busdaddy Samba Member
Posted: Thu Sep 20, 2012 7:54 pm Post subject: |
Sorry, didn't notice the subject.....so is it at least a fine exotic hardwood like Ash or Maple?, or just lumberyard crap? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Muthashabubu Samba Member
Posted: Thu Sep 20, 2012 8:41 pm Post subject: |
busdaddy wrote: |
Sorry, didn't notice the subject.....so is it at least a fine exotic hardwood like Ash or Maple?, or just lumberyard crap? |
No worries. Honestly, I hardly ever look at the subject either.
And it just seems like a piece of crap. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Fri Sep 21, 2012 6:23 am Post subject: |
Muthashabubu, so you bought this bus without first looking underneath it? _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Fri Sep 21, 2012 11:51 am Post subject: |
Joey wrote: |
Muthashabubu, so you bought this bus without first looking underneath it? |
Nope, I looked. I bought it how it is. And cheap. I'm not looking to restore it, just drive it. Once I get a running engine together. |
Montana74 Samba Member
Joined: November 22, 2011 Posts: 410 Location: Montana
Posted: Fri Sep 21, 2012 1:38 pm Post subject: |
Does NOT fixing anything count??? My BUs needed pretty much Everything fixed. Especially the Aquarium quality tubing for vaccuum lines, and the feul line going across the engine tin w/ no gasket as well. Yes, the fuel line was cut half way through!!!
_________________ 1974 Standard Beetle. |
Posted: Sun Sep 23, 2012 11:58 pm Post subject: |
Montana74 wrote: |
Does NOT fixing anything count??? My BUs needed pretty much Everything fixed. Especially the Aquarium quality tubing for vaccuum lines, and the feul line going across the engine tin w/ no gasket as well. Yes, the fuel line was cut half way through!!! |
Good save! How long did you own it before you noticed the fuel lines? |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Sep 24, 2012 6:52 am Post subject: |
aircooledguy wrote: |
I bought this . . .
and found this.
Perfect. |
At first site I would have said, "next". _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
1967250s Samba Member
Posted: Thu Feb 07, 2013 9:24 pm Post subject: |
What do you expect from the great northwestrainforest? :lol: It can be saved, we have the technology! |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Sat Feb 09, 2013 8:22 pm Post subject: |
Never buy a bus with a bra on it... 2" thick Bondo.
Found this gem in a dealer's back lot in Beaver, PA around '89 or so. Type 1 motor, no key (nice hot switch panel, though) and a Stewart-warner tach planted in the clock hole. 3x3 steel rear bumper w/ hitch, I used it to tow my '70 Ghia vert down to Florida. The drivetain lived on to power a friend's cherry bay Westy he found without eng/trans.
_________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
CessnaJon Samba Member
Joined: August 15, 2008 Posts: 677 Location: Senoia,GA
Posted: Sat Feb 09, 2013 8:31 pm Post subject: |
Nice mullet! _________________ 1973 Westy (shared birthday)
1990 Westy Multivan
2015 Passat TDI 6sp
2015 Sportwagon TDI 6sp
LR-JET, Gulfstream 159 |
Hefner Samba Member
Joined: March 07, 2012 Posts: 230 Location: North Coast, NSW, Australia
Posted: Sun Feb 10, 2013 5:02 am Post subject: |
Downunder we have a nickname for this sort of thing, It's called Bush Mechanics, My Dad was a terrible bush mechanic. Things like zip ties as throttle linkages, Plastic real estate signs to support rusty floors.
I mentioned to him that my rearseat 'Interior Trim' card kept falling off my 69 bug and when I got home from school he'd fixed it by screwing it in and the screws were sticking through to the outside.
I seriously learnt 'everything not to do' from my old man, he was a great teacher. Nowadays he comes other and watches me in my workshop, I carefully lay everything out, use correct parts, research everything first. If I stuff up I always think of my dad! lol
Here is an Aussie TV series called Bush Mechanics and you'll get an idea where the name came from
http://www.youtube.com/watch?v=H-tsKPlDn7U _________________ 1956 RHD Oval.
www.chrisgentle.com
www.customstreeter.com |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Wed Mar 26, 2014 10:36 am Post subject: |
I honestly don't mind the fuel sender access panel if it's done well, but this is just too much:
_________________ 1976 Westy
1966 Beetle |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Tue Apr 29, 2014 3:00 am Post subject: |
Bump!
From the gallery of this fellow- FlyingCoyote!
Bullets as fuses, didn't the Myth-busters do this one already? |
oc92 Samba Member
Posted: Thu May 01, 2014 10:39 pm Post subject: |
I believe the worst fixes to be no fix at all. Neglect kills VWs. From rust, to valves to leaking seals to oil changes... doing nothing does the most hands-down. _________________ " ... he walked the pavement of the city- a beggar and a king. Has it been otherwise with any man?" WOLFE
72 bus
70 bug
96 mx5 |
Posted: Tue May 06, 2014 5:57 am Post subject: |
oc92 wrote: |
I believe the worst fixes to be no fix at all. Neglect kills VWs. From rust, to valves to leaking seals to oil changes... doing nothing does the most hands-down. |
Mmm, quite true, quite true. One of the more interesting ones being the effect water has on a mag case, can you say- Wet kitty litter!?!
Busman1985 Samba Member
Joined: May 24, 2017 Posts: 67 Location: Cleveland GEORGIA
Posted: Thu Aug 10, 2017 7:08 am Post subject: Re: The Bad and Ugly (Worst Home Repairs to a VW bus) |
How do you like previous owners sway bar? I laughed when i bought this 74 and brought it home and climbed under it. And no I didnt drive it with this rebar sway bar, it hasn't ran since i purchased it.
cmonSTART Samba Member
Posted: Thu Aug 10, 2017 8:32 am Post subject: Re: The Bad and Ugly (Worst Home Repairs to a VW bus) |
That probably cost more for the welding wire than it did for the rebar to make it. _________________ '78 Bus 2.0FI
de K1IGS |
Just us buses Samba Member
Joined: April 27, 2004 Posts: 195 Location: Where the nuthatch winters
Posted: Thu Aug 10, 2017 4:28 pm Post subject: Re: The Bad and Ugly (Worst Home Repairs to a VW bus) |
I think the mud wasp egg cases are helping hold that together. You know, 30 or 40 yrs. ago these cars were cheap, disposable even. A lot were owned by poor people who did whatever they had to in order to keep going. I'm afraid of seeing something I used to own here. LOL _________________ It doesn't matter where you start, it all comes together; it all falls apart. |
