Muskrat Samba Member
Joined: July 20, 2006 Posts: 184 Location: sacramento, ca
Posted: Tue Mar 12, 2013 8:14 am Post subject: i suck at search. info on go westy 2.3 |
i tried the search but apparently i'm not very good at it because i get every post with go or westy in it. nothing comes up for 2.3. any help would be appreciated.
i'm looking at a tin top with a go westy 2.3 and i wanted to get a bit more info on reliability or any issues they have.
thanks
-k- _________________ Manx clone 62 pan 1500 single port
83.5 westy w/2.1 wbx...RIP |
SCM Samba Member
Joined: January 26, 2011 Posts: 3118 Location: Bozeman MT
Posted: Tue Mar 12, 2013 8:29 am Post subject: |
I only have about 6k on mine but it runs great.
The only problems I've had have been a leaking oil cooler o-ring (likely due to running it in single digit temps with 20-50 oil - per GoWesty's break in requirements) and a blown rear main seal. Read their site about rear mains, they acknowledge that they had a bad batch of them. Both issues were covered under warranty without any problems.
My mileage is pretty crappy (about 15 mpg), even for a Westy, but I think that is the fault of the auto trans.
All in all, I'm happy with it so far. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
ZanaEvyPapa Samba Member
Joined: July 31, 2010 Posts: 255 Location: Gainesville, FL
Posted: Tue Mar 12, 2013 8:37 am Post subject: |
http://bit.ly/WkDrVY _________________ 82 Diesel Westy
03 Jetta TDI
Gainesville, FL |
Mundopacheco Samba Member
Joined: November 14, 2006 Posts: 439 Location: Durango, Colorado
Posted: Tue Mar 12, 2013 9:39 am Post subject: |
I had a GL 2wd with the 2.3. I purchased this 'totaled' van, 6K after the engine was installed (by GoWesty.) I forget what the remaining warranty was, but I contacted them and they assured me they would honor it under its new ownership. I used that van for about 15K miles. In that time, I had zero issues...not even lifter clack. It was (BY FAR) the strongest 2.1 I had ever driven. I merged into traffic as if it were a normal vehicle. It was a great around town hauler and mule, but I sold my house, which included property that housed my eleven vans, so it was sold along with most of the others. |
bhamham Samba Member
Posted: Tue Mar 12, 2013 9:44 am Post subject: |
That is so cool... didn't know you could do site specific stuff like that - thanks. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Tue Mar 12, 2013 9:47 am Post subject: Re: i suck at search. info on go westy 2.3 |
grknvgn wrote: |
thanks
-k- |
Try a forum search using 'gowesty' as one word and check off the 'title only' box. This will get you a bunch of gowesty threads some of which pertain to their many engine options.... _________________ Dave O
The Western Syncro build
Posted: Tue Mar 12, 2013 9:51 am Post subject: |
bhamham wrote: |
you are welcome.
It's a game changer. I will never use a site's own search anymore. Google just does such a better job indexing information than anyone else.
Another tip: Sometimes you need to add more specifics because a sitewide search might give you results from the bug and ghia forums for example. In the OP's case, "GoWesty" was enough to narrow it down to only Vanagon results. So, let's say you wanted info on the Vanagon brakes, you'll want to do: "site:thesamba.com vanagon brakes"
And let's say you do that and there's just a ton of results with Big Brakes getting in your way, then add a modifier of "-big" and it will subtract any results with "big" in it. There's a ton of other little things you can do. I like to use the search bar, but this page makes it easy: http://www.google.com/advanced_search _________________ 82 Diesel Westy
03 Jetta TDI
Gainesville, FL
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Tue Mar 12, 2013 9:55 am Post subject: 2.3 |
Well GW put in a 2.3 and did all the rest of my van in 2006. Now 50,000 miles later not one problem. Yes the cat, coil, fuel pump, and muffler, went bad, but those are maintenance items. And batters ,tires, oil, filters, but I love my 2.3 ! But I also like my 2.0 ABA in my other van! _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
gl98115 Samba Member
Joined: April 22, 2011 Posts: 263 Location: Seattle, WA
Posted: Tue Mar 12, 2013 10:08 am Post subject: |
I bought a Westy with a GoWesty 2.3. It's got about 26k miles on the new motor. The motor is about the only thing that hasn't had a problem. _________________ '87 faux-Syncro Westy w/ 2.3l GoWesty WBX
djs94124 Samba Member
Joined: June 02, 2007 Posts: 79 Location: San Francisco
Posted: Tue Mar 12, 2013 10:44 am Post subject: |
I had a GoWesty 2.3 installed in my 2WD, manual trans full camper in 2005. So far, after approx. 17K miles (I don't drive it much these days), I have had no problems related to the engine. Driveability has been great, able to merge with highway traffic without drama, and it takes mountain grades easier without the need for as much down-shifting.
