'67 Subaru Powered Fastback (It's Alive!)
Bliss13
Bliss13 is offline
PostPosted: Thu Mar 14, 2013 1:52 pm    Post subject: Reply with quote
Notched wrote:
Shocked
That's one cool project!! That thing has TONS of room for a turbo and water/air intercooler. . . It's the right thing to do and you know it!! Laughing
Man, I already have most of the turbo parts. PO had big plans...
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
supaninja
supaninja is offline
PostPosted: Thu Mar 14, 2013 4:19 pm    Post subject: Reply with quote
Hey Bliss- Here is the fuel pump bracket that I made, it replaces the frame head cover.
After I cast it
cleaned it up and drilled and tapped
and installed
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
notchboy
notchboy is offline
PostPosted: Thu Mar 14, 2013 4:25 pm    Post subject: Reply with quote
Not bad for a squid from Houstain! Not bad at all. Cool
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
supaninja
PostPosted: Thu Mar 14, 2013 4:42 pm    Post subject: Reply with quote
Wink
-I was a soldier too Cool
Nick
Notched
Notched is offline
PostPosted: Thu Mar 14, 2013 5:37 pm    Post subject: Reply with quote
Bliss13 wrote:
Nate M. wrote:
Shocked
Just thought I'd clear up this quote... As it wasn't mine... Very Happy
Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
Bliss13
Bliss13 is offline
PostPosted: Fri Mar 15, 2013 1:50 pm    Post subject: Reply with quote
After I cast it
and installed
Wow, that's really nice! I'm sure I could weld something up similar and mount it in the same location you did.
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
Bobnotch
Bobnotch is offline
PostPosted: Fri Mar 15, 2013 7:33 pm    Post subject: Reply with quote
Bliss13 wrote:
After I cast it
and installed
Yes you could, but Nick was trying to recycle his beer cans and busted lawn furniture. You know, clean up the junk that was laying around. Wink
I personally like the part Nick casted, and it shows real thinking outside the box, to make the stuff to do sand casting. That's dedication. Cool
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Bliss13
Bliss13 is offline
PostPosted: Fri Mar 22, 2013 6:53 pm    Post subject: Reply with quote
http://youtu.be/zEhJjOkRXVk (Start up)
Well, it's alive! I found a video on youtube showing how to troubleshoot a no spark condition on a Subaru engine, followed the steps and narrowed it down to 2 signal wires coming from the computer to the igniter. I guess back when the ground cable came off, the two pins (in the ECU) to those wires were burned out. luckily there are 4 pins and my engine only needs two. So it was a matter of switching the wires from the 1 and 2 pins to the 3 and 4 pins, then hooking up the laptop and programming the thing to use the new pins. I let Lance at Outfront handle that, of course.
Whatever, the thing runs great! It's pretty damn fast too. The only problem now is the PO put a gutted out motorcycle muffler on the car and it sounds absolutely horrible. Imagine running straight pipe with an amplifier. So next stop will be a muffler shop.
By the way, I drove it home 1 1/2 hours in rush hour, L.A. traffic. The car drove well and the cooling system worked flawlessly. Never even hit 200 degrees.
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
jefftrish
jefftrish is offline
PostPosted: Fri Mar 22, 2013 7:21 pm    Post subject: Reply with quote
Really happy for you. You gambled and won. Patience, always pays off. Cool
Bliss13
Bliss13 is offline
PostPosted: Fri Mar 22, 2013 7:26 pm    Post subject: Reply with quote
Thank you jefftrish. It was definitely a gamble, but I'm feeling pretty good about that trade right about now!
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
jefftrish
PostPosted: Fri Mar 22, 2013 8:12 pm    Post subject: Reply with quote
When you say it's pretty fast to, what do you mean?
It look's like a little work, and some detailing and you will have a very cool reliable Vdub.
