should almost-new meyle shocks be like this?
wehrbüchse
wehrbüchse is offline
PostPosted: Tue Nov 27, 2012 4:14 pm    Post subject: should almost-new meyle shocks be like this? Reply with quote
Sorry for the noobesque question, but I'm getting different info, I'm at a parts counter out of town and I need informed help.
I recently picked up some "almost-new" 2011-marked Meyle shocks on craigslist. I thought it was weird that when I compressed them that they didn't re-extend as good shocks for my other cars do. I figured it was simply a design difference, and people have said this is fine.
Today I'm being told that no, this is NOT fine.
Please weigh in fellas. Thanks!
presslab
presslab is offline
PostPosted: Tue Nov 27, 2012 4:25 pm    Post subject: Reply with quote
Depends on the design. A nitrogen-charged shock will extend on it's own, as the nitrogen pressure pushes the shaft out.
The Bilstein shocks are nitrogen charged, and the Koni are not. I'd bet the Meyle are not nitrogen charged. Is there any sign of oil leakage around the shaft?
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
Jake de Villiers
Jake de Villiers is offline
PostPosted: Tue Nov 27, 2012 4:45 pm    Post subject: Reply with quote
As above - those shocks are fine.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
wehrbüchse
PostPosted: Tue Nov 27, 2012 4:52 pm    Post subject: Reply with quote
I'm almost 100% certain that these are hydraulic shocks. I can hear liquid moving around when I compress them. They look pretty new but the rear ones compress really easily.
Not one of them re-extends on its own
insyncro
Banned
insyncro is offline
PostPosted: Tue Nov 27, 2012 6:53 pm    Post subject: Reply with quote
Meyle shocks are not charged.
danfromsyr
danfromsyr is offline
PostPosted: Tue Nov 27, 2012 7:30 pm    Post subject: Reply with quote
I love when people tell ya you need gas shocks to give a little lift to your VW... when you can compress them by hand they have maybe 25#'s of pressure... how much VW lift is that Rolling Eyes like having a 10yr old lift the back bumper when driving Laughing
Abscate wrote:
wehrbüchse
PostPosted: Tue Nov 27, 2012 7:32 pm    Post subject: Reply with quote
isn't it the springs that determine ride height?
(...but then bad shocks can cause springs to sag?)
alnvilma
alnvilma is offline
PostPosted: Wed Nov 28, 2012 6:04 am    Post subject: Reply with quote
I put a set of those (non-charged) shocks on my hardtop.
I wanted a less jarring ride similar to the original Boge shocks.
Very nice difference for me after throwing out the Monroes.
Didn't want nor could I afford, Bilstien. I had already used KYB once too.
insyncro
Banned
insyncro is offline
PostPosted: Wed Nov 28, 2012 6:20 am    Post subject: Reply with quote
KYB...aka kill your back Laughing
jackbombay
jackbombay is offline
PostPosted: Wed Nov 28, 2012 7:31 am    Post subject: Reply with quote
Make sure you have the 10 year old lifting the bumper stand on a skateboard or it could be dangerous Wink
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
Wildthings
Wildthings is offline
PostPosted: Wed Nov 28, 2012 7:38 am    Post subject: Reply with quote
All shocks for a VW bus are going to be hydraulic shocks, but some will be gas charged and some will not. The gas is supposed to keep the oil from frothing as it gets hot in use and helps push it through the valves on rebound. Early on, at least, gas shocks had a tendency to leak when they got hot and were subject to sudden failure just when you needed the gas the most, they seem to do much better these days though.
I have found that gas shocks on the front of an older VW will noticeably raise the front end of an unloaded vehicle and have had them negatively effect handling.
