marcnr1 Samba Member
Joined: April 05, 2004 Posts: 17 Location: netherlands
Posted: Sat Apr 17, 2010 4:47 am Post subject: |
marcnr1 wrote: |
Peter_Plade wrote: |
The first run on the dyno was 44hp, after cahnging the venturies it was 46hp. And then we gawe it a litttle more timing.
But I´m happy never thought I would get over 50hp with it. |
At what rpm did you het that horsepower? |
=51hp@4100rpm
Sorry, I had to watch the movie before I did that last post! |
Peter_Plade Samba Member
Joined: January 09, 2005 Posts: 551 Location: Denmark
Posted: Tue Oct 30, 2012 1:30 am Post subject: |
Well this was what happend this summer, after almost 30.000km with the Express motor the crank gave up.
The most crazy thing was that I actually was able to limp it the last 15km home with the broken crank.
The motor is now torn down and new plans have been made.
This time I´m putting in a 72mm stroker crank, this should make it a 1341cc, kind of exited to see how this will work out.
_________________ http://vw-bluehats.blogspot.com/ |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Posted: Tue Oct 30, 2012 2:19 am Post subject: |
John Moxon wrote: |
How many is that now Peter?...I seem to remember you broke another one before. |
You have a good memory John
It´s true I also broke one back when I was running my Judson.
Apparently I rev my motors to high, I just can´t control myself _________________ http://vw-bluehats.blogspot.com/ |
J Samba Member
Joined: September 15, 2007 Posts: 126 Location: Sus&Wis-town,BelGIam
grueni Samba Member
Joined: November 03, 2008 Posts: 582 Location: Germany
Posted: Sat Nov 03, 2012 2:59 am Post subject: |
they allways brake at the same point
damn. _________________ 1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile ) |
Posted: Wed Nov 07, 2012 12:09 am Post subject: |
They can also brake in the other end
This is the one that broke when I was running my Judson motor.
grueni Samba Member
Posted: Wed Nov 07, 2012 2:55 am Post subject: |
autsch...than i had luck with my supercharged engine.
but on the medusa engine i let the crank checked alot. maybe because they are so old? so allways better to use a porsche 356 one _________________ 1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile ) |
mightymouse Samba Member
Posted: Thu Nov 08, 2012 3:26 pm Post subject: |
Thats due to no counterweights and no weight on the nose of the crank.
They flex in the middle and thusly break in that same spot at either end. More likely to be the flywheel end because of the flywheel weighing more and contributing more to the flex.
Add counterweights and heavier pulley or harmonic damper.
Problems will cease. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Thu Nov 08, 2012 3:52 pm Post subject: |
_________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Thu Nov 08, 2012 5:14 pm Post subject: |
72mm is a very popular stroke, out of the three I had made up from Porsche cranks I only have one left. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
oldbusboy Samba Member
Joined: June 25, 2006 Posts: 604 Location: Bowen Island, BC Canada
Posted: Mon Dec 10, 2012 3:02 pm Post subject: |
Hi Peter,
You've run both a Judson and an Express engine on the same car. Can you pick which of the two gave you better low and top end performance? Which did you enjoy more? Which (if either) was a pain to set-up and maintain?
Thanks
Trevor _________________ 1968 porsche |
Posted: Tue Dec 11, 2012 6:16 am Post subject: |
Hi Trevor
I like the Express motor the most. Not near the same problems as I had with the Judson.
And I can push it much more without it getting to hot.
Only thing that I miss is the torque at low rpm´s that the Judson had. _________________ http://vw-bluehats.blogspot.com/ |
Posted: Sun Feb 17, 2013 3:41 pm Post subject: |
Finnally I made some progress on the motor.
The short block is now assembled, and now some machine work is needed before I can get any further.
Posted: Sun Feb 23, 2014 10:22 am Post subject: |
I had 8500 trouble free kilometers with the new set up last summer.
The extra ccm made some nice low end torque,and the hp raised to 55 on the dyno.
This winter I made a new "Abarth" for it and now it's ready for some more driving
turbolaz Samba Member
Posted: Fri Mar 07, 2014 6:23 pm Post subject: engine |
Nice engine peter, im looking to build something like this what size crank did you use? what kind of carb kit is that? _________________ shipping extra,paypal ok at 4% added to parts.
parts are sold as is. |
Posted: Sat Mar 08, 2014 12:10 pm Post subject: |
I use a 72mm DPR crank, it's really good!
The kit is Autotechnik Express made in Hannover. _________________ http://vw-bluehats.blogspot.com/ |
malsteph Samba Member
Joined: August 05, 2008 Posts: 42 Location: Liège (Belgium)
Posted: Thu Apr 03, 2014 7:19 am Post subject: |
You could use an early Porsche cam. (103 if my memory is correct)
Period correct and very compatible with the rest of the engine.
Id would probably move the power band a little higher in the revs. But if you are still getting good torque value around 3000 RPM, it is worth a try. |
tobiasax Samba Member
Posted: Thu Apr 03, 2014 11:10 am Post subject: |
malsteph wrote: |
Hello malsteph: Have you good info on early Porsche cams? I have bee trying to find out what different cams the pre-A had, but haven't really succeeded. |
Posted: Fri Apr 04, 2014 12:39 pm Post subject: |
I use a mr okrasa cam and have no plans changing it, since it runs so good as it does. Might look for other cams if I some day need to take it apart again. _________________ http://vw-bluehats.blogspot.com/ |
