shizzon Samba Member
Joined: July 25, 2006 Posts: 600 Location: Boulder, CO
Posted: Sat Feb 16, 2013 5:23 pm Post subject: Should there be front sway bar endlink play? |
Folks,
My endlink on my drivers side front swaybar is loose. I assume that there should not be play, correct? Is this just due to the bushings being shot? That's my guess.... I may be due for some new ones. ...See video below
_________________ 1989 Bostig Syncro Westy |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2684 Location: Southeast Kentucky
Posted: Sat Feb 16, 2013 5:29 pm Post subject: Worn bushing |
The bushing is worn and most likely hardened.
I replaced those bushings (with the complete kit). Replacement requires removal from the vehicle.
I placed the sway bar in a bench vise and wrestled the bushing off. It is easier to remove than to install the new one. It is doable with brute strength, persistance and basic tools. I used spray silicone lube to aid with installation. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Posted: Sat Feb 16, 2013 5:31 pm Post subject: |
I assume the difficult one to remove is the upper bushing between the sway bar and the endlink? I assume the bottom two bushings just come out when you remove the bolt, right?
thanks!
sean _________________ 1989 Bostig Syncro Westy |
Posted: Sat Feb 16, 2013 5:49 pm Post subject: |
Scroll down to post # 543 in this link to see how I did the bushings on the bottom the sway bar link. http://forums.tdiclub.com/showthread.php?t=276798&page=37
I later removed the entire sway bar to tackle the larger swar bar bushings. I did take photos but never posted them. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
Vango Conversions Samba Member
Joined: October 04, 2010 Posts: 1054 Location: Seattle, WA
Posted: Sat Feb 16, 2013 5:51 pm Post subject: |
| you'll probably need a new spacer sleeve too. they usually get pretty rusty. |
Posted: Sat Feb 16, 2013 11:16 pm Post subject: |
The cost of replacing the bushings, at least with powerflex material (t3technique.com), makes me wonder if it's not just worth it to buy a whole new sway bar? _________________ 1989 Bostig Syncro Westy |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Sat Feb 16, 2013 11:41 pm Post subject: |
on our family vans I just use this urethane swaybar end link kit from my local FLAPS ($10~)
it requires only a little fitment adjustment and well it's in stock and works just dandy.
I have other items I prefer to spend my $$ with Loogy for than these..
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
MidwestDrifter Samba Member
Joined: June 13, 2012 Posts: 769 Location: Kicking Around Australia
Posted: Sun Feb 17, 2013 8:19 am Post subject: |
| danfromsyr wrote: |
X2 Used these type of bushings as well. The center bore needed enlarged a bit, but they have been good for the last 15k miles. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215 |
seanjenn Samba Member
Posted: Sun Feb 17, 2013 8:24 am Post subject: |
t3technique is having a sale this weekend too. _________________ 1987 GL Sunroof
2.1 4 spd |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Sun Feb 17, 2013 11:01 am Post subject: |
| MidwestDrifter wrote: |
| X2 Used these type of bushings as well. The center bore needed enlarged a bit, but they have been good for the last 15k miles. |
Did you drill them out or what? Thanks! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
BoneMachine Samba Member
Joined: January 15, 2012 Posts: 202 Location: MA, Boston Strong
Posted: Sun Feb 17, 2013 11:07 am Post subject: |
| Jake de Villiers wrote: |
Did you drill them out or what? Thanks! |
Using a reamer would be best, drilled holes are not truly round. Time to visit a machinist friend, maybe buy him a beverage. _________________ '85 Wolfsburg Edition Westfalia Weekender, Zetec #36, w/ Peloquin TBD
'83.5 Westfalia, full camper (we'll never forget you) |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1944 Location: Sidney B.C. Canada
Posted: Sun Feb 17, 2013 11:18 am Post subject: |
When you find a machinist that can accurately ream polyurethane then let us know
Drilling out bore is good enough, remember they fit over the steel spacing sleeve, then get squished when drop link attached and tightened.
cheers
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17296 Location: Brookeville, MD
Posted: Sun Feb 17, 2013 11:58 am Post subject: |
the ones from the flaps I used didn't need to use the sleeves, they have a protrusion that fits into the steering arm and negated the need of a sleeve.
for the centers I ran a close drill thru them it really didn't take very much at all. and this isn't a precision suspension piece just want it tight not loose.
the swaybar pushes down and pulls up against these bushings..
Chris gets my $$ no problem for other parts. this weekend it was/is lugnuts for my Audi wheel upgrade. _________________
| Abscate wrote: |
PAUL IRISH Samba Member
Joined: February 18, 2010 Posts: 20 Location: AFGHANISTAN
Posted: Sun Feb 17, 2013 2:21 pm Post subject: sway bar end link play |
| I bought the aftermarket end links which are thicker and powerflex bushings. the endlinks have a OD of 12 mm and have way too much play in the bushings. could not get an answer why so I ordered new SS steel sleeves and had them bored out with a 12mm bit. I spot welded the stainless washer kn top to the endlink and put the sleeves and top bushing on today. Will get someone stronger than me to put the endling and new bushing on the swaybar next week. Wonder what to do about the sloppy fit in the radius arm, put in grease or what. on the oringinal the whole area was full of rust and corrision. |
Posted: Sun Feb 17, 2013 3:07 pm Post subject: |
| dobryan wrote: |
| seanjenn wrote: |
| t3technique is having a sale this weekend too. |
I'm giving my money to Christopher (t3) this weekend.  |
You and me both, I just ordered the whole sha-bang-a-bang! _________________ '85 Wolfsburg Edition Westfalia Weekender, Zetec #36, w/ Peloquin TBD
Posted: Sun Feb 17, 2013 10:20 pm Post subject: |
A friend with a later model vanagon (85?) installed an addco bar, and gave me his OEM bar (which is also 21 mm). The bushings were in much better shape than my original bar, but I'm considering ordering powerflex bushings to improve handling. I have a couple more questions though:
1. My friends bar has the straight endlinks, not the curved ones like my 83.5 vanagon had. Is it okay to use ones with the straight endlinks on my year?
2. Also, how do I tell whether I need the "early production" front bushings (http://www.t3technique.com/powerflex-bushings/early-production-front-anti-roll-bar-set.html) or "late" (http://www.t3technique.com/powerflex-bushings/front-anti-roll-bar-set.html). They look very similar in the pics
3. Out of the 3 types of bushings on the front sway bar (upper endlink, lower endlink, and "middle" bushings), which ones are the most important to replace in order to improve handing ?
I'm basically trying to decide which bar I want to use... my friends, or my own. I can see that it would be very easy for me to replace the lower endlink bushings and the middle bar bushings (as above), but it seems like the upper endlink bushings would be an absolute pain to replace. I don't even see how one can pull the endlinks off of the main bar, much less get them back on. I'm kind of leaning towards just replacing the easy bushings, but I'd be willing to consider paying a shop to put on the upper endlink bushings if it was a really big deal for the handling.
Any thoughts on this would be much appreciated!
Sean _________________ 1989 Bostig Syncro Westy |
Posted: Sun Feb 17, 2013 11:00 pm Post subject: |
| shizzon wrote: |
Sean |
Go with the biggest bar!
The body mounting rubbers were the first ones I changed. _________________ '84 Vanagon GL 1.9 WBX
Posted: Sun Feb 17, 2013 11:02 pm Post subject: |
| ragnarhairybreeks wrote: |
cheers
alistair |
Good point - the hole doesn't have to be pretty...
How'd you hold them down while, uh, drilling them?  _________________ '84 Vanagon GL 1.9 WBX
