Oil leaking from transmission nose cone
pickledBus
pickledBus is offline
PostPosted: Wed Mar 13, 2013 5:17 pm    Post subject: Oil leaking from transmission nose cone Reply with quote
I was under my 77 FI camper bus looking at a starter problem from another thread and I noticed this wet oil around the shift coupler and nose code. I haven't cleaned the bus since I bought it about 6 months ago and it has been mostly sitting in my driveway with the occasional drive to keep the battery charged and gas flowing through it. How worried should I be about this oil leak?
rustbus
rustbus is offline
PostPosted: Wed Mar 13, 2013 5:23 pm    Post subject: Reply with quote
in my opinion, it would take 20 years for that leak to leak out all your tranny fluid.
have you check the level in the transmission? you need a 17mm hex to do it.
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Mar 13, 2013 5:31 pm    Post subject: Reply with quote
And a few days for dirt to collect on the shift coupler and rip the inserts to shreds… Shocked
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
pickledBus
PostPosted: Wed Mar 13, 2013 7:29 pm    Post subject: Reply with quote
So should I just wipe it down with a shop towel or do I need to break out a degreaser and some tooth brushes to really get everything off?
dehoto
dehoto is offline
I had a similar problem when my bus had been parked on a slope, front end lower than the rear. The gearbox oil slowly leaked through a breather hole located higher up the nose cone.
If not this then maybe the seal where the rod comes out of the nose cone is worn?
VDubTech
VDubTech is offline
PostPosted: Wed Mar 13, 2013 7:36 pm    Post subject: Reply with quote
Nose cone seal is worn and needs to be replaced. I agree that this isn't something you need to fix this second but be aware of it and next time you have the engine and transmission out, replace it. I would probably hit it with some degreaser and clean it up as good as you can. It'll be easier to keep track of if it's clean.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
fusername
fusername is offline
PostPosted: Wed Mar 13, 2013 7:48 pm    Post subject: Reply with quote
yeap, clean it w/ a rag, maybe some paint thinner if you feel fancy, and just keep an eye on it. It is on your engine drop to-do list now.
and do check the trans fluid level soon, who knows when the last time it got any attention was.
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
udidwht
udidwht is offline
PostPosted: Wed Mar 13, 2013 11:02 pm    Post subject: Reply with quote
That leak could never empty the trans enough to be an issue. It'll only weep when driven.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
fusername
PostPosted: Wed Mar 13, 2013 11:40 pm    Post subject: Reply with quote
yeah but who knows how many other seeps and weeps the old girl has had over the years, and if he just noticed this leak, who knows the alast time someone stuck a finger in her hole to check that she was all lubed up proper
[email protected]
