joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Mon Apr 16, 2012 9:07 am Post subject: 1 LB bottles |
Timwhy wrote: |
Are you minus a fridge? Or, did you just not want to run another line for it?
Nice install! |
I use 1LB bottles to run my stove. Went to our RV dealer, he said it is illegal to use rubber hose in a RV for propane . Went to Ace got a flaring tool some copper line , a couple of fittings, new 2 stage valve . And in 30 min all done! _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Sun Apr 22, 2012 8:24 am Post subject: |
I noticed this old thread got revived recently. Here is a picture of what I came up with back when I started this thread a few years ago. I have never used it, but carry it along anyhow. Our stock tank would easily go two weeks or more with a good fill using the fridge 24/7 and the stove twice a day. I installed an Espar for heat, so I believe we have the propane supply covered for now. At the time of this post, I felt I would not have the stock tank completed and reinstalled and was working for a temporary solution. I work well with deadlines though and got the stock tank finished. mark
_________________ ☮️ |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1867 Location: Pittsburgh PA (ish)
Posted: Sat Jun 30, 2012 7:47 pm Post subject: |
Sorry to bring back an old thread, but does anyone know of where i can source online the necessary parts to run my westy stove entirely off a 1lb cylinder?
As in, I don't have any of the other pipes or existing tank in place, nor do I want to.
I understand a regulator with a hose, with a 3/8'' (???) pipe thread fitting on one end, and a 1''-20 fitting on the other? |
Timwhy Samba Member
cris torlasco Samba Member
Joined: November 08, 2000 Posts: 1363 Location: Delmar, NY/Buenos Aires, Argentina
Posted: Sun Jul 01, 2012 11:53 am Post subject: |
Great thread. I only need propane for the cook stove (electric fridge and diesel stationary heater), so it doesn't make sense for me to carry that heavy and rusty propane tank everywhere. I will give the cartridges a shot and try to take go from "disposable" to "reusable".
On a side note, I have not been able to find a small, refillable propane bottle in this country. Does anyone know of one? 2 pounds or so?
Cris |
Wolfram Samba Member
Joined: June 23, 2005 Posts: 184 Location: Waiheke Island/On The Road USA
Posted: Sun Jul 01, 2012 2:00 pm Post subject: |
5Lb is the smallest I have found. We have a 5 and a 10. They cost the same as a 20 though.....
It's nice to have compact cylinders as they store easier.
Geoff
McLean
VA |
Posted: Wed Jul 25, 2012 8:22 pm Post subject: |
I was able to get all the parts to effortlessly convert my stove to 1lb cylinders from walmart.
I'm now somewhat concerned with potential offgassing in the vehicle though..... |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Mon Feb 04, 2013 4:39 pm Post subject: |
izzydog wrote: |
I put a T fitting BEFORE the regulator (at the tank) so that I can screw in my locally made 1 lb bottle adapter hose ($40) OUTSIDE the van to have a back up propane supply. You don't need to add another regulator if you do it this way. 3 feet of hose is enough to reach the ground and stand the 1lb bottle upright. |
Can you post a photo?
[/quote]
Many thanks.
D _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
izzydog Samba Member
Posted: Mon Feb 04, 2013 4:45 pm Post subject: |
Sure thing. I'll take a pic tomorrow of the tank setup and the 3 ft hose I had made. Cheers. |
Posted: Mon Feb 04, 2013 7:14 pm Post subject: propane tank |
Just thought I would throw this out, most states are requiring a two stage regulator! Some of the old pictures show the old single stage regulator. This is the new one. Better to be safe then sorry! Parts also at Ace Hardware . _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
Posted: Thu Feb 07, 2013 1:22 pm Post subject: |
Hey DeadSetMonkey,
Here's the pics of the "T" in my propane line that I use to attach a short hose for a 1LB propane bottle and back up my tank when it runs out in the middle of nowhere.
The "T" is plumbed in before the regulator and after the valve. The added length of the "T" will extend the whole enchilada about 4-6 inches which you can compensate for by bending your copper propane line a little to fit. I don't have a propane fridge anymore so I tossed the old copper line and now use high compression hose and good, stainless hose clamps (non-perforated) - works great.
The "T" fitting in the photo looks "flat" from that angle, but it is shaped like a "T". That square bit in the center is the cap/plug that you remove to screw in the male end of the 1LB bottle hose (third pic). The fourth pic shows the other end of the hose (female) which screws into the 1LB bottle.The square nut makes it easy to get it off with an adjustable wrench.
I had the hose made up for me at a local propane place that services home propane tanks. They will sell you the "T" as well. I don't know the thread and fitting size so bring the van with you when you go.
When you run out of propane, you just undo the square plug, screw in the 1LB hose, screw in the other end to you 1LB bottle and Bob's Your Uncle - yer back in business!
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
Posted: Thu Feb 07, 2013 1:38 pm Post subject: |
Or you can just use this, no need to change the gas plumbing.
It's great for long stays.
You can get different hoses if you just want to use 1lb bottle. Although for "truth in advertising" not sure if the 1lb bottle has enough pressure to overcome the valve. _________________ Currently:
Posted: Thu Feb 07, 2013 1:51 pm Post subject: |
That's one of the reasons that I used a "T". I wasn't sure whether how a 1LB bottle would affect the big filler valve.
I was also taking out my propane fridge so I had to mess with the plumbing anyway... |
Posted: Thu Feb 07, 2013 2:43 pm Post subject: |
MsTaboo wrote: |
You can get different hoses if you just want to use 1lb bottle. Although for "truth in advertising" not sure if the 1lb bottle has enough pressure to overcome the valve. |
Where did you get the above hose? Thank you. _________________ ☮️ |
Posted: Thu Feb 07, 2013 3:53 pm Post subject: |
izzydog wrote: |
Hey DeadSetMonkey,
Thanks! _________________ ----------------------------------------------------
Posted: Thu Feb 07, 2013 5:03 pm Post subject: |
rsxsr wrote: |
Where did you get the above hose? Thank you. |
The hose is readily available from any camping/gas supply store. The important bit is the brass adapter that fits the vehicle tank. That you have to get from a propane store/pro that sells fittings. About $24. _________________ Currently:
Timwhy Samba Member
Posted: Wed Apr 03, 2013 12:40 pm Post subject: |
Post a picture when you are done. Hard to tell from the website what the fill tank valve adapter looks like. _________________ ☮️ |
Timwhy Samba Member
Timwhy Samba Member