Regards,
Jeff
Bliss13
Bliss13 is offline
PostPosted: Fri Mar 22, 2013 8:23 pm    Post subject: Reply with quote
Regards,
Jeff
Well, it's got 190 hp, so it's got more power than any vw I've ever had, by far. Yeah, some detail and interior and I'll be pretty happy with it.
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
supaninja
PostPosted: Fri Mar 22, 2013 8:30 pm    Post subject: Reply with quote
AWESOME! I'm glad it was something simple, now get busy cleaning up the install!
Nick
jefftrish
PostPosted: Fri Mar 22, 2013 8:33 pm    Post subject: Reply with quote
I have a 69 fastback with a 1760 old school stroker, ported heads, 1 1/2 Merged header, and a set of Kads. I' guessing 90 to 110 max. Its a lot of fun I can't imagine 190 hp. Must be a blast. I bet there will be a few surprised cars, at the stop lights. Twisted Evil
Regards,
Jeff
Bobnotch
Bobnotch is offline
PostPosted: Sat Mar 23, 2013 6:48 am    Post subject: Reply with quote
Agreed to both. Looks like it'll be a fun project. But the install definitely needs some clean up work. Wink
Tram wrote:
Tram wrote:
supaninja
PostPosted: Sat Mar 23, 2013 8:35 am    Post subject: Reply with quote
I would get a spare trans before that one splodes Wink
Then figure out what you want to do for the long term, 901 or 091. Type 1/3 trannies are just too fragile (that should get some panties in a wad, hehe)for that power and especially that tq.
Nick
POWER ON
POWER ON is offline
PostPosted: Sat Mar 23, 2013 11:10 am    Post subject: Reply with quote
Well, it's alive! I found a video on youtube showing how to troubleshoot a no spark condition on a Subaru engine, followed the steps and narrowed it down to 2 signal wires coming from the computer to the igniter. I guess back when the ground cable came off, the two pins (in the ECU) to those wires were burned out. luckily there are 4 pins and my engine only needs two's. So it was a matter of stitching the wires from the 1 and 2 pins to the 3 and 4 pins, then hooking up the laptop and programming the thing to use the new pins. I let Lance at Outfront handle that, of course.
Good job on the start up. Yup the boys at Outfront know the Subaru stuff real well and will help you till the end. If it wasn't for them I would never known anything about this great conversion. Reliable 200+ HP's is great fun in a VW too. As for the trans, it will be ok but just don't be doing drag race type burn outs with drag radials.
ENJOY THE RIDE!
Bliss13
Bliss13 is offline
PostPosted: Sat Mar 23, 2013 8:07 pm    Post subject: Reply with quote
Thanks for all the encouragement guys. My bus will be down for another couple of weeks, so I actually need to drive this fastback a little while I work on cleaning things up. As far as long term, I may actually swap this Subie over to my bus and convert the fastback to regular old type 3 power again. If so, it won't be til next year though.
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
POWER ON
POWER ON is offline
PostPosted: Sat Mar 23, 2013 11:30 pm    Post subject: Reply with quote
Once I went to Subaru swaps I never looked back. Vanagons, buggies, Thing, type 3's, type 2's. Who ever rode and drove them become involved too. May it be hard core vintage guys to hard core full race VW engine guys. It's the best of both worlds. Glad you got to see the light that we did.
Enjoy!
FastyinaField
FastyinaField is offline
PostPosted: Sun Mar 24, 2013 8:52 pm    Post subject: Reply with quote
The DOHC 2.5l is only 165hp, not 190. They also have a pretty poor headgasket reputation. The bad headgaskets often lead to bad rod bearings because people will run the engines until they stop from massive overheating when the headgaskets go. The engine will fire back up after it cools off and a shop replaces just the headgaskets, sending a hurt engine back out to blow the rest of the way up shortly after.
They are a good engine, they just have a bad reputation due to the headgaskets. Replace them preemptively with the updated ones from Subaru and it will be a great engine for you.
Page 3 of 8
