another Camshaft Identification Thread
early
early is offline
PostPosted: Tue Oct 23, 2012 10:46 am    Post subject: another Camshaft Identification Thread Reply with quote
Hi Gang,
I have searched extensively to find these camshaft numbers with no luck.
I have a MOFOCO Block and Pulled the Oil Pump to have a look at the Camshaft - mostly because I have heard that MOFOCO built a lot of engines with Hydraulic Cams and I wanted to be sure what I have before putting on new Pistons & Cylinders.
the numbers on the Camshaft are either 09160 or 90610
the numbers on the 3 riveted on camshaft gear are either 6801106 or 9011089
here are pictures and Thank you in Advance for your Help !
early-
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn
03 BMW R1150RT
DarthWeber
DarthWeber is offline
PostPosted: Tue Oct 23, 2012 11:04 am    Post subject: Reply with quote
Just a wild suggestion but..............................................................................................................................................................have you tried calling MOFOCO?
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
early
early is offline
PostPosted: Tue Oct 23, 2012 11:12 am    Post subject: camshaft id Reply with quote
I sent an email to Roy at Mofoco.
but just because it is a MOFOCO Block doesnt necessarily mean that it still contains MOFOCO Parts. the Date on the Block is 2000 so its been around awhile and who knows whats in it.
the Previous Owner of this car/engine didnt give me any information as to what the engine was, he just said his Neighbor Ex vw Mechanic rebuilt it for him, well you know how that goes !..
Im just trying to identify what parts are in this block so I can move forward. It is probably just an aftermarket Stock Cam since it is Riveted , but I really dont know and was hoping someone might identify it.
thanks !
early-
Current Projects :
73 Sport Bug - L13M
94 Harley Flstn
03 BMW R1150RT
ALB
ALB is offline
PostPosted: Tue Oct 23, 2012 11:33 am    Post subject: Reply with quote
You have some good points, but Darth is right; it's a place to start.
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
[email protected]
roy@mofoco.com is offline
PostPosted: Tue Oct 23, 2012 2:37 pm    Post subject: Reply with quote
Yeah, I checked with the old man and he doesn't remember us ever putting numbers like that on a cam. For a while, we did have our own numbering system but the were AP-2 and AP-3. We also stamped 100, 110 and 120 when we ground cams to engle specs.
