Bliss13 Samba Member
Joined: July 28, 2009 Posts: 185 Location: Northridge, Ca
Posted: Thu Mar 14, 2013 1:52 pm Post subject: |
Notched wrote: |
That's one cool project!! That thing has TONS of room for a turbo and water/air intercooler. . . It's the right thing to do and you know it!! |
Man, I already have most of the turbo parts. PO had big plans... _________________ 1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro |
supaninja Samba Member
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Thu Mar 14, 2013 5:37 pm Post subject: |
Bliss13 wrote: |
Nate M. wrote: |
Man, I already have most of the turbo parts. PO had big plans... |
Just thought I'd clear up this quote... As it wasn't mine... _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Fri Mar 15, 2013 1:50 pm Post subject: |
supaninja wrote: |
Hey Bliss- Here is the fuel pump bracket that I made, it replaces the frame head cover.
After I cast it
cleaned it up and drilled and tapped
and installed
Wow, that's really nice! I'm sure I could weld something up similar and mount it in the same location you did. _________________ 1970 Sundial Camper
1973 SubaBeetle
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Fri Mar 15, 2013 7:33 pm Post subject: |
Bliss13 wrote: |
supaninja wrote: |
After I cast it
and installed
Wow, that's really nice! I'm sure I could weld something up similar and mount it in the same location you did. |
Yes you could, but Nick was trying to recycle his beer cans and busted lawn furniture. You know, clean up the junk that was laying around.
I personally like the part Nick casted, and it shows real thinking outside the box, to make the stuff to do sand casting. That's dedication. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Mar 22, 2013 6:53 pm Post subject: |
http://youtu.be/zEhJjOkRXVk (Start up)
Well, it's alive! I found a video on youtube showing how to troubleshoot a no spark condition on a Subaru engine, followed the steps and narrowed it down to 2 signal wires coming from the computer to the igniter. I guess back when the ground cable came off, the two pins (in the ECU) to those wires were burned out. luckily there are 4 pins and my engine only needs two. So it was a matter of switching the wires from the 1 and 2 pins to the 3 and 4 pins, then hooking up the laptop and programming the thing to use the new pins. I let Lance at Outfront handle that, of course.
Whatever, the thing runs great! It's pretty damn fast too. The only problem now is the PO put a gutted out motorcycle muffler on the car and it sounds absolutely horrible. Imagine running straight pipe with an amplifier. So next stop will be a muffler shop.
By the way, I drove it home 1 1/2 hours in rush hour, L.A. traffic. The car drove well and the cooling system worked flawlessly. Never even hit 200 degrees. _________________ 1970 Sundial Camper
1973 SubaBeetle
jefftrish Samba Member
Posted: Fri Mar 22, 2013 7:21 pm Post subject: |
Really happy for you. You gambled and won. Patience, always pays off. |
Posted: Fri Mar 22, 2013 7:26 pm Post subject: |
jefftrish wrote: |
Thank you jefftrish. It was definitely a gamble, but I'm feeling pretty good about that trade right about now! _________________ 1970 Sundial Camper
1973 SubaBeetle
Posted: Fri Mar 22, 2013 8:12 pm Post subject: |
When you say it's pretty fast to, what do you mean?
It look's like a little work, and some detailing and you will have a very cool reliable Vdub.
Regards,
Jeff |
Posted: Fri Mar 22, 2013 8:23 pm Post subject: |
jefftrish wrote: |
Regards,
Jeff |
Well, it's got 190 hp, so it's got more power than any vw I've ever had, by far. Yeah, some detail and interior and I'll be pretty happy with it. _________________ 1970 Sundial Camper
1973 SubaBeetle
Posted: Fri Mar 22, 2013 8:33 pm Post subject: |
I have a 69 fastback with a 1760 old school stroker, ported heads, 1 1/2 Merged header, and a set of Kads. I' guessing 90 to 110 max. Its a lot of fun I can't imagine 190 hp. Must be a blast. I bet there will be a few surprised cars, at the stop lights.
Regards,
Jeff |
Posted: Sat Mar 23, 2013 6:48 am Post subject: |
supaninja wrote: |
AWESOME! I'm glad it was something simple, now get busy cleaning up the install! |
Agreed to both. Looks like it'll be a fun project. But the install definitely needs some clean up work. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
POWER ON Samba Member
Posted: Sat Mar 23, 2013 11:10 am Post subject: |
Bliss13 wrote: |
Well, it's alive! I found a video on youtube showing how to troubleshoot a no spark condition on a Subaru engine, followed the steps and narrowed it down to 2 signal wires coming from the computer to the igniter. I guess back when the ground cable came off, the two pins (in the ECU) to those wires were burned out. luckily there are 4 pins and my engine only needs two's. So it was a matter of stitching the wires from the 1 and 2 pins to the 3 and 4 pins, then hooking up the laptop and programming the thing to use the new pins. I let Lance at Outfront handle that, of course.
By the way, I drove it home 1 1/2 hours in rush hour, L.A. traffic. The car drove well and the cooling system worked flawlessly. Never even hit 200 degrees. |
Good job on the start up. Yup the boys at Outfront know the Subaru stuff real well and will help you till the end. If it wasn't for them I would never known anything about this great conversion. Reliable 200+ HP's is great fun in a VW too. As for the trans, it will be ok but just don't be doing drag race type burn outs with drag radials.
ENJOY THE RIDE! |
Posted: Sat Mar 23, 2013 8:07 pm Post subject: |
Thanks for all the encouragement guys. My bus will be down for another couple of weeks, so I actually need to drive this fastback a little while I work on cleaning things up. As far as long term, I may actually swap this Subie over to my bus and convert the fastback to regular old type 3 power again. If so, it won't be til next year though. _________________ 1970 Sundial Camper
1973 SubaBeetle
Posted: Sat Mar 23, 2013 11:30 pm Post subject: |
Bliss13 wrote: |
Thanks for all the encouragement guys. My bus will be down for another couple of weeks, so I actually need to drive this fastback a little while I work on cleaning things up. As far as long term, I may actually swap this Subie over to my bus and convert the fastback to regular old type 3 power again. If so, it won't be til next year though. |
Once I went to Subaru swaps I never looked back. Vanagons, buggies, Thing, type 3's, type 2's. Who ever rode and drove them become involved too. May it be hard core vintage guys to hard core full race VW engine guys. It's the best of both worlds. Glad you got to see the light that we did.
Enjoy! |
FastyinaField Samba Member
Joined: December 25, 2009 Posts: 48 Location: New Hampshire
Posted: Sun Mar 24, 2013 8:52 pm Post subject: |
The DOHC 2.5l is only 165hp, not 190. They also have a pretty poor headgasket reputation. The bad headgaskets often lead to bad rod bearings because people will run the engines until they stop from massive overheating when the headgaskets go. The engine will fire back up after it cools off and a shop replaces just the headgaskets, sending a hurt engine back out to blow the rest of the way up shortly after.
They are a good engine, they just have a bad reputation due to the headgaskets. Replace them preemptively with the updated ones from Subaru and it will be a great engine for you. |
