Sliding Window Question (Dogs like air)
Fhak915
Fhak915 is offline
PostPosted: Wed Oct 31, 2012 6:09 pm    Post subject: Reply with quote
Do you have any pics of your work Fhak915 & danfromsyr?
Mzalac,
I have not done it but I did take the sliders apart and modify them for rear sliders. I am very sure I could do it. Was actually thinking doing this since I have an Adventure wagon and the driver sided slider is nonfunctional because it is blocked by the cabinets. Check out my Gallery photos of the rear slider. It is do-able but the lock bar needs to be had from passenger side window to do it right.
Frank
86 AW EJ22
heidi85ho
heidi85ho is offline
PostPosted: Sat Nov 03, 2012 1:01 pm    Post subject: Reply with quote
just thinking outloud.......could you not remove both drivers side and passenger side windows and then re-install the drivers side window on the passenger side, and vice versa? would not then the locking channels be on the bottom and open from the rear?
85 westy-1.9-standard trans, FAS GenV 2.0
danfromsyr
danfromsyr is offline
PostPosted: Sat Nov 03, 2012 1:12 pm    Post subject: Reply with quote
can't flip sides on the 85+ pass side sliding windows (sliding door window) as it's smaller than the drivers side with the new easy handle & mechanism.. so you have to get creative on that..
no pics of the work, just went out and got-r-dun they're really not that difficult to dissassemble and reassemble.. it helps to get a long nuff bar clamp that will also spread to open the frames and to reclose the frame to the glass.
Abscate wrote:
mzalac
mzalac is offline
PostPosted: Wed Nov 28, 2012 11:01 pm    Post subject: Reply with quote
I had my sliding windows reversed.
1989 Westfalia 2.1L OEM
"Life is like a game of cards. The hand that is dealt you represents determinism; the way you play it is free will." Jawaharal Nehru
presslab
presslab is offline
PostPosted: Thu Nov 29, 2012 9:25 am    Post subject: Reply with quote
I removed your other identical posts and left your remaining post here, as it seemed to appy the best. Please don't crosspost, aka post the same thing in multiple threads.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
Camp&Ride
Camp&Ride is offline
PostPosted: Thu Nov 29, 2012 5:04 pm    Post subject: Reply with quote
mzalak - let us know how this turns out. Am wondering about extra noise/water seepage from flipping the windows. Also, any pics of the slider reversal process would be great!
2WD 86 Westy
Zetec Inside
Camp&Ride
PostPosted: Tue Dec 04, 2012 12:32 pm    Post subject: Reply with quote
Similar product now offered from GoWesty:
Rear Sliding Window Assembly (Left Side w/Vent) [Vanagon] *DECEMBER SPECIAL* - $229
http://www.gowesty.com/ec_view_details.php?id=23453&category_id=333&category_parent_id=
2WD 86 Westy
Zetec Inside
danfromsyr
PostPosted: Tue Dec 04, 2012 1:49 pm    Post subject: Reply with quote
$229 is definately closer to where it should be.. a nice price point compared to $399 as originally listed.
as for the reveresed window channel leaking that's a no, there isnt that much hydraulic/air pressure on the side to force the water inside. and the seal channel makes a physical dam to block surface pushed water.
where I had a leak was the new bottom cut in the aluminum channel where I had to shorten it. I was supposed to use some clear silicone in the gap/joint when I put it back together. and either forgot or figured it wouldn't get around the glass. but I've since sealed that cut int he channel with a surface applicaation of silicone. (inside the channel would have been better though).
Abscate wrote:
BC Westie
BC Westie is offline
PostPosted: Tue Dec 04, 2012 5:33 pm    Post subject: Reply with quote
When I picked up one of my van from the body shop 2 years ago after a full paint job they reveresed the windows accidently. I thought well I will live with it and try it out as it does seem logical and gives more air for sleeping.
