Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Sat Feb 07, 2009 6:50 am Post subject: |
I might have some spare parts for the stc. I would have to look around.
Mike _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
thinghunter Samba Member
Joined: May 18, 2004 Posts: 403 Location: North Texas
Posted: Sat Oct 10, 2009 7:10 pm Post subject: |
Just came across this while looking for some Jeep bumpers for my son's off road beater Thing. At first I thought it was a kit but apparently it's a bumper with this attached. Actually I found where it's a retro kit for under $300. I'm thinking about doing something like this and trying it out. I like how it doesn't attach to the body in any way (other than the bumper mounts that are just part of the body). What do you guys think?
http://www.protofab4x4.com/products.php?ID=00&ID2=32 |
yellow73kubel Samba Member
Joined: August 17, 2008 Posts: 789 Location: Columbia, SC
Posted: Sun Oct 11, 2009 11:05 am Post subject: |
^ Works a lot better on the Jeep with a heavy duty bumper attached to the frame itself. Remember that the body sheetmetal would have to support 100% of the spare tire and bumper weight, which gets a lot heavier bouncing around offroad.
It would work pretty well if you could find a way to tie it into the frame. Or possibly some plates to spread the load. |
Chris181 Samba Member
Joined: April 05, 2004 Posts: 90 Location: French riviera
Posted: Sun Oct 11, 2009 11:12 am Post subject: |
I think it's a good idea with the bumper and a hitch trailer together for support the spare tire. _________________ __________________________________________
Chris.
http://vwandco.wifeo.com/
Thing '73 IRS conversion
Eurovan VR6 LPG |
kubelmann Samba Member
Posted: Sun Oct 11, 2009 12:25 pm Post subject: |
I just pulled a spare tire holder from a 86 Bronco II that I plan to modify to work on a Thing. |
Triple B Samba Member
Posted: Tue Oct 13, 2009 1:30 pm Post subject: |
Here is mine....
I will look for some better pics
There is a 5 gal gas can behind the tire and a 2" hitch below
sixty9fasty Samba Member
Joined: April 12, 2004 Posts: 1066 Location: crockett, ca
Posted: Tue Oct 13, 2009 3:04 pm Post subject: |
Just picked my Thing up last night, and it has a pretty interesting set-up on it.... mostly looks home made....
Pic I took last night, it's raining cats and dogs right now, I'll try and get a better pic for ya'll later when the rain stops...
FlowerPowered Samba Member
Joined: December 22, 2005 Posts: 389 Location: Montana
Posted: Tue Oct 13, 2009 9:08 pm Post subject: |
lukesky wrote: |
Does anyone out there have the spare on the front or the hood? |
Here is my custom built front mount from a post earlier this year:
http://www.thesamba.com/vw/forum/viewtopic.php?t=350780&highlight=spare+tire
I like the front mount because:
- It's mounted solely to the bumper, no sheet metal is molested.
- I adds a little better weight distribution.
- Makes me imagine I'd do better in a front end collision(purely speculation)
- Gives an even MORE unconventional look to an already unconventional looking vehicle. |
strelnik Samba Member
Joined: October 01, 2010 Posts: 352 Location: Michigan
Posted: Mon Oct 04, 2010 5:45 pm Post subject: |
vwthingboy wrote: |
This carrier was a unique one that surfaced at the German Motor works show 2005 and got posted in the Gallery.
It attaches to the bumper and one spot on the deck lid:
https://www.thesamba.com/vw/gallery/pix/206844.jpg
and open:
https://www.thesamba.com/vw/gallery/pix/206886.jpg
I like how the license plate holder is in the spare,
and the angle of the tire seems to match the decklid angle.
Nice work, and I assume it must be a custom one-off.
Looks like the car previously had the TS tire carrier, btw.
I know, it's not an ideal setup for engine access,
but maybe the owner puts a cushion on there and sits native-american style. |
I am restoring a Mercedes 220 (1953) allegedly owned by Groucho Marx and the add-on external spare tire carrier was part of the accessory package which the MB dealer added. Very similar |
deitymotorsports Samba Member
Posted: Sun Apr 29, 2012 7:19 pm Post subject: tire carrier bolts |
I have a simple question. I have the standard style rear tire carrier. And it came to me in pieces. I'm missing the proper bolts that mount the main arm to the upper bracket and lower to the bumper. This is were it pivots on. Looks like it has to be a shoulder style bolt so the carrier can swing without binding. Anyone have the proper set up or what they used? It's quite a large bolt and it cannot be that long were it goes through the bottom bumper otherwise it will hit. thanks. |
Semper_Dad Samba Member
Posted: Mon Apr 30, 2012 8:21 am Post subject: |
This is from the original broshure that VWoA put out with the rack. Doesn't have the bolt sizes. I think the bottom pivot is setup the same as the top.
_________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
jjrannauro Samba Member
Posted: Mon Apr 30, 2012 10:22 am Post subject: |
FlowerPowered wrote: |
lukesky wrote: |
I agree with you for all the reasons you mention. I like it best. I'm thinking to do the same. In Mexico many Combis (VW Bus) used to carry the spare tire at the front. Greetings |
Posted: Mon Apr 30, 2012 10:45 am Post subject: hardware |
ok. thank you. thats what i was making actually. thanks. |
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Thu Dec 20, 2012 1:04 am Post subject: |
I have a rear tire carrier, that I have had for 10+ years, never mounted it. finally found another 15" centerline copy, so my spair will match. going to buy another engine cover(so I don't mess my OG paint one up) I have the thing shop repro, powdercoated silver. going to cut a large hole in the engine cover for cooling. I made bigger backing plates a few years ago, hope they help with the stress of the weight. will still carry 14" spair up front, I have one of the gas cans that fits in the spair.
THOR |
ghia4me Samba Member
Joined: December 11, 2003 Posts: 67 Location: Savannah, wish it was margarittaville
Posted: Thu Dec 20, 2012 7:00 am Post subject: little off topic - hey but so are others |
what do you all think of a tire recessed into the front hood???
Is there enough space ???
does this have any advantage - other than it COULD look cool??
I have 2 ideas of how to drain the water ----- and one would leave the spare and tub mounted to the trunk floor and the hood would have a large hole trimmed out to go over the spare (like a shaker scoop)
_________________ 914 ChumpCar endurance racer
WWW.CHUMPCAR.COM
1977 911 - 3.0 liter
In Sunny Savannah, GA |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Thu Dec 20, 2012 11:22 am Post subject: |
If you go to my photo's you will see my tan car. I used a trunk area from a Dodge Omni. The space is limited. The drain is a funnel setup in front of the gas tank. Keep in mine that you will not have a place for the curtains. |
Posted: Thu Dec 20, 2012 11:40 am Post subject: |
Ron Domeck wrote: |
I concur, well done
VW Addict Samba Salesman
Posted: Fri Dec 21, 2012 11:02 am Post subject: |
Here is a picture of mine: I relocated the license plate on the left side bumper-- with plate light!
driftman11 Samba Member
Joined: August 01, 2012 Posts: 141 Location: little rock,ar
Posted: Tue Feb 16, 2016 7:13 am Post subject: Re: Rear Tire Carrier |
I know I am resurrecting this thread from death but I was wondering if anyone could give me some of the basic measurements for this tire carrier? I think I can fab one up if I had some measurements to go off of. |
