whynotvw Samba Member
Posted: Thu Feb 14, 2013 9:54 pm Post subject: Aluminess Box with Gowesty swingout and Swag bin, pictures |
Gowesty swing out with custom bracket to fit Aluminess Box/galley. Great for hauling Honda inverter or other stuff.
syncromike Samba Member
Joined: November 14, 2011 Posts: 660 Location: Boise, ID
Posted: Fri Feb 15, 2013 12:12 am Post subject: |
nice tip! Did GoWesty make your custom mount or is it a DIY? I've got that bumper and swingarms on my GW wish list and was just thinking the other day how I could securely store a Honda 2000i on the tray they had. _________________ _____________________
'91 Syncro w/ Country Homes PopTop |
Posted: Fri Feb 15, 2013 1:18 am Post subject: |
| syncromike wrote: |
| nice tip! Did GoWesty make your custom mount or is it a DIY? I've got that bumper and swingarms on my GW wish list and was just thinking the other day how I could securely store a Honda 2000i on the tray they had. |
Thanks, I made my own mount. |
Jeff's Old Volks Home Samba Member
Joined: December 19, 2011 Posts: 819 Location: Chester Basin, Nova Scotia
Posted: Fri Feb 15, 2013 4:10 am Post subject: |
Are both your tail lights visible? or is just a camera angle that obscures them...
Jeff |
1621 Samba Member
Posted: Fri Feb 15, 2013 5:19 am Post subject: |
| Jeff's Old Volks Home wrote: |
Jeff |
I was going to ask the same, particularly with bikes. You may consider adding a third brake light to the upper window. Otherwise, it all looks tidy. _________________ '85 Westy |
Posted: Fri Feb 15, 2013 8:33 am Post subject: |
Jeff |
Its visible. I have the third tail light, I just need to install it. |
rumitcu Samba Member
Joined: February 12, 2008 Posts: 97 Location: Boulder, CO
Posted: Fri Feb 15, 2013 10:44 am Post subject: |
Saweet!
Here is a tangential question: do you notice any significant flex in the GW bumper/hitch from the lever arm of the bike rack? I have the 4-bike version of that on the GW stand-alone hitch, and it flexes like crazy since it is only mounted to the tow loops. I am probably going to upgrade to their rear bumper/hitch, and it would be nice to know that it will comfortably support the weight of the rack. Thanks! _________________ 85 Westy with Bostig V2.0 & private beta turbo
Boulder, CO |
86syncrowesty Samba Member
Joined: September 23, 2010 Posts: 115 Location: Colorado Front Range
Posted: Fri Feb 15, 2013 7:33 pm Post subject: |
| rumitcu wrote: |
Saweet!
Here is a tangential question: do you notice any significant flex in the GW bumper/hitch from the lever arm of the bike rack? I have the 4-bike version of that on the GW stand-alone hitch, and it flexes like crazy since it is only mounted to the tow loops. I am probably going to upgrade to their rear bumper/hitch, and it would be nice to know that it will comfortably support the weight of the rack. Thanks! |
You may want to look into the Burley hitch, it travels a good length down the frame rails for support. _________________ 1986 Vanagon -- Syncro, Westy
2.5L Subaru |
Altoona Samba Member
Posted: Fri Feb 15, 2013 8:59 pm Post subject: |
| rumitcu wrote: |
Saweet!
It will definitely support it. The hitch is bolted into the inner framework of the bumper - which is in turn bolted deep into the frame rails in three locations (2 stock points and a third past them). It is quite stout. |
specialev Samba Member
Joined: March 25, 2011 Posts: 282 Location: Mukilteo WA
Posted: Sat Feb 16, 2013 11:02 am Post subject: |
| Did you put an extension on your bike rack? I've got the same rack with the GW bumpbers but when stowed it sit's much closer to the van. |
Posted: Sat Feb 16, 2013 1:07 pm Post subject: |
| specialev wrote: |
I extended about 12 inches" around the hitch area and had to shave some plastic part where the front wheels rests. I also extended the 15 inches like a add on piece so I can mount a third bike piece. |
Posted: Sat Feb 23, 2013 2:16 pm Post subject: |
I wanted to share some pictures of this product called swag storage bin for action packer 8 gallon. Made very well in aluminum. Pretty cool stuff. This solves a lot of my storage issues when I go camping and the best part is, very easy access. I thought about getting a storage box on the roof but then I can't take my surfboard and getting up there would be a bit of hassle.
Aluminess box with Swag storage bin.
Aluminess box opens and can be used for a table for BBQ or other things.
you can also load other stuff on top of the bin.
http://www.swagoffroad.com/
http://www.aluminess.com/ |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Sat Feb 23, 2013 3:01 pm Post subject: |
| rumitcu wrote: |
Saweet!
I have a hitch mounted rack that I carry a hundred pounds or so on the GW bumper and it is rock solid. _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
HoustonPhotog Samba Member
Joined: February 20, 2013 Posts: 1526 Location: Houston, TX
Posted: Mon Jan 13, 2014 7:38 am Post subject: |
| whynotvw wrote: |
| syncromike wrote: |
I know this is a thread resurrection but I was very curious to see how you mounted the Aluminess box to the GoWesty Swing Arm. Curios to see if you just used the 4 hole mount points or used another method.
Thanks! _________________ Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15406 Location: Syracuse, NY
Posted: Mon Jan 13, 2014 8:21 am Post subject: |
might want to add some further mounted brake lights there else this all becomes your new impact zone  _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
Posted: Mon Jan 13, 2014 9:27 am Post subject: |
| danfromsyr wrote: |
might want to add some further mounted brake lights there else this all becomes your new impact zone  |
trust me, i had that figured out when i installed the box. the van seats high enough where the factory lights are easily visible when your behind my van.  |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17278 Location: Brookeville, MD
Posted: Mon Jan 13, 2014 9:29 am Post subject: |
| whynotvw wrote: |
| danfromsyr wrote: |
Looks like a truck driver would have a hard time seeing the brake lights...  _________________ Dave O
The Western Syncro build
Posted: Mon Jan 13, 2014 9:31 am Post subject: |
| HoustonPhotog wrote: |
| whynotvw wrote: |
| syncromike wrote: |
Thanks! |
I did some further mods, at first I made a larger square plate to go on top of the gowesty square. But that wasn't enough to fully secure it. So I used Gowesty universal mount or the pole then secured two bolts to the back of it. So I have four bolts for the bottom and two bolts on the back using the GW universal mount. Now, it is very secure.
I use it all the time and definitely worth the investment. Not only it looks awesome but very functional. And because it is made out of aluminum it is very light and don't have to worry about rust. Surprised all the stuff you can fit into that box and the swag box on top. Also because of the railing on top of the box it is super easy to secure things on top of that box.
I think Gowesty might come out with something similar down the line.
GW universal pole mount is a must to secure the backside of the box.
Posted: Mon Jan 13, 2014 11:09 am Post subject: |
| dobryan wrote: |
| whynotvw wrote: |
| danfromsyr wrote: |
Looks like a truck driver would have a hard time seeing the brake lights...  |
camera angel makes it worst then it is. But I have a third brake light I just need to install it. But from behind and sitting position you can see the tail light. |
Posted: Mon Jan 13, 2014 11:19 am Post subject: |
| whynotvw wrote: |
I use it all the time and definitely worth the investment. Not only it looks awesome but very functional. |
Thanks for the info!
Looks great.. _________________ Abel Longoria