The only draw back I had was water on the highway would get blown into the van where the slider meets the other piece of glass. I might of needed new felt but I decided to just go back to the body shop and have them flipped back to their normal postion and problem solved. ***This only happened at HWY speeds***
I am a fan of the rear windows to slider conversions.
1980 Vanagon Cali Import 86,000Miles
1981 Vanagon (Auto) 219,000kms
1981 Westfalia (Auto) Cali Import 169,000Miles
1981 Westfalia 300,000kms
1982 Westfalia Cali Import 193,000Miles
1982 Westfalia (Auto) 205,000Kms
1984 Vanagon 306,000kms
1987 Vanagon GL 300,000Kms
jsmitch11
jsmitch11 is offline
PostPosted: Tue Dec 04, 2012 6:04 pm    Post subject: Reply with quote
They are clearing them out because they DO NOT FIT!!!! I have helped install 3 of these windows and they are a major PITA. You have to remove the piece between the plastic vents and the glass and use sikaflex or sealent instead and it stills in incredibly hard. I can't believe they even sell them....if I were them I would be ashamed to put my name on those!
1984 Vanagon Westfalia Syncro Hightop
1986 Vanagon Syncro(RIP)
1989 Vanagon Wolfsburg Whitestar Edition(RIP)
My Van syncro conversion/restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=535730&highlight=black+diamond
syncrodoka
syncrodoka is offline
PostPosted: Tue Dec 04, 2012 6:08 pm    Post subject: Reply with quote
jsmitch11 wrote:
they DO NOT FIT!!!!
Unfortunately I have heard the same.
goffoz
goffoz is offline
PostPosted: Tue Dec 04, 2012 10:21 pm    Post subject: Reply with quote
Well that explains a difficult weekend, I recently experienced.
Told a buddy "Sure I can help you with that, done a few of them"Made me feel like a Dolt.
....thanks GW..suckered again Rolling Eyes
Glad I placed my last order with VC, good cookies Very Happy
mzalac
mzalac is offline
PostPosted: Thu May 02, 2013 2:31 pm    Post subject: Reply with quote
Almost finished with my sliding windows.
Just need to paint my white screen frames black.
So far no extra wind noise or rain leakage.
goffoz
goffoz is offline
PostPosted: Thu May 02, 2013 8:36 pm    Post subject: Reply with quote
Dude ..."black on black",,love it Very Happy
...don't forget...always park in the shadows
Tell us a little about the paint
thanks
dobryan
dobryan is offline
PostPosted: Thu May 02, 2013 8:40 pm    Post subject: Reply with quote
Yep. I could not be in the top bunk in the sun unless I wanted to bake bread....but it's a clean looking bus. Smile
Dave O
The Western Syncro build
nemobuscaptain
nemobuscaptain is offline
PostPosted: Thu May 02, 2013 9:30 pm    Post subject: Reply with quote
Yeah, my first thought was he must live up north, then I saw Waikiki.
That bus must be a damn oven. I don't even like how hot my burgundy bus gets in the sun.
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
mzalac
mzalac is offline
PostPosted: Fri May 03, 2013 10:48 pm    Post subject: Reply with quote
yep, you guys are right.
I should of done what u guys did.
darn it!!!
mzalac
mzalac is offline
PostPosted: Wed May 22, 2013 2:14 pm    Post subject: Reply with quote
Here's my step-by-step:
nemobuscaptain
PostPosted: Wed May 22, 2013 4:35 pm    Post subject: Reply with quote
You know you can have just switched the driver's and passenger's side, right?
Maybe I'm missing something. How hot does that bus get inside?
danfromsyr
PostPosted: Wed May 22, 2013 4:42 pm    Post subject: Reply with quote
you can't swap side to side on the 85-91
the slider door window is smaller than the DS sliding window.
so you have to dissassemble and swap the parts. w/o the latch ending up on the top.
Abscate wrote:
Page 2 of 4
