bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Thu Nov 08, 2012 10:09 pm Post subject: |
It makes it confusing when you post more then one thread on the a topic so STOP IT.
Now as I said parts for these are hard to impossible to get as you will find and you will find use parts will be no good some times and finding out when things burst into flames is a bad time. Iam restoring my BN4 for my 71 westy only because it came with it from new Iam having to make new diaphams for my fuel pump and regulator because they are hard as a rock no good they can't be gotten new that I have found so they have to be made and made right or you know what can happen! with out constant up keep because of there age these heaters can be dangerous they burn gas (as if you didn't know that) I CAN'T STRESS THAT ENOUGH. people like with other things in life and in there cars ignore things this isn't one of them.
Ok enough with my safety lesson for now as I was saying in the other thread if your bus didn't already have one or you really wanted one I would look to something newer up to date burns less fuel less power you get part easier and its safer to run like a propane or even better a diesel heater. Unless you have a cook stove or other stuff in your bus that runs on propane then diesel tank is way easier to mount and for as little fuel they burn a 2 or 3 gal tank will last quite a while. The one Iam putting in my 70 westy Iam putting a tank and coach battery both on the driver side of the engine bay I will be doing a thread on its install you can if these heaters all over the net they are small and have high output diesel puts out more then propane per gal. _________________ where its cold and snowy |
Posted: Thu Nov 08, 2012 10:14 pm Post subject: |
| notchboy wrote: |
This is a printed source ready to go. It will give you the general understanding of how Eberspachers work. Some if not all of this can be found for free on various sites on the web.
http://www.thesamba.com/vw/classifieds/detail.php?id=90305
Use the forum search function for the bay window forums as well. The BN4 is a popular gas heater and has a good following. |
I just got that manuel from him and It is great! well worth the money I have a few to fix for consumers and me and it is top resource I just fully serviced my B2 for my 6 volt 1957 bug and did the upgrades in there and the heater works like new. _________________ where its cold and snowy |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22686 Location: Escondido CA
Posted: Thu Nov 08, 2012 10:36 pm Post subject: |
Do you need any material for your pumps-diaphragm? Old Russ Wolfe gave me some, allot actually, so I need to pay some forward. _________________
| t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Thu Nov 08, 2012 11:09 pm Post subject: |
I have a small piece it is just a little thiner then the original I got 0.012 the original is more like 0.015 but it took me over a year to find this. How much do you have? I was surprised the diaphragm in my old 1957 pump in my B2 was still like new man the rubber they used back then was second two none. _________________ where its cold and snowy |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 3036 Location: Commack, NY
Posted: Mon Nov 12, 2012 3:01 pm Post subject: |
Well, I learned ALOT today. But the bus is in pieces so I'm very anxious. It's out of the garage and up on stands. Since its a daily, I'm kinda out. But thankfully I work two blocks away...
I started with the manual (online, through my iPad), and the simple things. I pulled the knob and went to the back to hit the reset on the heater. The motor began to spin, but I didn't hear any clicking from the pump. So, I went to check the thermostat cable, and made sure it was pulled up all the way. After breaking it free with some PB blaster, it moves freely now, and I can see it moving the lever on the thermostat. Still no pump clicks. I do feel a breeze coming out of the outlet under the rear seat, it's just not hot.
I also checked fuel delivery to the pump, and found that when I removed the fuel line from the pump, fuel did come out freely. Next, I removed the fuel pump from the heater and took both ends off and cleaned it well with some carb cleaner. I made sure both the input and output were clear and reassembled it. I put power to it and the piston moves freely. One way when I apply 12V, the opposite way when I remove the 12V. Figuring it was the points that "applied" and "removed" 12V I went to the wires coming from the heater:
There is one that green, one that's brown with white, and a brown ground. I put a test light on the green, and the other end on the brown/white and turned on the heater. I heard the motor spinning, but anticipated (if the points were running) that the light would flash. Nothing happened.
