Replacing manual transmission drive flange oil seal
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
IdahoDoug
IdahoDoug is offline
PostPosted: Sat Apr 07, 2012 1:06 pm    Post subject: Reply with quote
Andrew - over the heads of what? And what size socket? Thanks.
Also, when you order your seals be sure you are not getting just the little caps that go on the flange, but in fact the real oil seal that goes behind it. Some think it's the cap leaking when in fact it's the seal.
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX
IdahoDoug
PostPosted: Sun Apr 08, 2012 12:25 am    Post subject: Reply with quote
Dylan (or anyone who's done this), I smeared fresh gear oil on my flange seal lips and the flange surface they run against on the first one. But wondered if a thicker grease would have been better. IF they get splashed from inside I would not worry. What did you guys do?
DouM
?Waldo?
?Waldo? is offline
PostPosted: Sun Apr 08, 2012 9:27 am    Post subject: Reply with quote
Sorry Doug, bad post on my part. I had clicked on page 1 by mistake and thought the end of that page was the most recent post. I was replying regarding taking out the screws that hold on the plastic caps of the adjusters. To get them out without any drama, tap a 12pt socket over the head. The size of the socket should be the first size too small to fit over the head without pounding it on.
Andrew
presslab
presslab is offline
PostPosted: Sun Apr 08, 2012 2:51 pm    Post subject: Reply with quote
DouM
Yes, the gear oil is free to lube the seals. When I did mine, the van was slightly tilted to one side and a bit of oil poured out once the seal was removed.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
IdahoDoug
PostPosted: Sun Apr 08, 2012 5:12 pm    Post subject: Reply with quote
Andrew - thanks! Got to use my snazzy new right angle impact screw extractor. I got it for a tough job I'm doing next month on the LandCruiser in tight quarters, but early bonus. Amazing tool for stuck screws of any kind and location.
Presslab - thanks for that input. I'll just oil it as normal for a seal that will get splashed then. If either of you have any assistance on the "Syncro diff lock help" thread, I'm stuck at the moment with some parts I did not expect wanting to come out the side of the diff gear case and don't know if I can pull them out and service the shaft, or not to pull it because something inside will fall off. Thanks!!
Racerrojo
Racerrojo is offline
PostPosted: Wed Nov 21, 2012 6:33 pm    Post subject: Reply with quote
Andrew A. Libby wrote:
Be sure to check that the atmospheric bleed in the top front of the trans is not blocked before starting on this job. If it is plugged (quite common) then it will make brand new seals leak. And if it is plugged and your seals are leaking, unplugging it will often cure the leaking without needing to change the seals.
what does that look like? is it just a small hole?
Ill be doing some RnR under the van this long weekend, the list keeps growing, from a simple rear wheel cylinder replacement to, new clutch (i think my pressure plate is caca). this seals are leaking but I doubt I can fin them locally and thus no time to ship them in.
and since I'll have the trany out...
Tight is tight... too tight is expensive!!!!
Too many vans and mostly all projects Smile
70coupyel
70coupyel is offline
PostPosted: Wed Nov 21, 2012 7:02 pm    Post subject: Reply with quote
Search my brother.
http://www.thesamba.com/vw/forum/viewtopic.php?t=515450
TheAndante wrote:
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc.
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer
Racerrojo
PostPosted: Wed Nov 21, 2012 7:37 pm    Post subject: Reply with quote
yep, I searched on my trany in the garage and found the little hole
AdrianC
AdrianC is offline
PostPosted: Thu Nov 22, 2012 1:53 am    Post subject: Reply with quote
Has anybody had fun'n'games with the grease cap on the inside of the flange? When we replaced the CVs last year, the RH was missing the cap. We replaced it with a new one, but somehow the driveshaft's already eaten it completely - only shreds of the edge remained.
As for those M7 bolts - are they definitely 1.25 thread pitch? If they're 1.00, then I'm happy to act as a middleman for a big bag of whatever length's needed from Citroen parts suppliers over here - they're common on 2cvs, with an 11mm hex head usually.
For eg...
http://www.ecas2cvparts.co.uk/screw-plated-11mm-head-14mm-long-p-1199.html
Adrian
Zookeeper of a miscellany of motoring silliness, from 0.75bhp to 9ft tall.
Living life on the road in an '88 2.1DJ Westfalia Club Joker Hightop.
www.WhereverTheRoadGoes.com
Wildthings
Wildthings is offline
PostPosted: Thu Nov 22, 2012 5:55 am    Post subject: Reply with quote
Are your CV's assembled correctly? Have you checked your axle length? Maybe it has been swapped out for one a bit too long. Has your van been lowered by any chance?
presslab
presslab is offline
PostPosted: Thu Nov 22, 2012 7:47 am    Post subject: Reply with quote
Axle too long (unlikely) or axle not centered in the CV joints (likely). Check the "ribs" on the axle to make sure the same amount is showing on both sides, at the small end of the boots.
