remove old glue residue from pop top
randywebb
randywebb is offline
PostPosted: Sun Mar 10, 2013 12:46 pm    Post subject: remove old glue residue from pop top Reply with quote
Any ideas on the best way to remove this glue residue from my poptop?
I want to make sure any chemicals I use do not melt the plastic FG(!)
This is from some velcro a PO had there to hold fishing rods.
1986 2.1L Westy 2wd Auto Trans.
msinabottle
msinabottle is offline
PostPosted: Sun Mar 10, 2013 1:03 pm    Post subject: A Thought Reply with quote
Some of what I went through might be helpful, I hope:
http://www.thesamba.com/vw/forum/viewtopic.php?t=505935
The fiberglass appears to be fine after all that.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun Mar 10, 2013 2:34 pm    Post subject: Reply with quote
Lacquer thinner, Enamel Reducer, Mineral sprits ( slower) , Goo Gone will all work without as long as it hasn't been painted in it's prior life.
You can remove the glue without any problems.
T.K.
IdahoDoug
IdahoDoug is offline
PostPosted: Sun Mar 10, 2013 5:39 pm    Post subject: Reply with quote
3M Adhesive Remover. It is designed to not attack normal automotive materials and finishes. However, it's harder to find and more expensive than the Goo Gone. I'd use a plastic scraper to remove the dried crud and when no more will crumble/pry off use a chemical.
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces.
randywebb
PostPosted: Sun Mar 10, 2013 5:48 pm    Post subject: Reply with quote
thx all
S4VAGE
S4VAGE is offline
PostPosted: Sun Mar 10, 2013 6:09 pm    Post subject: Reply with quote
Do you just want the sticker crap gone, or do you want the whole top to look the same color after? Answer could vary dramatically depending on what your end game is.
Either way, consider the pop top seal as you start to spray chemicals capable of removing glue. Make sure you protect it so when all that stuff runs down that you don't create a new problem as you fix this one.
peaceful warrior
peaceful warrior is offline
PostPosted: Sun Mar 10, 2013 6:18 pm    Post subject: Reply with quote
Mineral spirits and a razor blade. MS will not bother the rubber seal in the least.
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
tam_shops
tam_shops is offline
PostPosted: Sun Mar 10, 2013 6:51 pm    Post subject: Reply with quote
When scrubbing old adhesive off, I always use a pan scraper:
[url]http://www.ebay.com/itm/Pampered-Chef-Nylon-Pan-Sc...257b811f26[/url]
Doesn't have to be this brand, many kitchen stores have the same thing, different colours, same idea.
tam
1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885
S4VAGE
S4VAGE is offline
PostPosted: Sat Mar 16, 2013 2:25 pm    Post subject: Reply with quote
tam
Second that! Similar to what sign shops use to install vinyl stickers. I would only use razor blade on glass, not paint or fiberglass, but that's just me.
Terry Kay
Banned
PostPosted: Sat Mar 16, 2013 9:53 pm    Post subject: Reply with quote
A .50 cent plastic putty knife works well for adhesive removal on fiberglass gel coat.
On paint the softer vinyl lettering sqeege is recommended--won't mar the paint.
I use a rubber adhesive / lettering removal tool.
Works fast, no solvents required, no putty knife.
T.K.