Anticipating the points are bad, I removed the heater from the bus. And in trying to get to the thermostat (which is behind a small access hole cut into the firewall) removed the bolts holding the the mustache bar and the cradle bolts from the top engine mount to lower the engine an inch or two in anticipation of completely removing the firewall. Though (I know I'm gonna get yelled at for this) it turned out to be much more efficient to just bend the firewall forward a bit for me to stick my hand in.
So now, I know I have power. I know the pump is working when it gets power. It is getting fuel.
What is my next step? _________________ Mike
1964 Beetle
2001 Eurovan Camper |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53183 Location: Surrey B.C. Canada, but thinking of Ukraine
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Mon Nov 12, 2012 4:13 pm Post subject: |
| obnoxiousblue wrote: |
| So now, I know I have power. I know the pump is working when it gets power. It is getting fuel. |
Are you getting spark? Check the glow plug _________________ '73 Transporter 1.7L Dual Carb
| notchboy wrote: |
| You ran over some #Vanlife'ers hopes and dreams? |
| 60vwnewengland wrote: |
| Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
Posted: Mon Nov 12, 2012 4:17 pm Post subject: |
| thewalrus wrote: |
Are you getting spark? Check the glow plug |
That's a different sets of points (there's 2), read the link  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Nov 12, 2012 4:35 pm Post subject: |
Thanks Busdaddy, as always you're right on cue.
So you're of the opinion based on my experimentation that the points are likely the suspect as well?
Am I on the right path here, or should I be looking elsewhere for my cause? _________________ Mike
1964 Beetle
Posted: Mon Nov 12, 2012 6:30 pm Post subject: |
If the pump clicks while bench testing but there's no light when you connect a test light between the 2 pump wires on the heater the points on the dirty end of the fan are the next step. This assumes you confirmed there was power at the green wire when the heater was running (other end of test light to ground) and the brown/white wire was not grounding (test light between it and battery + while heater running). If you had the pump apart please tell me you didn't move the skinny jam nut one little bit because the piston stroke determines the fuel delivery and now you'll have to recalibrate if it's messed up. It's not hard, just an added step to prevent combustion chamber burnout or not enough heat (glow plug burnout). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Nov 12, 2012 6:57 pm Post subject: |
I didn't move the jamb nut I've been reading everything you've told me to! LOL
The wires with the test light did behave as you've said.
Glad this is at least going somewhat well!
It makes all my stressing today not seem so bad.
More later!
While I know I'll be posting and picking your brain more, I really appreciate your help! _________________ Mike
1964 Beetle
Posted: Sat Nov 17, 2012 5:03 pm Post subject: |
While I'm doing the heater, I'm replacing all the fuel lines on my bus. It seemed like the right time.
I'm trying to find if anyone has any opinion on the best type.
I bought the Fuel Line kit from German Supply, which came with crimp-type hose clamp:
Are those good, secure clamps or are the roller style better?
1964 Beetle
Joined: January 01, 2007 Posts: 17939 Location: sticksville, ct.
Posted: Sat Nov 17, 2012 6:34 pm Post subject: |
your bottom photo will work just fine, and you can get them at mcmaster-carr.
if you are going to run the bn4 (or any other heater) it is pretty important that your cut in/cut out temerature is measured/adjusted correctly, and the safteys are tested and ready to do their job.
super simple/safe system when properly used and adjusted _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
Posted: Sat Nov 17, 2012 6:35 pm Post subject: |
Either are fine, the screw type are removeable and reuseable roadside so consider emergency repairs as a factor. Avoid the worm style ones with the slotted bands if at all possible. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Nov 17, 2012 10:24 pm Post subject: |
| notchboy wrote: |
Get ready to open your wallet Im always looking for a new BN4 to restore. If you end up not wanting it, please keep me in mind.
