TroyG Samba Member
Joined: August 14, 2006 Posts: 192 Location: Nevada Texas
Posted: Mon Aug 18, 2008 6:16 am Post subject: Adapt your Torque Meister to 1 1/2 Gland Nut |
OK Guys here is how you do it.
Take a 1 1/2 socket ( OLD )
Take a old 36mm gland nut
Cut all the streads off the old gland nut and weld it to the socket.
When you are putting the Mister on the crank, turn it around so the short side is to the flywheel, insert the 36mm gland nut with the socket on it into the mister and torque it down.
SIMPLE , CHEAP , EASY
If you are in the Dallas area and you need your 1 1/2 Gland nut installed give me a call ( It's Free )
BTW NO smart a-- remarks about my welding ( I had a bad day )
http://www.reliablevdub.com/
_________________ http://www.reliablevdub.com/
Come and visit VolksTalk.com
at
http://www.volkstalk.com/ |
blue77bay Samba Member
Joined: February 11, 2006 Posts: 631 Location: Brisvegas Australia
Posted: Mon Aug 18, 2008 7:40 am Post subject: |
welding is fine but straight would have been nice  |
supermanbidder Samba Member
Posted: Tue Feb 26, 2013 11:10 pm Post subject: Torque ratio? |
Whats the torque wrench set at? |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 22679 Location: SHALIMAR ,FLORIDA
Posted: Wed Feb 27, 2013 8:17 am Post subject: |
or instead of making that a 1 thing only socket how about pressing a 3" ,1/2"extension with the female portion cut off , into the gland nut and then weld the crap out of it so it would now be an adaptor and you could still use the socket for what ever you choose. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5036 Location: Madisonville, La
Posted: Fri Mar 01, 2013 7:28 am Post subject: |
My buddy whipped this up for me..... Works well.
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Fri Mar 01, 2013 9:20 am Post subject: |
Nice birdshit _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Posted: Fri Mar 01, 2013 11:01 am Post subject: |
what bird shit? wish I had one. |
Posted: Fri Mar 01, 2013 2:19 pm Post subject: |
Wish you had what? Modified socket or a welder who can make welds look like bubble gum and birdshit _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
MURZI Samba Member
Posted: Fri Mar 01, 2013 2:26 pm Post subject: |
That birdshit handles 600ft lbs real easy...... _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Fri Mar 01, 2013 6:22 pm Post subject: |
MURZI wrote: |
That birdshit handles 600ft lbs real easy...... |
Wasn't talking about yours. _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
MURZI wrote: |
Dubbers Toy Box
4inbore.com
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3331 Location: Charleston, SC
Posted: Fri Mar 01, 2013 6:44 pm Post subject: |
kielbasa wrote: |
MURZI wrote: |
Wasn't talking about yours. |
You were talking about the dead guy's. Stay classy! _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Fri Mar 01, 2013 7:08 pm Post subject: |
i sure hope he didnt die caused from a failed weld somewhere... _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
Posted: Fri Mar 01, 2013 7:17 pm Post subject: |
kielbasa wrote: |
i sure hope he didnt die caused from a failed weld somewhere... |
He died from cancer. You, however, are still alive. Care to defend this fine work?
At least it stays under the car where nobody can see 'em. _________________
66brm wrote: |
Bodacious wrote: |
Posted: Fri Mar 01, 2013 7:40 pm Post subject: |
im sorry i dont keep tabs on every single member here whos alive whos dead, hell i didnt even realize its a thread from years ago. that picture you posted of mine, looks fine to me. looks better in person, picture isnt that great. i feel i have nothing to defend... but keep it on subject, this is about welding a gland nut to a socket, not narrowed beams. and by the way, thats a 5 inch narrowed beam with shocktowers still intact, that fits nice under the car with out any modifications to the body. _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
Posted: Fri Mar 01, 2013 8:16 pm Post subject: |
kielbasa wrote: |
but keep it on subject, this is about welding a gland nut to a socket |
On subject? You've added nothing but criticism regarding the cosmetics of some welds, and for no other reason than to criticize cosmetics. And when Troy was alive, he was offering to help folks for free, cosmetics be damned. Since your crap smells like roses, I'm sure your welds will hold fine; but that big ol' glob of bubblegum at the base of the shock tower will be no less of a big 'ol glob of bubblegum in person. So, how about you give your bubblegum-chewer a rest already... _________________
66brm wrote: |
Bodacious wrote: |
Posted: Fri Mar 01, 2013 8:53 pm Post subject: |
Atleast it was about the topic at hand. I see no bubble gum on my beam. You may be confusing a 220mig welding 3/16 plate in a very shitty picture.. and im sure your use to looking at purtty aluminum tig welds. I weld for a living since I was 15. I know they will hold and they pass any structural or visual inspection. A lot of stuff I do gets looked over and even xrayed. Never a problem. Visual is a big part of welding, if it doesn't look good chances are it won't hold its own when properly tested.
To end this note, I am sorry if op was a friend, if not sorry to thosr who knew, lost plenty to cancer and it is not fun. Also seen a guy lose a leg because a weld broke and a peice swung over and took out his shin. Which is why I mentioned. A bad weld bothers me to no end, biggest pet peev. Sorry if criticism is one of yours. _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
Posted: Fri Mar 01, 2013 9:15 pm Post subject: |
you also either, assuming i know everyones living status can come off as naive, or you being a smart ass with your "stay classy" remark knowing i would have no idea he has passed. either way, you come off a bit dick-ish. just saying. _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
Posted: Sat Mar 02, 2013 10:10 am Post subject: |
I was refering to murzi's , as I dont have one of those tools.I could make one,but dont realy feal like it since Ive done my last vw motor for others cars,truck&busses&dont know when Ill get to back my motors. |
flyboat Samba Member
Posted: Sat Mar 02, 2013 3:08 pm Post subject: |
I just welded a 1.5" box end wrench to my miester. Cut the handle off of course. _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
