ARMc Samba Member
Joined: February 10, 2012 Posts: 116 Location: Wisconsin
Posted: Sat Feb 09, 2013 3:55 pm Post subject: Weak seat belt return. |
Both my vans have really weak seatbelt return. I'm always closing it in the door... I did a brief search here and found little. Is there a simple spring or part to replace in these or is it the whole unit? Anyone tackled this minor annoyance without spending the 120$ each on new ones? |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2238 Location: Olympia, Washington
Posted: Sat Feb 09, 2013 5:12 pm Post subject: |
Its a flat coil spring inside the casing. If you open it . . . SPROING! You'll get cut up. You can buy replacements online from GW. I just toss mine in behind me when I get out. _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
ARMc Samba Member
Posted: Sat Feb 09, 2013 5:39 pm Post subject: |
Ho hum. Well thanks for saving me from a trip to the hospital. |
Altoona Samba Member
Posted: Sat Feb 09, 2013 7:04 pm Post subject: |
Pull the belt all the way out, wipe it down with a mild soapy solution (I like a little Woolite in warm water) and let dry completely. Now unscrew and clean the metal retention bar behind the galley (if you have a full camper). Clean the gunk off this bar and polish it up.
Doing this will work wonders on the action of the belt. |
Californio Samba Member
Posted: Mon Feb 11, 2013 10:00 am Post subject: |
Brand new GW seat belts are weak too. Just the design I guess. |
Red Beard Samba Member
Joined: May 09, 2006 Posts: 463 Location: Seattle, WA
Posted: Mon Feb 11, 2013 5:48 pm Post subject: |
I took the plastic housing off mine and saw that there was a twist or two in the belt inside the housing, making the diameter of the roll so large it was dragging on the housing---->weak seatbelt return. I pulled it all the way out slowly, then slowly let it rewind while correcting the twists. Works great now. |
BCWesty Samba Member
Joined: September 06, 2008 Posts: 165 Location: victoria
Posted: Mon Feb 11, 2013 7:37 pm Post subject: |
Spray some silicon spray on the belt. Works good. |