Say notchboy what gray paint did you use when you repainted your heater? it looks pretty close. _________________ where its cold and snowy |
Posted: Sun Nov 18, 2012 9:43 am Post subject: |
| skills@eurocarsplus wrote: |
if you are going to run the bn4 (or any other heater) it is pretty important that your cut in/cut out temerature is measured/adjusted correctly, and the safteys are tested and ready to do their job. |
What is "cut in/cut out" temperature? I did buy a restored heater. I plan on tearing into my old one to learn about it, but since y bus is a daily driver, this was the route that let me get the bus back together the fastest. I bought the heater from a TS guy, recommended by a few people I've met over the years. His name is Marty, he's in Colorado and lists ALOT of Eberspacher kits on his classifieds here. I sent him my pump so that it is calibrated for the heater (?) he said the temperature was critical so it didn't foul the glow plug or foul the spark plug. Is that what you're mentioning?
This is the heater:
Also, I planned on replacing all my fuel lines today. But as BusDaddy mentioned earlier, the crimp on style that came with my fuel line kit aren't easy to service roadside. And they make me a bit nervous because unlike the screw clamp type I'm not familiar with "how tight" is appropriate to avoid leaking, yet not be so tight to inhibit fuel delivery.
I called up Steve at Ultimate Garage (suggested in another thread here on TS) and am ordering today the ABA Stainless Steel clamps. I like them because unlike the worm/roller type. Apparently they put even pressure around the entire fuel line, and don't have the sharp edges and spaces in the banding.
I just wasn't sure which size clamps were good for what diameter hoses. So he is emailing me back the sizes I need so I can order today. _________________ Mike
1964 Beetle
Posted: Sun Nov 18, 2012 9:57 am Post subject: |
What is "cut in/cut out" temperature? I did buy a restored heater. I plan on tearing into my old one to learn about it, but since y bus is a daily driver, this was the route that let me get the bus back together the fastest. I bought the heater from a TS guy, recommended by a few people I've met over the years. His name is Marty, he's in Colorado and lists ALOT of Eberspacher kits on his classifieds here. I sent him my pump so that it is calibrated for the heater (?) he said the temperature was critical so it didn't foul the glow plug or foul the spark plug. Is that what you're mentioning?. |
He's referring to the flame switch adjustment (glow plug on/off, safety timer cutoff and run on after shutdown), if Marty went through the heater I'm sure he's done that. The pump volume is another different adjustment and relates to operating temperature in the combustion chamber, too much fuel and it fowls up and eventually burns out the chamber, too little and the glow plug cycles constantly and the safety switch trips. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Sun Nov 18, 2012 12:44 pm Post subject: |
Those things are neat. Mind if I ask some questions? first is vernacular based.
By Gas do you mean Gasoline or Propane? I'm assuming the former.
Is there some form of heat exchange in there? I'd imagine so, otherwise you might as well just be piping the engine exhaust into the cabin.
Do they have a special outlet or do they connect to the main heater conduit? _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Sun Nov 18, 2012 1:15 pm Post subject: |
RatCamper, I'm sure one of the pros will chime in. But from what I'm learning on my bus...
This is a gasoline heater, not propane. It siphons fuel from the supply to the engine to generate heat. I'm curious to through if it can be made to run n propane. I'd assume it could be done, since most house generators have propane conversion kits too... I'm just not sure.
On one end of the heater unit there is an orange impeller fan. That draws air into the heater. There is optional white/opaque plastic ducting that can be routed up to the cabin to act as recirculating heat. Other heaters, have a gray guard over the orange impeller to draw in fresh air.
The BN4, unlike some other heaters is a complete standalone system and has nothing to to (at least in my situation) with the stock heat exchangers. Though, I have seen some literature which suggests that it can be tied into the stock ducting particularly in the 181's (?)
In the type 2, the "heat" end has a duct that goes through the firewall, along the drivers side rear wheel well, then comes out under the rear bench.
I'm sure one of the guys will affirm or correct me soon. _________________ Mike
1964 Beetle
Posted: Sun Nov 18, 2012 1:58 pm Post subject: |
Looking through the Manuel the late model BN4 had a option for a wall mount thermostat anyone seen one of those? I would like to find one. _________________ where its cold and snowy |