Mileage has been a consistent 16-17 mpg no matter the conditions. Wish it were a little better in this area. _________________ 1987 2WD Westfalia
Modifications: GoWesty 2300 engine & rebuilt transaxle, 16x7.5 tire/wheel kit, South African "Big Brake" kit, Bilstein HD shocks, Whiteline front sway bar, 2WD Lift Springs, 2nd deep-cycle battery. |
wildenbeast Samba Member
Posted: Tue Mar 12, 2013 11:42 am Post subject: |
I also have a GoWesty 2.3 and have had no problems with it. I got it when purchasing our van and it was just past the break-in period. I have now put about 12k miles on it. After doing some really custom things to my last van, I only wanted a WBX motor this time around. I would have also considered a Vanistan or Rocky Jennings motor if the van hadn't come equipped with the GoWesty 2.3, but I am super happy with it. The major upgrade I've done is add a Vanistan exhaust to really eek out every last bit of possible performance. _________________ - Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU) |
SCM Samba Member
Posted: Tue Mar 12, 2013 12:05 pm Post subject: |
wildenbeast wrote: |
The major upgrade I've done is add a Vanistan exhaust to really eek out every last bit of possible performance. |
And just how noticeable is the resulting "eekage"? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Tue Mar 12, 2013 2:12 pm Post subject: |
I posted my impressions of the eekage here:
http://www.thesamba.com/vw/forum/viewtopic.php?p=6140249&highlight=#6140249
Bill
SCM wrote: |
And just how noticeable is the resulting "eekage"? |
Posted: Tue Mar 12, 2013 6:06 pm Post subject: |
thanks for all the reply's and search schooling.
now on to the test drive. _________________ Manx clone 62 pan 1500 single port
Chuey Samba Member
Joined: October 18, 2010 Posts: 858 Location: Oceanside, California
Posted: Tue Mar 12, 2013 8:44 pm Post subject: |
Don't you have to use Premium fuel in the 2.3? For me, a cheapskate, I considered that and got the lowest price GW engine which has been great. I run Regular grade fuel but good oil.
Chuey |
Posted: Tue Mar 12, 2013 8:46 pm Post subject: fuel |
Chuey wrote: |
Chuey |
No , only on the 2.4 and 2.5 this is why I wanted the 2.3 _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
Posted: Wed Mar 13, 2013 4:52 am Post subject: |
I used regular unleaded on my 2.3 at elevations of sea level through 10,000' and never had a problem or deviation in performance, other than that caused by elevation. Sweet motor.
Miguel |
Chuey Samba Member
Posted: Wed Mar 13, 2013 5:44 am Post subject: Re: fuel |
joseph928 wrote: |
Chuey wrote: |
Chuey |
No , only on the 2.4 and 2.5 this is why I wanted the 2.3 |
Oh, great! Now, I have to go to the link in the above post so I can learn about the eekage. Man, I hope I'm not sorry I got the smaller engine.
At the same time, I had them put in a new radiator. I had gotten mine when GoWesty still worked on customer cars. I was having them do pretty much all my work and I was buying, piece by piece, all their mechanical upgrades.
Chuey |
Posted: Wed Mar 13, 2013 10:49 am Post subject: Re: fuel |
You don't have to use premium fuel in a 2.3 but I find you get much better fuel efficiency if you do put in premium fuel. The cost difference between low octane and premium is typically less than $2 per tank.
joseph928 wrote: |
Chuey wrote: |
Chuey |
Posted: Wed Mar 13, 2013 11:07 am Post subject: Re: fuel |
You don't have to use premium fuel in a 2.3 but I find you get much better fuel efficiency if you do put in premium fuel. |
That's surprising. How much difference? _________________ '87 faux-Syncro Westy w/ 2.3l GoWesty WBX |
