Duguda's Manx II build
Page: 1, 2, 3, 4  Next
Manx Lee
Manx Lee is offline
PostPosted: Thu Oct 25, 2012 12:50 pm    Post subject: Duguda's Manx II build Reply with quote
found a manx II Thanks MSstevens!!!
JiI
JiI is offline
PostPosted: Thu Oct 25, 2012 8:29 pm    Post subject: Reply with quote
I have an identical body. Lots of room in the rear for tall tires. I should sell mine though....
Jeff
frizzardking
frizzardking is offline
PostPosted: Fri Oct 26, 2012 5:44 pm    Post subject: frizzardking-manx classic & manx 2 Reply with quote
Well welcome to the buggy world ; you should join the manx club you can have any type of buggy ; go to meyers manx. Com
And good luck!
frizzardking
PostPosted: Fri Oct 26, 2012 5:45 pm    Post subject: frizzardking-manx classic & manx 2 Reply with quote
And good luck!
Bob Elgin
Bob Elgin is offline
PostPosted: Fri Oct 26, 2012 7:36 pm    Post subject: Reply with quote
got one myself, check my build at my spatz rebuild/refresh. or click the link at the bottom of my post
OLD ENOUGH TO KNOW BETTER AND STILL TO YOUNG TO CARE!!!!!
My Build http://www.thesamba.com/vw/forum/viewtopic.php?p=5987690#5987690
My Youtube page
https://www.youtube.com/channel/UCqd2r1Af7uZgqlnxAtMap4A
Manx Lee
Manx Lee is offline
PostPosted: Sat Oct 27, 2012 2:32 pm    Post subject: Reply with quote
Thanks Frizzard and Bob i will check it out
Manx Lee
Manx Lee is offline
PostPosted: Sat Oct 27, 2012 2:37 pm    Post subject: Reply with quote
Looks great Bob how did you attach the hood to the body?
Manx Lee
Manx Lee is offline
PostPosted: Sat Oct 27, 2012 3:07 pm    Post subject: Reply with quote
i mentioned earlier that a IRS pan came with my buggy upon closer inspection i decided to use a donor with a title and alot of the missing pieces
Manx Lee
Manx Lee is offline
PostPosted: Thu Nov 01, 2012 3:47 pm    Post subject: Reply with quote
I will be removing the lift kit
didget69
didget69 is offline
PostPosted: Thu Nov 01, 2012 4:25 pm    Post subject: Reply with quote
Duguda Duguda wrote:
and new engine
Type 4, Bus motor - what size/engine code?
http://www.thesamba.com/vw/archives/info/engine_letters.php
bryan
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Manx Lee
Manx Lee is offline
PostPosted: Thu Nov 01, 2012 5:14 pm    Post subject: Reply with quote
going with a Corvair power plant
didget69
didget69 is offline
PostPosted: Thu Nov 01, 2012 6:36 pm    Post subject: Reply with quote
Is the engine a runner? Any history on it? You've probably read about the T4 issues with valve seats & head cracks?
Pulled a compression check on it yet?
bryan
Manx Lee
Manx Lee is offline
PostPosted: Thu Nov 01, 2012 6:58 pm    Post subject: Reply with quote
no compression test, but the van did run and drive good except the ton of Rust that it had....which is why it was parted out.. UPDATE I decided to use a corvair engine
Manx Lee
Manx Lee is offline
PostPosted: Wed Jul 03, 2013 7:26 pm    Post subject: Reply with quote
found a manx 2 so I will be building that instead!
Manx Lee
Manx Lee is offline
PostPosted: Tue Jul 16, 2013 7:10 pm    Post subject: Reply with quote
Manx Lee
Manx Lee is offline
PostPosted: Sat Jul 27, 2013 1:00 pm    Post subject: Reply with quote
finally home !
Bob Elgin
PostPosted: Sat Jul 27, 2013 7:10 pm    Post subject: Reply with quote
sorry been busy , just getting back to normal.
I built a inch and half angel iron(square of course) and also put a rubber pad around the inside of the angel iron, so it wont rub a hole in the tank. As far as the neck i went to u pic um parts and took the gas filler tube and flange from a chevy s10, cut it to the length then mounted the gas cap to the flange.
The gas tank angel iron is adhered to the firewall and also the flat part of the pan,
My Youtube page
Manx Lee
Manx Lee is offline
PostPosted: Wed Jul 31, 2013 4:16 pm    Post subject: Reply with quote
ok Thanks Bob!
I was doing a search for seats for buggies and I came across these :
they are a from a 71 Opel GT I measured them and it looks like they would it work they are 32 inches from the ground 30 off the front of the seat..
What do you guys think? I would be changing the interior color to black
Rathbone
Rathbone is offline
PostPosted: Wed Jul 31, 2013 5:52 pm    Post subject: Reply with quote
They're cool! Very vintage.
(o\_i_/o) what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul - Mr. Oblaski, Principal
Manx Lee
Manx Lee is offline
PostPosted: Thu Aug 22, 2013 4:29 pm    Post subject: Manx 1 build Reply with quote
getting some fiber glassing done on the rear and front I have quite a bit work
to do but I am getting there.
Page 1 of 4
