Endicott jb Bondo King
Joined: February 17, 2008 Posts: 1902 Location: Havre, MT
Posted: Sun Oct 21, 2012 7:37 pm Post subject: |
Today I removed the crappy 009 with the illustrious ignitor II and put in an old 205m off of an old 40 horse I had lyin around. Set the timing with the vacuum disengaged and then ran to the parts store without the advance. Ran ok with no advance. Picked up some vacuum hose and installed accordingly. Runs much nicer in the low range and doesn't take forever to pick up. Now to figure out how to get the carbs diaed in perfectly. It still backfires a little here and there but runs much nicer. _________________ Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs. |
Desertbusman Samba Member
Posted: Sun Oct 21, 2012 7:44 pm Post subject: |
cdennisg wrote: |
[ I guess I never include the possibility of someone else working on my bus, so I don't consider the possibility of someone else screwing it up.
Sounds like you have bus ownership under control. No none touches my Dubs (can't afford it anyway). Although had a pro computer alignment. Only after going over the whole thing with the tech as far as the alignment specs. With only one tierod he couldn't have messed it up.
Since you do your own the only "someone" to worry about is the P.O. _________________ 71 Superbug
71 Westy |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sun Oct 21, 2012 8:20 pm Post subject: |
Desertbusman wrote: |
cdennisg wrote: |
Since you do your own the only "someone" to worry about is the P.O. |
I have fixed plenty of PO stuff, and this winter, I will be removing the windshield and entire dash to finish the job. The PO had nothing to do with the windshield rust, but he did mess with the gauges and wiring enough to make me want to gut it all and start over.
I do my toe-in with a home made sliding rule I built, and I clamp the rear of the wheels toward each other to give it a "thrust" alignment. Works perfectly every time. I use a few spacers and one of my nice carpenter's levels to do the camber adjustment. I haven't done one in awhile, or I cold probably rattle off the numbers. That's what Mr. Bentley is for. _________________ nothing |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
XXX! gonna be getting some pics uploaded here soon....BUT.....
Notchboy, Draconis, Me, Zelten, and a few others were seen today at the XXX.....
what a good turn out for Water and Air coolers! great time, hung out all day, got some digits from a couple girls....all in all a good day _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Oct 21, 2012 8:21 pm Post subject: |
ccpalmer wrote: |
cdennisg wrote: |
when you want to get your steering wheel perfectly centered, and you find that the splines are off just a little in either direction, you can slightly adjust both tie rods to get it perfect. I really can't see a thing wrong with that. |
The only thing that might be wrong and is the biggest concern of everything is the centering of the box. |
I would say that another issue at hand is say someone adjusts the left tie rod to be a quarter-inch shorter and adjusts the right tie rod a quarter-inch longer the toe-in may remain the same but the geometry involved in the tie rod-swing lever system is compromised. It's complex to explain in detail - this is the best website I could find to explain this principle "ackerman geometry?"
http://www.smithees-racetech.com.au/ackerman.html
Basic idea is this system allows for variable toe when steering as on a turn, the outside wheel must travel in a bigger circle than the inside wheel thus the inside wheel must be at a sharper angle than the outside wheel. |
In a sense, I think that is what DBM was trying to say. There is much more at play here than just toe-in. Ackerman angle and steering geometry is some interesting stuff, for sure. _________________ nothing
Posted: Sun Oct 21, 2012 8:56 pm Post subject: |
Mom n dad, annie (who is a masively amazing woman who helps put on cruise for the cure) and me, and our respective bus's
Wheres maisy? (and maisy, jasons bus)
personally, i never even made it across the street...
i said pose, and she cracked up right as my phone saved the pic....
the drive to the meet i snapped a few cool shots...
and rainx worked like a charm
206-841-7324
[email protected] |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Mon Oct 22, 2012 8:10 am Post subject: |
Had tires mounted. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon Oct 22, 2012 8:32 am Post subject: |
Jeez Kirk, you and your fancy tires.
