vwcomet Samba Member
Joined: January 05, 2008 Posts: 42 Location: Las Vegas, NV
Posted: Fri Nov 23, 2012 9:55 am Post subject: |
They look like the fasteners for the wood rear base bow for the convertible top. I had similar ones on my 1967 convertible. |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3915 Location: In Molinya Orbit
Posted: Sat Nov 24, 2012 6:29 am Post subject: |
vwcomet wrote: |
Thanks for your comment which gives me a place to look though I'm not sure how they go on. I assumed the rear bows mount on with some large coutersunk screws that I have in a labelled bag. If you (or anyone else) happen to have photos it would be great to see.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Aussie59Cab Samba Member
Joined: April 15, 2011 Posts: 136 Location: Australia
Posted: Mon Dec 10, 2012 4:23 pm Post subject: |
I have these pieces from my 59 Lowlight Ghia Convertible restoration that I don't know where they go and what they are. Please help.
_________________ 59 Karmann Ghia Cabriolet
56 RHD Oval |
dcrawford3 Samba Member
Joined: June 07, 2012 Posts: 38 Location: Wilmington, North Carolina
Posted: Sun Feb 17, 2013 5:13 am Post subject: Steering wheel |
So I was going through some of the parts that I received from the PO of my Ghia and found this steering wheel.
The markings on the front are partially obscured.
On the back side it says "Made in Italy"
Can anyone identify this wheel, will it fit a Ghia, is it worth refurbishing?
Thanks,
David _________________ '63 Ghia Coupe......
In the battle between a hammer and your skin....
The hammer always wins !
Measure Twice---Cut Once ! |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Posted: Sun Feb 17, 2013 6:28 am Post subject: |
Thanks John,
I think the comment "generic aftermarket wheel" just answered my question.
ghiarossa Samba Member
Joined: March 21, 2012 Posts: 85 Location: Jackson, MS
Posted: Fri Mar 01, 2013 5:18 pm Post subject: Guide tube? |
This was amidst the assorted parts in a box I got back with my 71 Ghia cabriolet. Some kind of guide tube?
_________________ David Odenwald
1958 VW Karmann Ghia coupe
1971 VW Karmann Ghia cabriolet |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Fri Mar 01, 2013 5:50 pm Post subject: |
^^ Clutch cable bowden tube. the bracket attaches to the left side of the transmission. |
Posted: Fri Mar 01, 2013 5:52 pm Post subject: |
Aussie59Cab wrote: |
the top pieces look like worn out brake shoe retaining cups.
the next pieces down are thrust washers for setting up type 1 spindles (king and link pin spindles) |
Posted: Sat Mar 02, 2013 9:35 am Post subject: |
hazetguy wrote: |
Thanks for identifying it. _________________ David Odenwald
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Thu Apr 11, 2013 9:09 pm Post subject: |
Friend who's an ACVW mechanic comes across these installed on the fuel lines of stock VW's at times, but does not know what they are. The bottom tube has a hole that opens to the cavity above, but is straight though otherwise. The top tube seems to be valved or restricted, but he is does not recall if the top tube was connected to a fuel or vacuum line. It does have the VW emblem cast into the body.
Paul
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
Altema Samba Member
Posted: Fri Apr 12, 2013 7:50 am Post subject: |
No kidding, a factory shut off valve! Examining it, it looks like suction from the inlet side pulls down a diaphragm to open the valve for the discharge side of the pump to feed the carb. Doesn't seem very useful for run-on though since the valve would remain open as long as the engine is physically turning over...
Thanks for the info Everett, this is hugely helpful!
Paul |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Sun May 05, 2013 10:00 am Post subject: |
Altema wrote: |
ghia-13 wrote: |
thanks altema!! so on the cam where you have the gear aswlel it goes on opposite side of the cam where the opening is, to just cap off? |
That is correct. The raised edge of the plug fits in the groove of the case with the flat side facing out.
Paul
Or flat side in for autostick. |
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
aero3113 Samba Member
Joined: March 03, 2013 Posts: 196 Location: Setauket, NY (Long Island)
Posted: Wed Jul 10, 2013 10:08 am Post subject: |
Is it a rubber bumper for when you shut the glove box? |
Brassneck Samba Member
Joined: November 17, 2012 Posts: 420 Location: Seattle
Posted: Wed Jul 10, 2013 11:05 am Post subject: |
aero3113 wrote: |
I was thinking the same thing, except the ones I've seen are solid rubber all the way around. |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Wed Jul 10, 2013 11:17 am Post subject: |
does not look like a bumper to me. looks like a hole plug. bumpers are usually taller. the flat side goes out. the pointed side has the recess areas so it can squeeze through the hole. probably covers a hole to access a screw or bolt |
danielsan Samba Member
Joined: September 18, 2008 Posts: 802 Location: Carson City, NV
Posted: Wed Aug 07, 2013 10:57 am Post subject: |
It holds the faux wood facia in place, preventing lift and fills the mystery holes under the dash. There is one hole near each a pillar and one near the ash tray. |
