Any usual suspects? Wet floor...
Weevil_Kneevil
Weevil_Kneevil is offline
PostPosted: Sat Jan 19, 2013 8:44 am    Post subject: Any usual suspects? Wet floor... Reply with quote
Took a drive this afternoon to go hunt for a cooling tin... In the pouring rain. When I got back home, I noticed that under all my carpets, both sides, front and back, the padding is soaked??? Looked under the car, I saw no real possibilities for a leak? The pan seems ok? Also, the rubber seal between the car and the pan is in place?
Are there some usual suspects to go look up first here? Or is this gonna be a hunt for a tiny hole / crack?
Still raining outside, so maybe I can gather some digital wisdom prior to getting under the car...
Current :
- 70's 1600 Single Port
Past :
- 1600 TP
- 89' 1800 Golf Sport
- 80's Porsche 924
- 70' Mercedes 200
- 85' Mercedes 200
early
early is offline
PostPosted: Sat Jan 19, 2013 9:21 am    Post subject: Reply with quote
check the front windshield and rear window seals. sometimes they leak. or the drains from the windows leak. under the back seat near heat channels leak as well if rusty
early-
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn
03 BMW R1150RT
davidw99
davidw99 is offline
PostPosted: Sun Jan 20, 2013 5:59 am    Post subject: Reply with quote
Common culprit is the corner of the windshield seals. Next ime you are out in the rain keep an eye on these. A small trickle can add up to a lot of water.
Dave
'73 Saturn Yellow Sports Bug that has undergone a full pan off restoration. "Herbert IV."
'67 Sedan. "Bellamy." Currently being "refreshed."
74superTN
74superTN is offline
PostPosted: Sun Jan 20, 2013 6:46 am    Post subject: Reply with quote
Antenna seal, Behind Door panels, Window Seals...those are all my culprits for my 74
73 Thing
80 Vanagon Westy
2016 Golf Sportwagen
baxsie
baxsie is offline
PostPosted: Sun Jan 20, 2013 10:03 am    Post subject: Reply with quote
Be sure all the drains are functioning. For instance, if something leaks in the antenna hole, it should drain out below the lower door hinge.
http://www.thesamba.com/vw/forum/viewtopic.php?t=483962&highlight=drain+locations
There are also some drains in the doors.
I think there are several drain points in the car. Basically anywhere water could puddle will have a drain (except for the floor pans).
1975 LaGrande Super Beetle Build Log / Farm boy hinge pin puller / Farm Boy Chassis Rotisserie
"I'm not getting older, I'm getting bitter."
Weevil_Kneevil
PostPosted: Sun Jan 20, 2013 10:29 am    Post subject: Reply with quote
Ok, big issue was trickle of water on my front window, in the corners. Runs seemingly behind the dash, then to where? Somewhere leak onto the floor.
I'll be taking out the window in a day or two. Re-install, try get it sorted out.
Bought the car with what seems to be a new rubber on the window, but also a ton of silicone.
Current :
Past :
- 1600 TP
- 80's Porsche 924
- 70' Mercedes 200
- 85' Mercedes 200
68IHscout
68IHscout is offline
PostPosted: Sun Jan 20, 2013 10:40 am    Post subject: Reply with quote
also the front drain tube from fresh air vent was plugged with debri,and dirt ...74sb
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Jan 20, 2013 11:25 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=539338&highlight=windshield+drain
In Stereo, Where Available!
Tim Donahoe
Tim Donahoe is offline
PostPosted: Sun Jan 20, 2013 4:56 pm    Post subject: Reply with quote
I have found that sitting inside the car while a partner hoses the car down will tell you where the water is coming from.
Of course, have the assistant squirt in one area, then move on to others.
Tim
Joey
Joey is offline
PostPosted: Sun Jan 20, 2013 5:25 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/archives/manuals/looklisten_9.php
Joey
60 Kombi - '74 Bus - '79 Panel - '56 Beetle - '65 Beetle
vintagevdubbers.ca
Weevil_Kneevil
PostPosted: Mon Jan 21, 2013 12:01 am    Post subject: Reply with quote
I think the biggest issue I have at the moment is the trickle / small stream of water on the insides, in the bottom corners of the windshield. Runs into the big hole / gap, then I assume down the A pillar. There is some evidence of rust on the inside of the car under the carpeting. Then into the heater tubes? Out the vents, and onto the floor? Sounds possible right?
I'm going to remove all the carpeting in a few minutes (Sad ... car has brand new interior... seats .... carpets ... roof lining ....) And track and trace.
Thanks for the above links. Made for good reading!!
Current :
Past :
- 1600 TP
- 80's Porsche 924
- 70' Mercedes 200
- 85' Mercedes 200
Eric&Barb
PostPosted: Mon Jan 21, 2013 7:34 am    Post subject: Reply with quote
Ding, ding, ding!!! Wink That is what we found out ages ago with our type 1s in our rainy PNW of USA weather. New seals need sealant between body and seal, just as VW shows in all dealer info.