(looks good!) _________________ 1976 Westy
1966 Beetle |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Mon Oct 22, 2012 9:41 am Post subject: |
Congrats Kirk! Pretty badass. Did you get my text about the Krylon?
Champagne in the Membraaaaane
Champagne in the brain! _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
DaleNW Samba Member
Joined: March 29, 2012 Posts: 169 Location: Boulder, CO
Posted: Mon Oct 22, 2012 11:33 am Post subject: getting the engine compartment back together |
installed dynamat on the celiing of the engine compartment, resealed the original insulation, then installed the new panels I made. Installed the fan blower, and installed new rear side marker lights and tail lights. Busy weekend!
[/img]
And Friday night I put in new trim and rubber on and in the passenger door.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Mon Oct 22, 2012 12:36 pm Post subject: |
Dayum You could eat in there. Have brain surgery. Say that germaphobes could live there in peace. What Im trying to say is thats CLEAN
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
DaleNW Samba Member
Posted: Mon Oct 22, 2012 5:18 pm Post subject: |
notchboy wrote: |
Thanks Notchboy! Some have called me overcumpulsive . . . others have used an alternate term. |
rick_spiff Samba Member
Joined: August 13, 2008 Posts: 31 Location: Richland, Washington
Posted: Tue Oct 23, 2012 9:38 am Post subject: |
Glassed in the new vents so I actually get hot air!
And popped the front signals to find rotted gaskets... sealed them up with some silicone goo, to be replaced with real seals when (if?) I find them.
Bring on the weather! |
DaleNW Samba Member
skid Samba Member
Joined: January 16, 2009 Posts: 1329 Location: Vancouver, BC
Posted: Tue Oct 23, 2012 11:03 am Post subject: |
Kirk wrote: |
Had tires mounted. |
lovelovelove those tires, they are in my future! _________________ '71 Westfalia |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Tue Oct 23, 2012 11:04 am Post subject: |
Kirk wrote: |
Those tires are bad-ass; Very aggressive looking. _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
XXX/Rx/RnR Samba Member
Joined: March 01, 2008 Posts: 405 Location: valley of the sun
Posted: Wed Oct 24, 2012 6:31 am Post subject: |
All birtch panels installed, except d/p doors. Full o/h on those. Parts kits ordered from ww. Had one broken regulator. Will clean and greese up the other and the locks. Found a old shop rag in the bottom of one door with a rust outline below it after removed. So treating the rust today after removing the wings. Cut out 2 thin rubber seals. Not using sheet plastic. Took all day to clean the doors yesterday. Guess I'll have to get a thin sheet of plexi-glass and make a door panel and clamp it to a door so I can see to drill the holes for the chrome head snaps that I'm using. Want the doors to match the slider and rear hatch where I used snaps on those. Using all early bay steel hardware than the plastic the late bays came with. The holes don't match up between a early bay and late bay. Using door pull straps too instead of armrest so when I spend the seat around on the passinger side, the door will close because of the armrest mounted in the seat. The square holes in the door are stamped out for em that the snaps for the screws to go in. |
Posted: Wed Oct 24, 2012 7:18 am Post subject: |
Wow, if done right it sounds like you're going to have NICE front door panels. Post up a pic if you get that finished up! I'd like to see _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
Kirk Samba Member
Posted: Wed Oct 24, 2012 8:58 am Post subject: |
EZ Gruv wrote: |
Kirk wrote: |
Those tires are bad-ass; Very aggressive looking. |
skid wrote: |
lovelovelove those tires, they are in my future! |
Thanks! I love them. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
kevinj73us Samba Member
Joined: September 25, 2011 Posts: 228 Location: Laurel, MD
Posted: Thu Oct 25, 2012 4:05 am Post subject: |
Installed a new exhaust last night. This is the GT style from Mid America - it's an EMPI unit.
Turns out in addition to the hole in the collector on the Bugpack system that was on there, one of the gaskets was bad and was causing a leak, too.
Really quiet inside the bus now!
kj _________________ 1973 Station Wagon
m-plate |