AdrianC
AdrianC is offline
PostPosted: Sat Nov 24, 2012 5:47 am    Post subject: Reply with quote
They should be. They were fitted by very Vanagon-familiar people, with the shafts out and on the bench. Circlips are all in place.
Not yet.
No. The one that's having this issue is the RH (non-furniture) side. It was the other side that had a broken pigtail on the coil, too.
Adrian
minsk
minsk is offline
PostPosted: Tue Nov 27, 2012 3:54 pm    Post subject: Reply with quote
has anyone sourced any of the machine screws m7 x 1.0 x 13?
iv looked everywhere on the interwebs...no luck..im redoing a transmission now also and need them
1987 Sunroof Syncro
1988 Vanagon GL
2009 audi a3
www.sunroofsyncro.com
vanagonmechanic.com
http://facebook.com/pittsburghvanagonclub
https://www.youtube.com/minskmade
my super slow 1987 sunroof syncro rebuild
https://goo.gl/photos/7e9MZhHJxGvvv1Tm7
VANAGON STICKERS
https://www.etsy.com/shop/pigeonink
View user's profile Send private message Send e-mail Visit poster's website AIM Address Facebook Instagram Gallery Classifieds Feedback
presslab
presslab is offline
PostPosted: Tue Nov 27, 2012 4:01 pm    Post subject: Reply with quote
You can get a hex head M7x1.0x12 here. Haven't tried it.
http://www.mcmaster.com/#91280A410
I remember ETKA showed a 1.25 pitch but I never actually measured one.
minsk
minsk is offline
PostPosted: Tue Nov 27, 2012 4:11 pm    Post subject: Reply with quote
it is 1.25
i was at fastenal yesterday
we measured it..its a little longer than 13 also
1987 Sunroof Syncro
1988 Vanagon GL
2009 audi a3
vanagonmechanic.com
VANAGON STICKERS
Racerrojo
PostPosted: Sat Dec 01, 2012 7:18 pm    Post subject: Reply with quote
I just did this, but with the tranny on and engine stand ( replacing CV shaft and new Clutch), one of the flanges required a puller, the other one just came off by hand, I swear the hardest thing (besides dropping the trans.) was the stupid cir-clip major PITA and I had the pliers, installing it, was harder.
But any way while I was on that, I noticed a leak on the shift lever seal, and I'll like to replace it while I have every out.
Is this an easy one?
I thought I found a post that detailed the procedure but cant seem to find it.
minsk
minsk is offline
PostPosted: Mon Dec 03, 2012 12:51 pm    Post subject: Reply with quote
so because of the scarcity of m7 x 1.25 13mm.
i retapped the screw holes to m8 x 1.25
and used these screws m8 panhead screws from Mcmaster Carr
18-8 Stainless Steel Metric Pan Head Phillips Machine Screw, M8 Size, 16MM Length, 1.25MM Pitch, packs of 10
Product Number. 92000A526
1987 Sunroof Syncro
1988 Vanagon GL
2009 audi a3
vanagonmechanic.com
VANAGON STICKERS
Bobalos
Bobalos is offline
PostPosted: Tue Jan 22, 2013 6:50 am    Post subject: Reply with quote
good morning folks,
first off, thanks for all the pictures & information, its making this process less painless.
Im replacing the seals on my trans & the plastic piece, that goes over the seal but under the flange that is held on with these two screws, is all messed up. anyone know of a good source to find them? Ive called a few places yesterday, but nobody had any leads for me.
This is the piece Im looking for
thanks
Bob
minsk
minsk is offline
PostPosted: Tue Jan 22, 2013 7:24 am    Post subject: Reply with quote
i was not able to find those either...if anyone know that would be super awesome
1987 Sunroof Syncro
1988 Vanagon GL
2009 audi a3
vanagonmechanic.com
VANAGON STICKERS
Bobalos
Bobalos is offline
PostPosted: Tue Jan 22, 2013 10:28 am    Post subject: Reply with quote
I found them @ Rancho Performance Trans. (714) 680 0126. the person I talked with was Mike & he was very knowledgeable & quite helpful.
they have the OEM plastic ones & metal replacement ones.
Also, Chirco (800 955 9795), can get them, they just dont stock them. sounds like the only ones that they deal with is the metal replacement ones.
& FWIW, I went to my local "I have everything" hardware store (that has never let me down) yesterday & they did not have anything in 7mm but of course had a bunch of 8mm, with the same thread pitch, in just about any head I wanted. running a tap through it was easy peasy. should work fine.
thanks again folks.
Bob
Page 3 of 7
