jspbtown Samba Member
Posted: Tue Jul 26, 2011 10:03 am Post subject: Dust cap |
I have a set of front disc brakes on my Avenger:
I can't for the life of me find a dust cap that will fit the drivers side. I bought one from BugCity at a show and he said it was for all Beetles. it didn't work. I thought maybe one from a link pin version (which slides inside the hub versus over the top like the later versions) might work but thats a no go.
Any idea what application might fit? I replaced the calipers with the VW replacement versions so I am assuming its VW based. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Tue Jul 26, 2011 6:21 pm Post subject: |
Strange that the rotors look like Ghia rotors, which would lead one to presume that the Beetle drum/Ghia rotor dust cap would fit... hmmm....
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Tue Jul 26, 2011 6:45 pm Post subject: |
Do you have any measurments? _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
Posted: Tue Jul 26, 2011 7:22 pm Post subject: |
Pull the speedo cable back in far enough on left rotor so that you could try the right side cap on the left rotor...
And measure the bore ID of both rotors -
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Tue Jul 26, 2011 9:20 pm Post subject: |
comin with some of the replacement rotors/drums, I have seen this problem before how far off is it? mine I put on A piece of wood and tapped it with A hammer, to oblong it A little, worked grate! but mine was not that far off.. you can stretch it over A piece of pipe, put some spot welds on it, the list gos on.. good luck _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Posted: Wed Jul 27, 2011 6:10 am Post subject: |
The cap on the right slides over the center of the rotor. It does not tuck inside. It looks similiar to the one I got for the left except the one for the left does not have a small relief cut on the side of the cap that the right one does. I have not tried to see if the right works on the left yet.
The outer part of the center of the rotor is tapered. No matter how hard I smack the left cap it won't stay on. Its not even close. The cap is smooth on the inside and the center section of the rotor is tapered. You guys can imagine how that won't work. There is nothing for the cap to grab and it can't be help on by pressure because the more you tap it on the harder it wants to pop off.
I will get some more pics tonight. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Wed Jul 27, 2011 2:58 pm Post subject: |
I ran into this on 3 disk conversion kits. It was not the rotor, it is the caps that are made wrong. If you have an original from the drum setup it will work. For my last one I just attached it with a bead of silicone. Strong, seals out water etc, easily removable. Just noticed you say your rotor is tapered. I did not have any taper. Is it tapered a lot? _________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone |
Posted: Wed Jul 27, 2011 6:14 pm Post subject: |
Well...problem solved.
In went out to measure the taper and much to my surprise there was a flat section on he rotor before it tapered. So I took my digital caliper and measured the rotor. I then measured the ID of the original cap I bought.
The rotor OD was 3/4 of mm larger that the ID of the cap.
A little sandpaper to take the paint off the rotor...a little sanding drum to the inside of the cap...and viloa! It tapped right on.
Thanks guys. The project gets a little bit closer to being done |
sandslinger79 Samba Member
Joined: March 24, 2007 Posts: 20 Location: Summerville, SC
Posted: Wed Jan 02, 2013 12:13 pm Post subject: |
jspbtown wrote: |
What size diameter is that dust cap? _________________ 1973 Baja |
