Impressive restoration
srfndoc
srfndoc is offline
PostPosted: Wed Nov 14, 2012 9:38 am    Post subject: Impressive restoration Reply with quote
http://www.jeanlainvintage.com/wp-content/themes/v...stauration
Maxim
Maxim is offline
PostPosted: Wed Nov 14, 2012 4:08 pm    Post subject: Reply with quote
Awesome work Surprised
www.thevintagewagen.com
http://www.youtube.com/user/TheVintageWagen/
http://www.facebook.com/TheVintageWagen
My 67 Bus Topic: http://www.thesamba.com/vw/forum/viewtopic.php?t=470966
hitest
hitest is offline
PostPosted: Wed Nov 14, 2012 7:27 pm    Post subject: Reply with quote
Holy smokes! That's the Bentley service manual reference photography bus!
FU#5
novetti
novetti is offline
PostPosted: Mon Nov 19, 2012 9:32 pm    Post subject: Reply with quote
Very nice work.
The sale price reflects that.
Clara Premium Member
Clara is offline
PostPosted: Tue Nov 20, 2012 11:33 pm    Post subject: Reply with quote
now you are just asking for a list of incorrectness, things that would not be in the Bentley.
carb....
madcitymcflyer
madcitymcflyer is offline
PostPosted: Wed Nov 21, 2012 4:12 am    Post subject: Reply with quote
You can add to the 'stickler's list':
No speed limiter (governor) on carb;
Deluxe horn button instead of standard black one;
Missing pedal (belly)pan;
Shiny painted heat exchangers (only came primed);
Over finished underside sheet metal;
Fuel tank is painted black (they came in a shade of gunmetal gray).
Radial tires look nice; 'originals' would be 6.95 or 7.00 x 14's bias ply
Continentals from the factory;
Radio is a dealer-installed option only
Still, if Bentley ever publishes a web version, use it as is for the photo bus. And make sure the mechanic wears his clean shop coat!
hazetguy
hazetguy is offline
PostPosted: Wed Nov 21, 2012 6:04 am    Post subject: Reply with quote
want more?
-lock plates on front axle beam not installed in the correct orientation (driver's side)
-disc brakes on front (and associated mechanicals involved with that)
-front trailing arms not painted
-wrong style horn
-looks like a distributor for a dual port engine
-not so sure about those copper brake lines
-no insulating wrap on heater tubes
-wrong style sealing grommets for hose junction between fan shroud and rear tin
-etc
there looks to be a lot of missing parts. perhaps, and i don't know why this would be the case but it happens, these pics were taken before final assembly was completed? it's pretty clean though. i'd much rather see a bus like this where it is very clean all over and under, rather than some of these nice looking/"restored" busses that when you look underneath you can tell that nothing was attended to underneath.
xavi_242
xavi_242 is offline
PostPosted: Wed Nov 21, 2012 7:21 am    Post subject: Reply with quote
agree^^^
very nice and clean bus. It doesn't worth what they ask for, though. Crazy price...
1967 Split SO-42 Dormobile
Lou V.
Lou V. is offline
PostPosted: Wed Nov 21, 2012 8:46 am    Post subject: Reply with quote
Has the wrong deck lid aswell it should be church key type.
But a very nice bus.
