sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2006 Location: Texas
Posted: Tue Jan 29, 2013 8:33 pm Post subject: Front end damage? |
So after removal of my front fenders, I'm noticing a possible reason why my hood never had a clean seal. After scraping off some of the factory undercoating, I noticed some rust lines where it appears the front end was hit (albeit not that bad, really). The factory paint has cracked off in these 2 areas (see black and red arrows in the first picture). There's also some kind of dimple effect where the apron meets the body at the top (green arrow). My question for anyone with bodywork knowledge is this: Being a novice at any kind of body work, does this look like it warrants some type of pulling out by a body shop? I should also point out that the left half of the apron is pushed in about 1/2-3/4"....and I'm considering replacing the apron altogether because at least one of the front bumper mounts needs to be replaced.
Any advice or input would be greatly appreciated.
_________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
sleepywiesel Samba Member
Posted: Tue Feb 05, 2013 4:47 am Post subject: |
Here you can see the front quater panel of my '60 beetle. The front was also slightly damaged. But I could hammer it out. You see the Quaterpanel has some pressings and is not flat.
Your black pointed line is for the sparetire. The old tires back in the fifties and sixties were bigger than the new tires today. So this "Dent" is stock to make space for the spare tire.
But the other pressings seems to be "enlarged" a little bit. Would be a challenge to make them smooth again.
You could try to bolt the bumperholders on the car and connect them with a strong beam.
Then bolt the body back onto the pan and put a car jack between the beam and the frame head. But be careful with it. Just put a bit stress on the construction. Then you could try do hammer and dolly it out.
The section pointed by the green arrow should be removed easily.
Replacing always should be the last option.
_________________ ________________________
'59 beetle
'60 beetle |
superdude72 Samba Member
Joined: January 18, 2012 Posts: 244 Location: United States
Posted: Tue Feb 05, 2013 12:32 pm Post subject: |
Definitely got a little bit of damage there. You can try and straighten it yourself with a hammer and dolly. Also an oxy/actlyne torch heated in dime size spots for a couple seconds and then tapped with a hammer can help the metal form back into its original state. Sort of a metal memory.
Otherwise, devise a way to pull on the front while you tap on and around the creases. |
therealfrogman Samba Guitar Hero
Joined: October 23, 2007 Posts: 666 Location: Pueblo, Co
Posted: Tue Feb 05, 2013 2:14 pm Post subject: |
Very similar to what I have with my 65, I have tried pulling and heating those areas but I think mine is much worse and my body skills are just building up.
If that was mine I would pull the front section off and work it without it, however, I am just speculating on the outcome, the problem I see are the rust spots and the aftermath.... Everytime I start something like this I end up buying new steel so just ignore me please! I enjoy these learning threads and have very little to offer as far as quick fixes.
Everything I know I learned here and or by trial and error, and here _________________ 73 Camper Tin Top/Type 4 1.8 engine, Single progressive EMPI carb, electronic ignition SVDA W/ Vacuum.
Really appreciate what Everett has done here. Almost like he hand picked some of you. I am very thankful for all the help I get here. |
Posted: Tue Feb 05, 2013 2:15 pm Post subject: |
Thanks for the suggestions, guys. I'll definitely try some gentle "persuasion" to start with, as I don't want to "f" it up worse. From a glance, the lines are actually fairly straight, but the hood doesn't close as straight-on as it should. I don't have a lot of bodywork experience, so I'm a little apprehensive about doing worse damage to it... _________________ .
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Tue Feb 05, 2013 3:40 pm Post subject: |
2-3 lb hand sledge & dolly. You can't hurt inner fenders! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
luizzsf Samba Member
Joined: November 25, 2012 Posts: 34 Location: San Francisco
Posted: Wed Feb 06, 2013 6:03 pm Post subject: |
Any pics of how a straight front looks? |
Posted: Wed Feb 06, 2013 7:15 pm Post subject: |
I think this is a straight front! _________________ .
Posted: Thu Feb 07, 2013 2:28 pm Post subject: |
sportin-wood wrote: |
I think this is a straight front! |
Yes, this is the straightened front of my 60' bug. You can still see some small dents there. But it works _________________ ________________________
'59 beetle
'60 beetle |
Posted: Thu Feb 07, 2013 3:39 pm Post subject: |
It actually doesn't look too bad! Besides, as long as it works good, with the fender on, no one will be able to see any imperfections. _________________ .
