DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Mon Aug 11, 2008 7:16 pm Post subject: Direction of 36hp fuel pump pushrod. |
I'm wondering what is the proper direction of fuel pump pushrod on a 36hp. I just removed the leaking made in USA fuel pump and rebuilt the car's original German pump. I didn't pay attention that the pump pushrod had one flat end and one with a little bevel / round-ish end. Looking at the original pump I assumed the rounded end goes into the pump. Is this correct? _________________ Midwest Autosavers, Inc. Woodstock, IL |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Aug 12, 2008 5:47 am Post subject: push rod |
Dr.Darby,
I believe the beveled end goes towards the engine and the flat end goes to the pump.
60 ragtop |
toxic56 Samba Member
Joined: September 25, 2006 Posts: 120 Location: Dallas Texas
Posted: Tue Aug 12, 2008 12:03 pm Post subject: |
Would having it in wrong cause the hinge pin on the fuel pump to work its way out? I rebuilt my german fuel pump and the hinge pin keeps working its way out and I have to take it off and fix it. |
Posted: Thu Aug 14, 2008 9:29 am Post subject: pump |
toxic56,
I don't think it would cause your pin to fall out. What happened to me when I rebuilt mine was that the original pin is swedged in there and it came out. I was on my way to VWOTG in CO when it came out so I put it all back together and clamped on a pair of vise grips to get me down to CO. I ended up driving it that way till the next VWOTG(if it ain't broke don't fix it attitude).I was going to rig up a pin for it with 2 c-clips but I had an old pump with this style of pin in it so I used it.
60ragtop |
Posted: Thu Aug 14, 2008 3:11 pm Post subject: |
Thank you 60ragtop very much for the reply. Sorry DrDarby to get off your topic somewhat.
I will try another base that I have and/or try a new pin with c clips.
Chris |
Posted: Thu Aug 14, 2008 8:55 pm Post subject: |
The pump rebuild kits have a pin with two Circlips. I didn't touch my original pin or operating arm as it looked in great shape. _________________ Midwest Autosavers, Inc. Woodstock, IL |
55reasons Samba Swamp Cooler
Posted: Fri Nov 02, 2012 4:31 pm Post subject: |
But the rebuild kits hinge pin isn't long enough to stick out far enough to put the circlips on, so don't be surprised there.
....and the plastic guide spacer from CIP1 was VERY POOR quality. Hole drilled crooked, oil flow hole too small (and plugged with plastic shavings) etc... |
