1991 vanagon headlight switch melted.
jforero
jforero is offline
PostPosted: Sat Oct 06, 2012 4:25 pm    Post subject: 1991 vanagon headlight switch melted. Reply with quote
Folks the headlight switch in my 1991 vanagon overheated and melted. Shocked The part number on the switch is 251-941-531Q. I understand that number has been superseded by 251-941-531T but VW no longer supplies that switch. Does anyone have a swith that I can buy or does anyone know if I can use a swith from an earlier model and make it work?
Sodo
Sodo is offline
PostPosted: Sat Oct 06, 2012 5:26 pm    Post subject: Reply with quote
If you use a "headlight relay kit" then any switch will be sufficient. You might check your headlight bulbs, maybe the reason the switch melted is because your van has (some or all 4) higher wattage headlight bulbs.
To run higher wattage bulbs, the "relay kit" is absolutely required. And if you add the relay kit, your next switch can be old, used and will still last forever because all the real power goes thru the relay.
....KTMs, GasGas, SPOT mtb
Corwyn Premium Member
Corwyn is offline
PostPosted: Sat Oct 06, 2012 5:32 pm    Post subject: Reply with quote
Both GW and VC carry the headlight switch. Yours melted because you are drawing too much current through the switch. Check either of the aforementioned vendors for a high power headlight relay kit.
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Sat Oct 06, 2012 5:33 pm    Post subject: Reply with quote
http://www.van-cafe.com/home/van/smartlist_585/headlight_switch.html
Currently:
All that's needed for evil to prevail is for good people to do nothing.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Oct 06, 2012 8:45 pm    Post subject: Re: 1991 vanagon headlight switch melted. Reply with quote
The dash wiring harness is different to support the new type switch. If you substitute the older type switch into the newer dash harness you will be bypassing the protection fuse for the dash lighting. That is not a good idea.
You could splice a fuse inline with the gray/blue wire leaving the switch to restore fuse protection.
Mark
240Gordy
240Gordy is offline
PostPosted: Sun Oct 07, 2012 11:54 am    Post subject: Reply with quote
Frank Condelli sp? fuse relay kit is only $37 from his site, was checking it out last night.
Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR
susan dolvin
susan dolvin is offline
PostPosted: Thu May 22, 2025 11:15 am    Post subject: Re: 1991 vanagon headlight switch Reply with quote
Hi, does anyone know where to get a 1991 headlight switch? It was working but then the tail lights quit. HaVe checked vc and gw both out of stock.
Thank u so much for any clues.
This is for a bus for my grandson.
Susan Dolvin
1966 Dormobile Westy
1988 Riviera weekender
1990 Westy
zerotofifty
zerotofifty is offline
PostPosted: Thu May 22, 2025 2:44 pm    Post subject: Re: 1991 vanagon headlight switch melted. Reply with quote
This one is thru 1988, maybe it will work? I dont know...
https://www.thesamba.com/vw/classifieds/detail.php?id=2133914
Or this on Amazon, thru 1989
https://www.amazon.com/Volkswagen-Vanagon-Headligh...&psc=1
no year listed, Cheap!!!
https://www.autohausaz.com/pn/251941531M
You may wish to call Buslab in California and inquire if they have any. They seem to have a lot of stuff not listed on their website.
https://www.buslab.com/
There is some good info here too, read the notes regarding 8 or 10 pin switches...
https://www.busdepot.com/251941531m
Good luck!!!!!!
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
