and am thinking of removing the top and retro-fitting some style of rag top sunroof in the hole. Anyone out there ever heard of anyone doing this? Any suggestions. Is this a stupid idea? |
flat4freak1978 Samba Member
Joined: June 02, 2003 Posts: 793 Location: stone mountain georgia
Posted: Thu Jun 19, 2003 1:18 pm Post subject: Pop-top to Rag-top conversion |
no on the contrary its a really cool idea that i think could be done for under a hundred bucks if you fabricated everything yourself versus 200 plus dollars for that stupid sunroof seal. just get some alminum stripping measured out for all 4 sides of the hole, put in snaps, the bottom part and cut a peice of vinyl (the high grade kind) and fold it over a about a half inch and put the top parts of the snaps in it and install all of this make sure to put some sort of weather sealing strip under the aluminum to keep water out and you could measure the width of the sunroof hole opening and go to a junkyard and get one of those air deflectors off of another car that has a sunroof that will fit from one side to the other of the bus roof opening and install it in front of it to deflect air/water. and then run a bunch of water over it and spray it all around to test for leaks and assuming it doesnt leak youll have a very cool custom ragtop. atleast thats the idea ive schemed up in my head. you guys let me know what you think about my idea. thanks.
peace and much luck.
happy trails.
justin everson
[email protected] |
Big B Samba Member
Joined: June 24, 2003 Posts: 467 Location: long beach,cal
Posted: Tue Jun 24, 2003 1:30 am Post subject: Pop-top to Rag-top conversion |
Justin;
STOP IT, STOP IT RIGHT NOW!!!!!!
i've installed two aftermarket kits and was very unimpressed with both of them.
Making your own will destroy a good bus The thing will leak like a sive.
Big b |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Tue Jun 24, 2003 6:53 am Post subject: Pop-top to Rag-top conversion |
brian, you are assuming he is using a "good' bus to start with. just as a hypothetical exercise, (don't try this at home kids, with a good bus) here's the approach i would take- rather than messing around with a soft covering (chances are you would lose it the first time you get passed by a big truck), i would find a donor bus in a junk yard and cut a roof panel 2" larger in all dimensions than your existing opening. bevel any support ribs in your new targa panel so that it fits flush with your own bus roof, but don't cut the ribs- you'll want the stiffness. install a good adhesive backed foam weatherstripping around the hole in the roof, and for good measure install the same stuff on the inside of your targa panel, so that the two weatherstrips will be side by side when the panel is installed (measure, measure, measure!) clean up the cuts on the top panel, and install an edge beading to protect fingers. to secure to the top of the bus, use dzus pins, and for added security, hold-down clamps inside at each corner. If you want to get fancy, you can install some hooks and straps to secure your new targa panel to the inside rear roof of your bus for storage, cheap, simple, and easy to return the bus to stock down the road. |
